Question about Delta & Single Handle Shower Faucet
How do yor remove a shower control to fix leaking water does not turn off complete I took out screws but can,t seem to pull off the handle
  • 490 Answers
Handle has a plastic lid that pops/pries off and has a screw under it. Make sure to turn off the water supply to the bathroom or house before you pull out the cartridge.
Posted on Oct 12, 2010
How to remove the shower valve on my Maax shower? It is leaking badly, and I think I just need to get to the valve that directs water to either shower head, or back sprayer nozzles or the whole body
Its probbably the hose connected to the valve, try screwing it back on and turn the water up slowly, if that does not help, check your local radio shack
Nov 05, 2013 | Maax Brio II One-Piece Neo-Angle Corner...
Just had a single handle shower faucet installed in my new walk-out developed basement and it seems there is a control on it I want to remove. I can't get the handle to go beyond mid-point and I want more...
Hi im Rossouw
The rest of ur house water in the showers fine?
If not they must install a prv (Presure reducing velve) on the cold going to the house and geyser befor it t,s of to the house and even if the rest of the house water is fine u must ask ur plumber who intalled it if he took the cold water going to the new shower strait of the mains if so he must corect it by t-ing in at the right cold water supply or put a velve on the cold water to ruduse the cold presure . then u will have more hot presure and that means lovely hot shower
plz vote and rate my advice thanx
Jul 17, 2010 | Delta & Single Handle Shower Faucet
Hi,I have a Bathtub Shower Valve that is not working
SHUT OFF THE WATER SUPPLY VALVE BEHIND THE SHOWER.THOSE HANDLES ARE DIFFICULT TO REMOVE,SQUIRT WD-40,LET IT SOAK IN,THEN GIVE IT A LITTLE TAP ON THE HANDLE ,BE CAREFUL NOT TO DAMAGE IT.IF YOU CAN NOT STILL REMOVE THE HANDLE,THEY SELL A HANDLE PULLER,
Apr 20, 2010 | American Standard Home
My shower seems to run even after closing the shower to off position. the water is coming out hot?????? thankyou JOHn Vancouver
REPLACE THE CARTRIDGE. TURN OFF WATER, REMOVE HANDLE AND FACE PLATE. REMOVE TWO SCREWS UNDER PLATE. PULL OUT CARTRIDGE AND INSERT NEW. REASSEMBLE
Jan 06, 2010 | Delta & Single Handle Shower Faucet
The shower control valve for my moen 2995 faucet is stuck in the shower position. how do i remove it?
Turn off water main. remove round cap on face of handle, remove screw and pull handle. After that everything else can be pulled off easily. When you get to the diverter you should be able to why its stuck.
Sep 27, 2009 | Moen 2995 Chateau Three Handle Tub and...
Leaking hot water from delta single handle facuet
I have to assume you've unscrewed the face plate, not removed it, because you can't do that without taking the handle off. Delta handle usually come off by unscrewing an allen (set) screw just under the handle itself. Sometimes these are covered by a plastic plug.
Occasionally, even after you've completely removed the set screw, the handle still won't come off. Wiggling and pulling for a few minutes will generally get it off. If not, then a hacksaw, new handle and new cartridge are the answer.
If the allen screw is stripped and that's why it won't ome off, see above.
Good Luck.
Aug 26, 2009 | Delta & Single Handle Shower Faucet
Water sprays out the diverter
Remove hot/cold button in handle, remove screw/pull off handle. Remove the two screws in the wall plate/remove plate. Use a wrench to remove the diverter assembly. Get new diverter assy and reinstall eveything. You don't need to turn off the water.
Jun 09, 2009 | Delta Faucet #RP320 Divert Assembly
Replaced moen 2225 cartridge leaks when valve is turned on
Yes you remove the clip by pulling up  on it.  make sure water is off.  then you can replace the cartridge by puling it out.  make sure that you put new cartridge back in the same way you took it out there will be a H and a C on the cartridge.
Jun 01, 2009 | Moen Plumbing
Shower handle leak
turn off main water in home . turn on tap some where in home to release presser take shower handle off (screw under cap) unscrew the tap with a wrench unscrew on insides you pull out replace washer put all back togethere
Feb 11, 2009 | American Standard 3275.505.099 Colony Soft...
Delta & Single Handle Shower Faucet  Logo
383 people viewed this question
Top Delta Home Experts
Mike
john h
Tim Whalen
Are you a Delta Home Expert? Answer questions, earn points and help others
