Question about Eljer & Savoy& Toilet Tank With Lid
Flapper wont stay up during flush - Eljer & Savoy& Toilet Tank With Lid
  • 43,501 Answers
In the bottom side of the flaper there is a hole. There sould have come with the flapper pugs to make the hole smaller if the flapper goes down too fast... If you have them put a plug in there that has a smaller hole...they will be assorted colers, each color having a different size hole.
If you do not have the plugs then shut the water off and use something like a silicone caulk to close up the hole some. This will keep the air inside the flapper longer and help it to "float" or stay up longer...
Let the silcone setup or dry for a couple hours and then try again... or just buy a replacement flapper that has the plugs.... the whole replacement should cost less then ten bucks...
heatman101
Posted on Sep 27, 2010
How to adjust water level on Glacier Bay n2316. Never flushes totally in one flush.
Before you adjust the level, check the flapper. If it's worn, it may not be staying up long enough during the flush. You can replace the original, or buy a "dial a flush" flapper. (Made by Fluidmaster)
May 07, 2015 | Home
Why won't my toilet flapper stay up long enough to flush
this is pretty easy - when you install the flapper on the vent tube do not push it all the way down. slide the rubber over the tube and just far enough to make the flapper level. it will be about 1/2" off the bottom of the tube. if you push it all the way down, the flapper will slam shut before the flush is finished.
Sep 01, 2014 | Home
Toilet does not have good flush
The power of the flush has nothing to do with the fill valve. It has to do with the flapper. When the flapper is opened, the surge of water into the bowl is what causes the toilet to flush. If the flapper closes too quickly, it will take away from the powerful flush. Try to find the correct flapper for that type of toilet and stay away from the "universal" flappers.
Feb 06, 2014 | Home
Toilet flapper doesn't stay up unless handle is held down until tank empties.
If the flapper won't stay up, you may be lifting it too high - you want to retain a little air inside it when it's lifted. Try adjusting it to a lower lift height.
Jan 12, 2014 | Plumb Pak Plumbing
Water constantly runs in toilet. occasionally will semi-flush on it's own. How do I adjust mechanisms to prevent this?
change the rubber flapper in the bottom of the tank. This is the way water stays or leaves the tank. You can find the flapper by taking the top off the tank. Flush the stool and you will see the flapper come up . it is at the center bottom of the tank. turn the water off to replace it, and flush the tank after you have turned the water off to get as much water out of the tank as possible to replace the flapper. you can get a new flapper at any hardware store for just a few dollars
Apr 08, 2011 | Home
How can I adjust the float, I have wellworth complete solution class five (11471-0). It seems like the float goes down quickly, with emptying the remaining water. I have set the right water level, and yet...
what happens is the float is not staying open for long enough, by shorting the chain that goes to the flapper might help but you can only shorten it so much or the flapper does not close all the way then the toilet is just running and running. No you don't want that so the other thing you can do that might work is when you go to flush the toilet just hold the handel down for 5 seconds this will keep the float up and open for the Right amount of time. Other wise the other way to fix it witch is a old school trick is that you need to find a nice small piece of foam, witch floats and is about the size of a old half dollar and as least half inch thick, you place that on the chain that goes to the flapper so when the toilet is flushed the flapper will float and stay open . IF you do this just make sure to use a good piece of foam and secure it properly where it wont come off the chain.
May 18, 2010 | Kohler K-11470-0 White Wellworth Complete...
Yellow attachment to flapper in Cadet 3 toilet tank
Some toilet flappers are designed with this some are not. It has to do with the particular flapper design, helping the flapper to stay in the open position to allow a better flush. Anyways you should be to adjust this float up or down to optimize it's usefulness. Trial and error is all you can do, keep watching and flushing until it no longer gets in the way. I hope this helps in at least knowing that for your toilet and the flapper you have, it's suppose to be there. Good luck and thanks for using FIXYA and have a great weekend. Jeff
Apr 09, 2010 | American Standard 4112.016 Cadet Toilet...
We have to flush at least two times before we get a complete flush. any suggestions?
Some of these come with a flapper/flush valve that is made to operate in partial or full flush. Look at the underside of the flapper. Is it a cone shape that has a pencil sized hole in it (or two)? This cone is supposed to keep the flapper afloat during the flush, but the holes allow it to flap back down early. Its a pretty cheezy way to pass the low water requirement, but they get away with it. If you hold the flush handle down for a few seconds (until the tank empties) you will get a full flush, but only when you need it. Or you can just buy a replacement flapper that doesn't have the hole in it. They are cheap and easy to replace, but you will use more water.
Jan 17, 2010 | Toto Drake ADA Compliant Toilet with...
Toto toilet, flapper doesn't stay up long enough to flush
One of two things is the problem. First, make sure that you have a tight chain with little slack. If there's too much slack, the flapper won't catch in the passing air to stay up. Second, the flapper is not correct for that style of toilet. You might want to look into purchasing a new Kolby filter that has a removeable cone in the center. Move that cone to 12 o'clock to allow the maximum amount of water to run through the flush valve. If the flapper you have now is flat, it needs to have a cone in the center on the underside.
Jul 09, 2009 | Toto Toilets ST753S 01 Cotton Dartmouth...
Eljer & Savoy& Toilet Tank With Lid  Logo
102 people viewed this question
Top Eljer Home Experts
john h
Mike
Donni Steen
Are you an Eljer Home Expert? Answer questions, earn points and help others
