Question about Mtd 22" Yard Machine Push Mower
Pull string to start is catching. It is free to pull when out of the mower. As soon *** I put it back in it is stuck. There must be a trick to insert a certain way. HELP! Adrienne
2 Suggested Answers
Just_Bobz
  • 448 Answers
SOURCE: mower will not start. starter is stuck.
Is this solved?
Posted on Jan 10, 2009
Pull string won't recoil on my 10641 lawn boy mower. How do I fix this problem
the spring in the recoil broke. you can buy new Spring or put a hook in the old one so it catches and will then Wind.
May 06, 2015 | Garden
I cant pull the string to start the mower
pull plug out tie up bail handle see if you can turn engine over by hand if you can pull hard on rope it has jamed if not .move check for locked up mover add oil to cylinder for it to turn over till its free my have to take recoil off to do this if the reciol starter pawls or lock in
Aug 30, 2014 | Garden
Pull string
you might have you coil set to close to the flywheel and the coil is not letting the flywheel spin like it is suposto sotheir for you string id to tin\ght when you hace the hood on so reagap the coil and sett it a little farther back from the flywheel by not to far back
May 14, 2013 | Mtd 22" Yard Machine Push Mower
Replacing a pull string on a lawn mower
This can be tricky depending on the brand. Most pull start systems will have 3 or 4 bolts on the fly wheel- puppeteer cover.when you take the cover off, it should all stay together. It will have a plastic wheel inside that the rope winds aroundand in the center of the wheel should have a bolt. Remove the bolt and remove the plastic wheel, but be careful it will have a wind up spring, but most newer models have an enclosed spring.you should see a hole in the side for the pull rope. Insert the rope through the outer sheild first and thenthen in theslot of the wheel(kinda like stringing a yo-yo) then insert the end of the rope on the side of the wheelwheel in the hole, and tie a small tight knot in the rope so it won't slip through.then put the wheel back in the shield, and wind up the rope around the wheel. You should feel the spring tighten up. Don't let go of the spring tensioned wheel and rePlace the center wheel bolt. The handle should sticking out the sheild hole. Now replace the assembly on the mower. Some models you have to wind the spring and hold it tensioned with a wire while you replace the sheild, this tricky. But most wind upwhen you pull the rope out. So when you release the rope the spring will wind it back up. Good luck this task can be tough for first timers.
Jul 31, 2011 | Briggs & Stratton Garden
Echo trimmer srm-230 pull string to start trimmer is stuck. I try pulling on it and it only comes out about an inch.
The pull string is probably tangled up. There are usually vents which enable you to see into the machines pull string assembly. Loosen the fasteners and pull off the cover exposing the pull string. You can unwind and untangle and then it should recoil perfectly. If that does not work continue to dismantle the pull string assembly because you probably have a broken starter pawl which is located on the back of the pull string assembly.
Aug 10, 2010 | Garden
MTD Yard Machine CD000147 6HP 21 inch ..The problem is "Cannot pull the starter string for start. The string or engine stuck to pull the starter. We didn't use it for the whole winter.
The operator presence bail must be in the run position to release the flywheel brake. If you can't pull the rope with the bail in the run position, your rope is fouled. You will have to remove the shroud and take it to a repair shop.
Apr 19, 2010 | Mtd 22" Yard Machine Push Mower
Pull string came off as I was trying to start it.
there should be three or four screws to the top of the mower where the string goes, after purchasing new pull string make sure you wind the spring when you re string, so that when you put the cover back on it will be spring loaded and in proper working condition
Oct 17, 2009 | Ariens Garden
I need to fix athe pull string on my toro push behind mower. it has an 195cc tecumseh motor. the string broke and i can't find anything on toro about how to fix it without buying the whole assembly.
remove bolts from cover and remove the cover. Should be able to access the assembly for the pull rope. Go to a local mower repair shop buy some new line. The old line should just be knotted up on the spring loaded wheel in there. You put a new piece on put in a new knot, put some turns on the assembly to basically wing the spring so it snaps back when pulled, put line through whole and attach to pull handle.
Jul 11, 2009 | Garden
Mtd 22" Yard Machine Push Mower Logo
27 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
