Question about Fargo DTC-300 Thermal Card Printer
Screen reading wrong ribbon - had the same ribbon in it since the last printing.
  • 3 Answers
My DTC300 printer has the same problem.
The ribbon supply roller is driven by a small motor connected via an O-ring belt. The printer rolls the ribbon back and forth to locate the start of each color panel on the ribbon during printing and ribbon detection. Without the O-ring, the ribbon only moves toward the take-up spool, eventually going slack so that the color detector only sees one color - hence the "wrong ribbon" message. In my printer, the slack ribbon also gets chewed up in the print head.
You can order a whole belt kit (~ $20 + shipping) or you can locate a generic O-ring belt (1.8mm x 26mm).
Cheers
Posted on Nov 19, 2010
When i give print ribbon come with paper
sounds like you have the wrong type of ribbon (POOR QUALITY) OR the ribbon could be set up wrong on the printer or you need to reajust the paper and ribbon guides.
Out of interest how old are the ribbons you are using - do you know the manufacturer date? A few years back I had this problem with one of my clients and it turned out that the ribbons had been sititng on the shelf for 4 year! These degrade quickly!
Nov 20, 2011 | Intermec EasyCoder Office Equipment &...
Ribbon on the printer does not go through smoothly
The roller that captures and advances the ribbon is worn. Try a new ribbon. You may be able to find the roller. Good luck with that.
Dec 17, 2017 | Zebra 110XiIIIPlus Label Printer
I have a Monarch Paxar 9416 Printer and can't get it to align correctly to print. It comes out 3/4 of the way and errors out. It won't do the last advance to align correctly.
Sounds like you might either be using the wrong size supplies (wrong length compared to the data going to the printer), or you might not have the correct indexing set on the printer. If you choose a blackmark setting for the index (black mark on the back of the liner so that the printer can detect when to stop), but your printer is set to die cut (no black marks on the liner, only spaces between your labels), then the printer can become confused on where to stop. The same goes for the visa versa of these marks.
Lastly, if you are using a ribbon, or are supposed to use a ribbon, you might find that the printer isn't working because of a ribbon fault.
Just in case neither of these help, what software are you using to make the printer print? Maybe I can help further.
Apr 19, 2010 | Monarch Paxar 9416 Printer
Datacard sp55 printer won't recognize ribbon
PR-01726 Ribbon Out
Out of print ribbon.
Possible Cause 1 : The print ribbon Cartridge is empty.
Solution 1 : Reload the print cartridge. Change the cleaning sleeve and replace the cartridge in the printer. Run a cleaning card as soon as printing is completed.
Possible Cause 2 : The printer ribbon is not loaded correctly.
Soultion 2 :Load the printer ribbon correctly and then close the cover.
Possible Cause 3 : This ribbon has been completely used.
Solution 3 : Use a new roll of ribbon.
Tips for Success
* When this message appears, replace the old ribbon with the new ribbon of the same type. The printer has already prepared the card data for this ribbon type. You can change the colors of monochrome ribbon (such as from dark blue to gold).
* If you must change the type of ribbon (such as (YMCKT to KT) when this message appears, install the new ribbon, cancel any cards waiting to print, and change the ribbon type settings. Finally, return to the card creation program to send the card data to print.
* If the ribbon was repaired, the wrong take-up spool was used. Repair the ribbon again, using the correct take-up spool.
If you cannot fix the problem contact your service provider for assistance.
FTB
Nov 23, 2009 | Datacard Group SP55 Card Printer
Oki ml521 printing problem
There's a small metal spindle that turns the ribbon when the carriage moves. It sticks up out of the plastic bit where you put the ribbon. These can break so the ribbon doesn't turn so it prints in one patch of the ribbon so it wears it out quickly
Oct 06, 2009 | Office Equipment & Supplies
Attempting to print labels from a Monarch 9855 printer and receiving error message: "Print Head error 768." Printer was working fine as of last Friday. We have other Monarch 9855 printers that are on other...
the problem is your printhead is bad . do a print test by presing both arrow buttons at tah esame time for two seconds, look fo rthe line that reads bad dots. if the value i sgreater than 000 yu have a bad printhead
jay
Jun 08, 2009 | Monarch Paxar? 9855 Label Printer
I have a 7 year old Lexmark 2381plus dot matrix printer. Recently, the print on the last page of the 3 part form has become very hard to read (very light). I changed the ribbon and have the form setting...
Hi and welcome to FixYa,
It would seem you posted twice.
Based on your description, the printer is working, it is not a form issue, the printer head is good, an adjustment might be needed and it works, there is no reason to replace the Lexmark 2381plus printer even if it is 7 years old (not unless you would want to).
To the faint printing on the last of the 3 pages:
  • the take-up spool/wheel drawing the ribbon is not working (most likely). The ribbon is not moving hence the printer head is not striking fresh ribbon area. Check the ribbon cartridge, it may be stuck or the driving spindle where the ribbon's take-up spool/wheel locks into. It may need a bit of cleaning and/or lubrication;
  • the printer head is slightly adjusted away from the paper. Normally, there is a mechanical lever/adjustment that sets how many paper & duplicates are fed. Adjust for 1 only.
Good luck and thank you for using FixYa.
Jan 30, 2009 | Lexmark 2381 Plus Matrix Printer
Can hardly read print after putting on new ribbon
You have to make a platen adjustment (on the left side move it back).
Jan 23, 2009 | IBM 4247 A00 Matrix Printer
Not printing
this problem will address on label and ribbon issue. you must establish your printer set-up first, meaning see to it that the label and ribbon was correctly loaded, if still problem occur try using manual calibration you can see how to do at the manuals you have..
Jul 29, 2008 | Zebra Stripe S600 Thermal Label Printer
Oki 320 Turbo -- Unclear characters in output
If it is not the ribbon, you may have to replace the print head.
Genuine Okidata Print Head
Mfr Part #:
50063802
Hope that helps...
Jun 21, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
Fargo DTC-300 Thermal Card Printer Logo
432 people viewed this question
Top Fargo Office Equipment & Supplies Experts
Safe-Card ID...
Are you a Fargo Office Equipment and Supply Expert? Answer questions, earn points and help others
