Question about Bosch Nexxt WFMC330SUC
How do i tell the age of my bosch wfp3300 washing machine the F D number is FD8010 00033
Takes ages to wash
most washing machines take an hour for a normal wash
if yours takes longer then there is a problem in the control program that is not progressing the program
call a technician for as proper diagnosis and a quote
May 23, 2016 | Bosch Washing Machines
I have a 2009 bosch 100 series washer that won't wash or spin, but will drain?
I realize that this post really old but I wanted this to be available for the next guy. I bought Bosch part number 154740 which are brushes that worked for me. They will tell you it wont work but it did for my Bosch (wfmc1001uc/09) washing machine.
Mar 06, 2012 | Bosch Nexxt 100 Series WFMC1001UC Front...
Can anyone tell me where I can get carbon brushes for a Bosch WFMC1001UC/09 washing machine. Bosch does not sell or list the part. They say you have to replace the motor as a unit. The number on the old...
I realize that this post really old but I wanted this to be available for the next guy. I bought Bosch part number 154740 which are brushes that worked for me from repairclinic.com. They will tell you it wont work but it did for my Bosch (wfmc1001uc/09) washing machine.
Dec 28, 2011 | Washing Machines
Where is the Serial No on the Washing Machine?
the serial number is located in two places just inside the door on a sticker (most likely washed off though) or sometimes on the rear of the machine.if you cant find it you will need to call bosch and they can tell you if you where the original buyers they will have it on file
Dec 19, 2010 | Bosch Classixx WFO 2866 Front Load Washer
Machine is a WFP3300 Hydrosensor, no spin and we cannot open the door
Remove the flap on the bottom which covers the drain pump & you will see a red tag which is the standby door release.Pull it down & you will hear the door unlock. Drain off the water through the small black hose then unscrew the pump cover & remove the cause of the pump jam (hair clip etc)
Sep 05, 2009 | Bosch Washing Machines
Bra wire trapped in drain of washing machine noisy when drum rotates.How can I get it out?
Fishing line was looped through the larger holes in the back of the drum with a lassoo on the end of it & hooked round the wire then drawn out. A very time-consuming procedure in a confined space with a fine bendy light to illuminate the part.
Jun 01, 2009 | Zanussi FJS1225W Front Load Washer
How to disable beeps in Bosch wfo 2442 oe
please tell me somebody how to turn off spin for bosch WFO 2442?
May 29, 2009 | Bosch Washing Machines
Trying to sell machine and not sure of the exact age of machine.
The age is determined by the SERIAL number. Please provide me with your number (located on a nameplate around the wash tub opening) and I can tell you when it was manufactured.
May 18, 2009 | Kenmore 24032\24036 Top Load Washer
Help! My Bosch Nexxt washer has issues.
Will your machine pump out water? If it does it sounds like a faulty module. Try this website: www.bshappliancecare.com I think it identifies the model number by another code on the washing machine so you should be able to at least positively identify what unit you have. Good luck.
Sep 03, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
Bosch Nexxt  WFMC330SUC Logo
109 people viewed this question
Top Bosch Washing Machines Experts
Marvin
Marvin
Craig Butler
Craig Butler
jimorris77
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
