Imagine you are subhaschandra bose now address your father and tell him why you dont want to go to englan about 200 words
    Brigadier General:
  • 10,406 Answers
Father, I don't want to go to England, because the long-term weather forecast is: rain, rain, rain, rain, rain, rain, rain, rain, rain,
rain, rain, rain, rain, rain, rain, rain, rain, rain, rain, rain, rain, rain,
rain, rain, rain, rain, rain, rain, rain, rain, rain, rain, rain, rain, rain.
Posted on Sep 27, 2010
Can you tell me the year of manufacture of bose lifestyle serial number 613095407 and another with serial number 1 203863. It will help me make a choose buying one second hand Thanks
I imagine Bose.com support could answer that. The more important question is - what series they are. That's printed right on the bottom.
May 23, 2011 | Bose 901 VI Main / Stereo Speaker
Could you send me the best set up starting with 1 for setting up our new XR 8600 Powered mixer in our church. We have 3 bose loudspeakers on each speaker output. Should those Bose be set for 100 watts...
Sorry, but you have a problem. The amp is rated to 4 ohms per side. Your speakers would have to be 16 ohm type to allow 3 per side in parallel. The Bose ratings are usually consumer type ratings and they would have to be set to 200 watts each (twice the rating that the amp can produce per side) to be safe connected to that amp. Your speakers are likely 8 ohm so you could parallel ONLY two per side OR if they are 4 ohm, then you would have to series them. You could series two or three per side safely for the amp. You don't tell us what model Bose speakers you have. Anyway, one has to first meet the specs of the amp and the speakers to avoid damage. It is likely the amp is too BIG for the speakers. For the setup of the mixer portion of this problem I want you to view videos on YouTube. Search for "mixer setup". Don't worry that they are different mixers than yours... there is enough commonality and the functions are nearly the same for MOST analog mixers. Recommendation: forget about two of the speakers... keep them as spares and run low volume to avoid blowing the speakers. I can't imagine any competent audio equipment supplier configuring your system this way.
Apr 24, 2011 | Peavey Xr 8600 8 Channel Powered Mixer
We have bose 9 speaker system from usa 110v it was my fathers we have brought it back to spain which is 240v can you help ie transformers
Probably every electrical supply store in Europe sells tranformers for American (110V) gear.
Google "240 - 100 transformer Europe"
What's a Bose 9? You mean 901? Before you try to use it get the manual from Bose.com and wrap your head around it's requirement for exclusive use of any amplifier.
Mar 08, 2011 | Bose Wave Radio
Printer HL 5370 DW is wrinkling all envelopes. Is
If it's not wrinkling regular plain paper, then you need to tell the printer you're printing envelopes. Envelopes are thicker than letter paper. When you tell it to print, make sure you click on "Properties" and set the job for "Envelopes". Also, make sure the guides are set to fit the envelopes snugly.
Apr 25, 2010 | Brother HL-5370DWT Laser Printer
Bose lifestyle 48 won't play stored music. Everything else works fine
Hard drive is ****..... impact computers.com hard drive number is MK4026GAX pull out of system and replace look at my other posting for 801 code!!! and dont be a ******** again and buy a bose!! TELL YOUR FRIENDS , FRIENDS DONT LET FRIENDS BUY BOSE!!!!
Mar 19, 2010 | Bose Lifestyle 48 System
My father is 75 yrs old. My sister bought him the
SORRY but we do not know what PHONE she bought .
Aug 08, 2017 | Cell Phones
Connecting speakers
I don't know if you have the original or the series II, but you can find the owners manual for both online at bose's site at this address.
http://www.bose.com/controller?event=VIEW_STATIC_PAGE_EVENT&url=/customer_service/owners/guides/comp_and_multimedia_speakers.jsp
this should tell you everything you need to know.
Jan 24, 2009 | Dell Latitude D500 Notebook
901 EQ1915
No. You may think you're doing it with the first solution, but the EQ curves introduced by the Bose Active EQ are extremely steep at the extremes. One could just as easily advise that the RIAA phono EQ curve (look it up) could be simulated through an external EQ, but why would you want to try? The best you would come up with is a ballpark match. Don't we really strive for accuracy?
Bose 901's employ 9 full-range, 4"-diameter drivers in each cabinet, hence there are no tweeters, no woofers and no internal crossovers. You can probably imagine how much EQ it would take to make a full-range driver, with its inherent limited voice coil travel and steep roll-off at the extremes, respond as if it was, say a 12-inch woofer, or a tiny dome super-tweeter.
Every series of Bose 901 that came out had its own specific matched series of Active EQ to compensate electronically for the natural limitations of the individual drivers. I imagine there were a lot of major simlarities from one to the next and that you would not be too far off the mark to mix a Series-IV EQ, for example, with a Series-V speaker pair, but I really doubt you're going to dial in the same curves with a manually adjusted equalizer without some specs as a guide.
Try to find the correct Active EQ on eBay. You’ll be much happier with the results.
Dec 01, 2007 | Bose 901 EQ1915 Home Equalizer
Manual for casio cfx 200
My husband's father gave him some old watches. He had them fixed. I was looking for the manual and found it at veitk.com/misc/cfx200. If that does not work the personal email address is tlveik@gmail.com. He no longer fixes these watches so the email address may no longer exist. He has a scanned copy of the manual there. I cut and pasted into word in case the copy was not good quality so all I have to do is zoom my percentage up. It that does not work I googled casio calcuator watchcfx-200. Hope this work
Nov 25, 2007 | Watches
Computers & Internet Logo
65 people viewed this question
David Payne
David Payne
