Question about LG WM2075C Washer
Need to replace the front gasket... it leaks
  • LG Master
  • 8,220 Answers
You need 2 special tools to remove the clamps. Have you tried to shim the door latch so that it would close tighter? Have you cleaned the weep hole at the base of the gasket?
I have a manual HERE.
Posted on Sep 27, 2010
  • Dan Webster
    Dan Webster Sep 27, 2010
    Your model may only need a flat blade screwdriver to get that gasket off.
Oil leak on driveway coming from front of engine
Dear Sir,
Here is the oil leaking Problem Identifying Technique
Engine oil leaks from the valve cover gasket are common.
  • The intake manifold plenum gasket may leak and cause increased oil consumption/burning and a spark knock during acceleration; the gasket should be replaced.
  • External oil leaks from valve cover gaskets, intake gaskets (front or rear), and the rear crankshaft (rear main) seal area are common. The rear main seal is an unlikely source. Normally, the bearing cap mating surfaces (as well as the sealing surface between the oil pan and bearing cap) are the source for the leaks.
  • Engine oil leaks at the distributor can be misdiagnosed as leaks from theintake manifold seal, oil pan gasket, or rear crankshaft (rear main) seal. A revised distributor is available if oil is found inside the distributor.
  • If the oil filter casing shows signs of distortion from excessive oil pressure, theoil pump should be replaced.
  • Often misdiagnosed as a leaking oil filter gasket, the oil filter adapter can seep from between the adapter and engine block.
  • Carbon buildup on the top of the piston is common. As the buildup increases with mileage and over time, symptoms may vary from light ticking, to ticking/hammering, to hammering/knocking noises. Fuel injector cleaner often solves the problem.
  • I think it helps to analyse u r Problem
    Nov 02, 2012 | Toyota Cars & Trucks
    Door gasket leaking
    My GE washer model wcvh6400j0ww was leaking too. The repair person thought the same thing the gasket. It turned out to be the water in-let pipe (WH41X10118 and you will need seal WH41X10119) and not the gasket. He ordered the gasket and took machine apart to replace and found cracked pipe. Take your machines front off and make sure it is the gasket leaking. Good Luck,
    Jul 20, 2010 | GE WBVH6240F Front Load Washer
    Whirlpool Front Loading Door leaking water
    The most common cause for a front loading washer to leak from the front door is a torn or detached gasket where that gasket attached to the machine.
    Open the door and begin to pull the gasket away from the opening. Look for any problems. If you find a place where the gasket is not firmly secured to the opening, you can list that area up and glue (even with super glue) the gasket back down to the metal opening.
    If you find gasket damage, it will need to be replaced.
    Jan 03, 2010 | Whirlpool Duet Sport HT WFW8400TE Washer
    Oil leaking in engine have replaced seal and O rings but still leaks. I am going to scream!
    ok, There are many areas that the oil could leak from. Head gasket, oil pan gasket, rear main seal, front seal, valve cover gasket. You'll need to locate the leak under the car in order to know which one to replace. There is nothing simple about replacing the rear main seal and although he front seal is easier it can still be a problem. Good Luck.
    Sep 04, 2009 | Ford Escort Cars & Trucks
    Dishwasher is leaking out of the front right bottom corner. It spurts out while it is running. I took the front panel off and could see that where it is coming from but dont know why it is all of a sudden...
    most of the time when it leaks from the front door it is going to be from a corner. most every time the front door gasket is replaced to solve the problem. I have found that the gasket on my dishwasher last about 2 years before needing replaced. I clean the white hard scale that builds up on gasket frequently
    Jun 17, 2009 | Dishwashers
    Need to replace front seal/gasket or something. leaked all fluid
    do yourself a favor bring it to a shop. if you dont line thing up. well let just say your going to have strong legs from walking. i hope this helps
    May 10, 2009 | Ford Bronco Cars & Trucks
    1995 Honda Accord Oil leak from front of engine?
    Just try if you can tighten the 8 bolts and see if there'll be any difference. If not you might need to replace gasket.
    rate this fixya!
    Mar 24, 2009 | 1995 Honda Accord
    Leaking dishwasher
    i had a ge that leaked in front, needed to replace rubber door gasket....
    Nov 09, 2008 | GE Nautilus 24" Built-in Dishwasher
    LG WM2032HW gasket replacement
    I have changed these without disassembling the unit. Just remove the spring from the gasket, then peel back the gasket to remove the inner spring. This is the easy part, getting the inner spring back on is a pain in the neck, but it can be done. The spring will give you problems either way. Good Luck
    Aug 14, 2008 | LG WM1814CW Front Load Washer
    LG WM2075C Washer Logo
    65 people viewed this question
    Top LG Washing Machines Experts
    Dan Webster
    Dan Webster
    Gerry Harvey
    Gerry Harvey
    Are you a LG Washing Machine Expert? Answer questions, earn points and help others
