Question about GE 3.2 Cu. Ft. 8-Cycle Super Capacity Washer - Bisque-on-Bisque
How do you remove the agitator from a ge top load washer?
    Sergeant:
    Champion:
  • 351 Answers
Grab the bottom of the agitator and pull hard be careful not to hit yourself in the face
Posted on Sep 27, 2010
  • 1214 Answers
SOURCE: Agitator is slipping- GE model WJRR4170G top load washer
Starting at the center agitator stem, there should be a cover cap or something that is removed to allow access to the bolt or nut that hold the agitator on.
Reply back what you find and I'll help further.
Posted on Jan 30, 2009
Macintoast
  • 4 Answers
SOURCE: GE washer won't agitate
I had this same problem with our GE top load washer.  I just needed to pull harder.  (Note: The agitator is held in place by about a dozen L-shaped clips in a ring around the agitator's base that will release more as you pull harder on the agitator.)  Everything from the base below the large fins on up comes out together.  Grab the shaft above the fins and pull slowly and hard. I had to take the entire tub out, lay it on the porch, put my feet inside of it, and pull the agitator assembly out.  I wasn't able to pull it out while it was still in the washer.  BE CAREFUL! DON'T **** IT OUT; that might injure your back; just pull out slowly and as hard as you can without hurting yourself.  I was able to get it out successfully, but I am currently stuck at removing the bell below the agitator.  Good luck!
Posted on Feb 28, 2009
  • 56 Answers
SOURCE: GE washer agitates but won't spin
I think you may have a stopped up pump does it drain the water out if not it will not spin. A putty knife inserted 2 inches in from each side will release the spring catches and gently pull on front as you release sprins then look to the bottom right hand side and there is the pump clamp the tub to pump hose or **** water out with a shop vac take off tub to pump hose and then two 3/8 in screws that hold down the pump turn over where you can look in the pump may have an obstruction as always disconnect power before service.
Posted on May 31, 2009
  • 289 Answers
SOURCE: I have a ge profile top load washer. the agitator
if the agitator just spins than you have a bad transmition.
Posted on Dec 29, 2009
  • 153 Answers
SOURCE: How to remove agitator from GE washer? Model WHDRR418G1WW.
The agitator should just pull straight up and out of machine.
Posted on Mar 03, 2010
Gtwn3000mows ge washer need to replace the washer drive block and cant figure out how to remove the agitator from this particular model
On my top-load GE HydroWave washer the agitator just snaps in with a bunch of tooth-like clips in the center of the inside of the agitator. To remove it, grab it on the very bottom of the agitator by hooking your fingers underneath the bottom flange (using two hands evenly spaced) and just lift hard to yank it out. The clips will unsnap and then it just lifts out. Really bad design IMHO but that's how it comes out. I thought I was going to break something doing this but it came right out.
Aug 04, 2013 | GE WBSR3140DW Top Load Washer
How to take out the agitator on ge top load washer
Normally you can remove the top from the agitator, where you would normally put conditioner, and look down the centre of the agitator and should see a retainer of some description that should be able to be undone by hand.
Feb 23, 2012 | GE WBSR3140DW Top Load Washer
Coin stuck in agitator. how is agitator removed
Normally you can take the top of the agitator off with the use of a screw driver or by turning couter clockwise. Once the top is off you should see a nut or bolt. Removing this will allow the agitator to be removed.
Nov 12, 2010 | GE Profile WPRE6100G Top Load Washer
how to remove agitator from GE hydrowave washer machine?
Feb 27, 2010 | GE WBSR3140DW Top Load Washer
Feb 26, 2009 | GE WPRB9220D Top Load Washer
GE topload washer Agitator
theres no nut and bolt,,only a cam or bell ..you have to roch agitator back and forth,,until it losens,,and pull up reall hard..or put your belt under agitator and yank up..onthejob
Jan 23, 2009 | GE WBSR3140DW Top Load Washer
Ge washer
Pull up sharply on the agitator to remove it from the shaft. Check the agitator mounting cup underneath it is probably stripped out. It is a replaceable part.
If the agitator is difficult to pull up,use a old strong leather belt under the agitator and pull it off using the belt.
Jan 11, 2009 | General Electric WHDSR316G Top Load Washer
GE washer WWSR3090T6WW
I DONT KNOW HOW TO REMOVE MY AGITATOR PARTS TO PUT IN THE NYLON COUPLING I GOT THE TOP PART OFF BUT THATS THE ONLY PART COMES OFF
Oct 22, 2007 | GE WDSR2080D Top Load Washer
GE Top Load Washer
There is a plastic coupler piece that goes bad under the agitator. The agitator pulls straight off with a little oooompf. The coupler is bolted to transmission shaft sometimes i have to use a puller to remove coupler as its seized to trans shaft PLEASE rate my help as solved as it darn good
Oct 02, 2007 | Kenmore 24872 Top Load Washer
GE 3.2 Cu. Ft. 8-Cycle Super Capacity Washer - Bisque-on-Bisque Logo
79 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
