Question about Ovens
Hi I have an oven model:MER57750AW Maytag. The burners work, but I go to bake it gets up to the right temp just fine but it wont shut off. I have to unplug it. It would be cool if you could help.
  • 184 Answers
SOURCE: Freestanding Electric Maytag Stove /Oven (with 4 burners self clean w/clock)
I WOULD LOOK AT THE DOOR LOCK ASSEMBLY AS THE DEFECT. THERE IS USUALLY A SWITCH THAT TELLS THE CONTROL IF THE DOOR IS LOCKED OR NOT. IF THE SWITCH HAS SHORTED CLOSED, THE CONTROL THINKS THE DOOR IS LOCKED AND WON'T DO ANYTHING BUT CLEAN.
MOST OF THE ASSEMBLIES ARE UNDER THE RANGE TOP.
YOU MAY HAVE TO REMOVE TWO SCREWS FROM THE UNDERSIDE OF THE TOP AT EACH OF THE FRONT CORNERS. OPEN THE OVEN DOOR TO GAIN ACCESS.
IT WILL BE LOCATED IN THE CENTER. THE DOOR HOOK THAT STICKS OUT TO ENGAGE THE DOOR IS PART OF THE DOOR LOCK ASSEMBLY.
Posted on Apr 04, 2008
  • 190 Answers
SOURCE: Bosch oven not heating to temp
Dear customer,
i recommend u to try the following routine to sort out this problem
  • Check timer and clock settings
  • Reseat the element
  • Test the element
  • Test the element connectors
  • Test the oven temperature control
  • Test the oven selector control
  • Recalibrate the temperature control
  • hope u find this useful. thank you.
    Posted on Jul 09, 2008
    TheMobilian
    • 8220 Answers
    SOURCE: Won't bake, but all else works
    Swap the broil and bake ignitors(they are both the same) see if the bake works. If the oven bake works then you need only replace the ignitor. If it does not then I would say you should check the valve for continuity. If open, bad gas valve. If continuity is detected, bad oven control.
    Posted on Dec 22, 2008
    scottowa
    • 87 Answers
    SOURCE: Maytag gas Stove MGR5710 bake oven does not work. boiler works
    Usually I always find it's the ignightor. They are not to hard to replace. It's #5 on this looooong link
    http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=MGR5710ADW&productCategoryId=0124002&brandId=3048&modelName=GAS-RANGE&diagramPageId=00005&componentDescription=GAS%20CONTROLS&documentId=X2906551&backToLink=Return%20to%20Sub%20Components%20list
    Or go to http://www.searspartsdirect.com/partsdirect/index.action?intcmp=xsite_Sears
    enter your model number and it'll kind of show you how to get it apart. Good luck.
    Scott
    Posted on Jan 23, 2009
    shinn8
    • 85 Answers
    SOURCE: We have a Maytag Gas Range, Precision Touch
    Likely your oven igniter is bad. Part number 74007498
    Posted on May 18, 2009
    Oven "bake" burner wont ignite on a gas oven.
    The ignitor is not working right and is going bad....
    have the repair man replace the ignitor, or DIY....
    Check out this tip about your problem...
    Oven not Working or Oven not Heating
    Oven Problems Replacing the Igniter
    heatman101
    Dec 27, 2010 | Whirlpool Ovens
    I have a maytag pilotless ignition gas oven. the top burners work fine the broiler ignites fine. we just tried clean mode and its working too. the problem is we cannot get the oven to heat up. we turn bake...
    heatman101
    Oct 13, 2010 | Maytag Ovens
    When I turn on my Maytag performa using the "bake" function, everything looks ok on the display, however the temp. never rises above 100. I've tried "bake" and "convect", and neither one work. "Clean"...
    Usually the problem is the heating element. This is easy to check and usually inexpensive. There is a video at www.appliancehelponline.com/servicemanual.html that will walk you thru testing and replacing. It may be a different model but the testing and replacement will be the same. You can also enter your model # for diagrams and illustrations of your specific model.
    Apr 09, 2010 | Maytag 30" Built-In Single Electric Wall...
    Old kenmore built in oven wont unlock
    When I turn on my Maytag performa using the "bake" function, everything looks ok on the display, however the temp. never rises above 100. I've tried "bake" and "convect", and neither one work. "Clean" doesn't work either. The oven will lock, and display shows that it's heating up, but temp. never rises.
    However....."broil" feature works just fine.
    Please help.
    Apr 09, 2010 | Ovens
    My Maytag Performa oven and stove top will not turn on (heat up)
    Please help.
    Mar 09, 2010 | Maytag 30" Built-In Single Electric Wall...
    Gas oven model MGS5875BDB comes up to temperature fine but then won't hold the temp. the overn does not restart after it cols a bit. It is the same in bake or convect bake cycle.
    Hi, what you describe sounds like a weak igniter. The igniter (which lights the oven burner) doesn't go out all at once and will cause problems like this for a while, then quit working all together. I'd say replacement is the answer. Good luck.
    Jan 12, 2010 | Maytag Ovens
    My kenmore gas oven won't heat. I turn to dial to temp i want can smell gas building up in oven and can see a glow in bottom of oven but will not ignite. Sometimes if I turn on a cooking eye I can then...
    When the bake igniter becomes weak or burns out, your oven would not bake. The bake igniter is usually mounted on the oven burner. It's about 1 inch by 4-8 inches (depending on the model), and comes in round or flat styles. If you don't see the igniter glow at all, it's probably burned out. Replace the igniter if found defective. Note: one of the exceptions could be that your oven is set to automatic mode instead of manual. If this is the case, set your oven to manual mode and check again.
    If the bake igniter glows red and not bright yellow or white, it is probably because it is too weak. When this happens, the safety valve would not let the gas out into the oven burner. A weak igniter must be replaced.
    A faulty igniter is probably the most common cause, however there are others:
    -- defective thermostat
    -- defective selector switch
    -- defective gas safety valve
    -- defective gas valve coils
    Oct 22, 2009 | Whirlpool SB160PEE Gas Single Oven
    TOP BURNERS WORK BUT OVEN DOES NOT WORK AT ALL.
    Sounds like a heating element. Same thing happend to my oven. You can find them around 50-60 dollars. Veryy easy to install, just remove a couple of screws and remove old element and put in new one. Make sure you shut off power to oven firstg of course.
    Oct 08, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
    Ovens Logo
    48 people viewed this question
    Top Ovens Experts
    Dan Webster
    Dan Webster
    ashburton
    Are you an Oven Expert? Answer questions, earn points and help others
