Question about Lexmark C772dn Laser Printer
960 Service memory Error A I am getting this error
960 Service memory Error A I am getting this error message and would like to know what does it mean. thanks
  • Lexmark
    Lexmark Sep 27, 2010
    The error message indicates a failure of the RAM memory that is soldered onto the printer's main controller/system board. Please remove any extra memory installed in the printer. If error continues, printer may require a service call for professional assistance. Contact Lexmark technical support (printer under warranty) or local authorized service provider. thanks
Inky
  • 691 Answers
SOURCE: "Service Req E095"
This is an HSYNC Error and probably means the Laser unit on your machine is faulty.
Possible causes of the error :
Laser Scanner
LSU Harness
C585 Main MCU Board
For more info get a service manual HERE
Posted on May 29, 2008
leroyal
  • 2120 Answers
SOURCE: 49.c02 service error message on HP laserjet 4100
General printer error. Unplug the power cord for 10 seconds.
Posted on Feb 06, 2009
  • 1602 Answers
SOURCE: IBM infoprint 932 service printhead error
go on line and type in
ibm infoprint 1352 laser printer error 932
enter
or
ibm 1352 infoprine error message 932
rod
hdsportyem
  • 11 Answers
SOURCE: Epson Acculaser CX11NF Error 'Service Req E527'
Hi.. To fix the E527 error, close the front panel (cover A) and open the top cover (cover B). With the photoconductor unit removed, the toner carousel will rotate. It only rotates if cover A is closed all the way. You can easily rotate the carousel to a position where you can remove/reinstall the toner cartridge if stuck.
Thanks
jim report_dis_text_13954 = 'We\'re sorry but you must be signed in to report inappropriate material. Click the button below to sign in or register.
  • Sign In / Register »
  • Cancel »
Posted on Feb 18, 2009
  • 7 Answers
SOURCE: we keep getting an error message - service error
Have you replaced the inks friend had same problem ink was'nt seated right took them out and refitted them error vanished.
Posted on May 24, 2010
I have an error message on my printer Expson XP-960 - error message is ox f1 - what does that mean and how do I fix it??????
That error usually means there is a paper jam. If not a jam, there may be a piece stuck somewhere. Try checking and clearing it.
Feb 02, 2017 | Epson Office Equipment & Supplies
2 3 4 orange blinking lights/ automatic start up and forced shutdown/ optiplex 960
Log in to: http://www.dell.com/support/home/us/en/04/product-support/product/optiplex-960/diagnose and send this info to Dell. As I recall lights 2,3,4 are either memory or HDD failure.
Run Diagnostic Run Diagnostic Diagnostics can be run on supported Dell devices with a full version of Windows.
Already have an error code from running ePSA diagnostics?
Dell devices come with preboot diagnostics to capture error codes. If you have already run a preboot system assessment (ePSA), enter the error and validation codes with your Service Tag below and complete the steps to resolve your issue. Enhanced Preboot System Assessment Error Code (without 2000-prefix) * Validation Code * Service Tag * Part Serial # (optional) ; ;
Mar 28, 2015 | Computers & Internet
OPTIPLEX 960 error codes 3 and 4 at startup. Solid amber light.
"optiplex 960 error codes 3 & 4 at startup"
Found out by myself the google suggestion to look up the Dell Diagnostics page:
http://support.dell.com/support/edocs/systems/Op745/en/UG_en/trouble.htm
Lights 3 & 4 means "Memory modules are detected, but a memory failure has occurred." Bingo! I didn't actually replace memory sticks, but pulled them out and put back in one by one. Only three out of four sticks were accepted. Works.
Jun 05, 2012 | Computers & Internet
960 service memory error-a lexmark c534dn what is wrong how to fix?? Gloria
The printer memory is failing. RAM soldered on the system board is bad. It would be best if you contact Lexmark Technical Support for proper assistance.
Jun 14, 2011 | Lexmark C534dn Color Laser Printer
960 service memory error how do I solve the problem on a Lexmark C534?
Theprinter memory is failing. RAM soldered on the system board is bad. It would bebest if you contact Lexmark Technical Support for proper assistance.
Mar 29, 2011 | Lexmark C534dn Color Laser Printer
Service 960 memory error- r for my Lexmark C532n printer
A 960 RAM MEMORY FAILURE message indicates a failure of the RAM MEMORY that is soldered onto the printer's main controller/system board.
If the printer is displaying a 960 memory error.
1. Power off the printer.
2. If you have any extra memory SIMMs or code SIMMs installed in the printer, remove them.
3. Power on the printer.
4. If the 960 error continues, the main controller/system board will probably need to be replaced.
5. If the 960 error does not return, try printing a few documents.
6. If these documents print correctly, the cause of the 960 memory error is probably one of the SIMMs you just removed.
To confirm this, do the following:
1. Turn off the printer and reinstall each SIMM one at a time.
2. After you install each memory card, power the printer back on and try printing. If the error returns as soon as you install a particular SIMM, that SIMM is probably the cause of the error message.
Nov 08, 2010 | Lexmark C530dn Laser Printer
960 service memory error - a
The error indicates that the system board's on-board memory has failed. This usually requires a service call but you can try to turn off the printer, then turn on after 15 seconds. If the problem continues, I strongly suggest you contact Lexmark technical support or an authorized service provider for assistance. You may need to know your printer's model type and the serial number when calling for service. Thanks.
Sep 10, 2010 | Lexmark C530dn Laser Printer
Memory card error
There are several possible causes for "memory card locked" or "memory card error". Some include trying to use of a 4GB SDHC card with an older camera made before SDHC format came out. Others include problems with the switch on the side of the card, and the switch internal to the camera. Troubleshooting tips for this problem may be found at this link.
May 23, 2010 | Canon IXUS 960 IS Digital Camera
Lexmark C772dn Laser Printer Logo
1,557 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
