Question about Pentair 15 Hp Superflo Swimming Pool Pump
Can the pump's pressure be turned down? The water come out of the jets really hard and fast and our electric bill has more than doubled since the pool pump was installed. Friends with similar pools noticed the difference in water flow from our pool to theirs. Also, is there a manual on how to perform the regular maintenance? The installation and user's guide we received seems to be missing a lot of info needed for proper maintenance. Thanks.
  • 44 Answers
I think you mean "1.5 Hp" because a "15 Hp" is just crazy, LoL Pumps are matched to each pool when they are built, so there is no need to go to a larger size pump (Higher Hp). If you can't return/swap the pump for the correct hp you had removed, you can have a smaller Impeller installed on the pump.That will reduce the flow,and also use less electricity.As far as maintenance... Clean out the basket from time to time,Lube the lid o-ring with pool lube ONLY, and keep an eye out for leaks.
Posted on Sep 28, 2010
How does a home well water system work?
Deep well.
Pressure valve located on front of above-ground-storage-tank will turn pump on-off depending on amount of water pressure inside tank.
When water is consumed inside home, the pressure valve responds to the lower pressure and closes electrical contacts... sending electricity to water well pump located deep underground.
The pump turns on and lifts water through a pipe into the above ground storage tank.
When the tank is full of water, the pressure valve senses the higher pressure and turns off electricity going to pump
Pump shuts off.
There is a one-way check valve on the water line going down to pump, and this keeps water from flowing back down into well.
The above ground tank maintains water pressure for the house.
When pressure is reduced by taking a shower, the pressure valve turns pump on again, and cycle repeats.
Aug 20, 2014 | Water Heaters
Very low water pressure and excessive pump running
Clean electric switchcontacts with crocus cloth. Adjust higher cut in pressure on this switch.
Apr 12, 2014 | Wayne WATER SYSTEMS SWS50-12P 1/2 HP...
Tank air pressure
Hi Chris...
Normally you set the air first.... but it can be done either way, just be sure that you have about 1/4 of your tank an air cushion, this stops the pump from cycling on and off to fast
Bud
Apr 27, 2013 | Utilitech 20-Gallon Vertical Pressure Tank...
I have a Mastercraft1/2 HP self priming Shallow well jet water pump, the water fell below the intake in my well and I quickly noticed and turned off the pump. We had water delivered and I'm not su
If water is back up above the intake, it should prime itself in a few minutes. As long as you don't let the case get hot to the touch it should be okay to run dry.
If it fails to prime and pump up pressure, you may have to prime it.
Oct 20, 2012 | Plumbing
My jet pump has a 20 - 40 pressure switch but won't give any more than 30 psi. Whats wrong?
There are several causes for this to occur.
1. If it is a 20-40 switch right out of the box it may not be set correctly. I have had this happen. If it builds to 30psi and shuts right off without straining to build to 40psi adjust the Cut-Out pressure up to 40psi. There are two different adjustments on a well switch. One for Cut In / Cut Out psi and one for Cut Out psi.
2. Lack of head pressure being built by the pump can be the cause. This can be attributed to the wrong Jetting in the pump. IE: A shallow well jet/venturi on a deep well.
3. The pump may have a bad impeller, but the pump will generally really strain to build pressure and a bad impeller will be loud, like grinding at times.
4. Double check the pre-set pressure in bladder tank also.
RJ
May 28, 2011 | Fairbanks Ace 1 Horsepower Convertible...
Do I have to hook my tank to draw water from my well?
A bladder tank is designed to give a certain amount of gallons of "draw down" before the pump turns on. The pump will work with or without a bladder tank but will come on every time water is used. Well pumps (Jet or submersible) can run for extended periods of time without causing harm to the pump, but a pump that turns on and off constantly will eventually burn out because it is so hard on the pump.
Jet pumps need to keep "head pressure" to efficiently create the vacuum necessary to draw water from the drop pipe, this is partially what a well tank does.
RJ
Feb 12, 2011 | Flotec Corrosion Resistant Shallow Well...
Top burners are propane. we are used to propane heating really fast. this stove seems really slow. 5minutes to boil litre of water. burners are having hard time lighting.
If it is new fromt the factory, you many have the natural gas (methane) jets in the burners. You will need to check your bag of parts to find the propane parts (LP parts). LP jets allow a different fuel/air mixture to burn at the right heat. Check the owner's manual for details how to make the change.
Please rate me - Good luck.
Nov 20, 2009 | Frigidaire PLCS389DC Dual Fuel (Electric...
Home water pressure
If you had a rapid decrease in water pressure during a dry spell,i would guess that it's your well that's the problem. But far more common is the pump getting clogged with something from down there.
Sep 14, 2009 | Computers & Internet
No pressure showing as jet pump runs
Correct. Either the foot valve, jet valve or leathers. If you pull the well, replace them all, and double the leathers.
Regards, --W/D--
Jul 20, 2009 | Plumbing
Craftsman model 580.752020 electric pressure washer. First time I used it worked for about three minutes then the motor stopped. I cannot get it to start again. Plugged into a 15 amp gfi circuit which did...
turn off water and machine electrics.
remove high pressure hose from front of machine, this may be tight if there is still pressure in the system.
turn on water, when water comes out of machine hose outlet turn on machine. does the machine turn on and water flow increase, if so you probably have a blocked lance jet or trigger.
remove lance extension if fitted and fit hose back to machine, try again. If its ok then this proves you have a blocked lance jet, maybea poke about with some stiff wire will free the obstruction.
If this doesnt bring on the machine you probably have a jammed pressure switch on the pump.
this pressure switch turns on the pump when the trigger is pulled and switches the motor off when the trigger is released.
hope this helps.
Jul 16, 2009 | Electric Garden
Pentair 15 Hp  Superflo Swimming Pool Pump Logo
125 people viewed this question
Top Pentair Pool & Spa Experts
Pj Kiley
Pj Kiley
Level 1 Expert
Jay Finke
Jay Finke
Bill Jordan
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
