Question about Kenmore Dryers
Heater will run but not heat up. Replaced the heating element, still not heating up.
  • Kenmore Master
  • 43,501 Answers
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Sep 27, 2010
How do i fix my stiebel eltron tankless electric water heater?It stop working..
Th easy fix would be installing a new heating element that has burned out. You don't say what size this tankless heater but if it stopped working entirely you might have just one heating element inside. You can test it by (1) turning off the circuit serving the heater, disconnecting one of the wires to the heating element, then taking an ohmmeter to see what the resistance of the element is. If it is "infinity" then it is open and burned out. Replace element. If it is around 6 ohms (for a 10kW heater running at 240V) then the heating element is OK. Unfortunately those heating elements don't last forever. Check the repair manual on how to replace the heating element.
Dec 07, 2014 | Stiebel Eltron DHC Instant Tankless...
Power tripping
the heating element is drawing a load when it shouldnt be. Make sure when u replaced the heat element that it isnt touching the metal tubing inside. Could possibly be a fault in the heating relay inside the circuit board
Mar 16, 2014 | Balboa Instruments Pool & Spa
Replaced thermostat and heating eliment still not heating up dryer runs and blows ari just not heating up.
ALWAYS UNPLUG DRYER BEFORE CHECKING
1.loose wiring---check terminals & wiring
2.defective centrifugal switch in motor---replace switch (check linkage to motor
3.defective timer---replace timer
4.open heater element---replace heater element
Jul 31, 2010 | Whirlpool Dryers
Dryer runs too hot.
Remove power from the unit. You want to use a multi-meter set on an ohms scale. Remove the wires from each terminal at the heating element. Check resistance to ground at the heater by putting one meter lead to the case of the heater, and the other meter lead to each terminal at the heater. It sounds as though your element has gone bad and is shorted to the case. The resistance should be infinite. If you read any resistance from the element to the case, replace the heating element. The no heat setting should be exactly that....no heat.
May 22, 2009 | Dryers
Maytag dryer: pye2300ayw
yes, it will. you should be able to take off the panel on the bottom of the front of the dryer. way in the back is the heating element. do not put your hands in there with the power on, but start the dryer and look in there and you will see if the heating element comes on. it will be like looking inside your toaster.
Oct 27, 2008 | Maytag PYE2300AY Electric Dryer
Kenmore gas dryer 110.97566200 gas dryer is running throught the cycle but no heat.
Your Heating Elements could have problemA dryer sometimes won't heat or heats too slowly because of a variety of reasons. By following the guidelines below, you can inspect the heating elements on a gas or electric dryer to pinpoint the source of the problem.
Troubleshooting the Gas Heater
In a gas dryer, heat is provided by a gas heater that is controlled by an air shutter. The gas heater is generally the source of no-heat or drying problems. You can often correct such problems by adjusting the air shutter on the gas burner, which is located along the bottom of the dryer.
To adjust the shutter, take out the screws and remove the panel that covers the gas flame. Turn on the dryer so the flame is burning. If the flame has a deep blue color and you hear air whistling around the burner, the air/gas mixture is receiving too much air. If the flame has a yellow tip, the mixture is not receiving enough air. Turn the thumbscrew or loosen the two screws slightly to increase or decrease the flow of air to the burner. Keep turning until the flame is a light blue color, without any yellow, and the whistling stops.
Gas dryers use an electric ignition device rather than a pilot light to light the gas heater: An element becomes hot and glows like the filament in a lightbulb. Electric ignition systems are always sealed; you can't adjust or repair them. If an electric ignition device fails, call a professional service person for replacement.
©2006 Publications International, Ltd.
In a gas dryer, heat is provided by a gas heater, controlled by an air shutter.
Electric dryers have self-contained electric heating elements.
Servicing the Electric Heating Elements
Electric heating elements, found in electric dryers, are self-contained units located in the back of the dryer. A defective heating element is frequently the source of no-heat or drying problems. Remove the back service panel to gain access to the elements.
The heating elements are located inside the heater ducts. If you think a heating element is faulty, test it with a volt-ohm-milliammeter (VOM) set to the RX1 scale. Disconnect the leads from the power terminals and clip one probe of the VOM to each terminal. The meter should read about 12 ohms. If the reading is higher than 20 ohms, the heater is faulty and should be replaced. Replace a faulty heater with a new one of the same type and electrical rating. A heater connected to a 115-volt line usually has an 8.4-ohm resistance; a heater connected to a 220-volt line usually has 11 ohms resistance.
The heater may also malfunction because it's grounded. To test for this, set the VOM to the RX1 scale and remove the leads to the heater. Clip one probe of the VOM to a heater terminal and touch the other probe to the heater housing. The meter needle should jump to a fairly high reading. If the needle flicks back and forth at a low reading, the heater is probably grounded and should be replaced. Here's how to replace the heater:
Step 1: Remove the back of the dryer. If necessary, also remove the cabinet top.
Step 2: Disconnect the leads and remove the screws that hold the duct in position. Then lift the entire heater unit out of the dryer.
Step 3: Remove the screws that hold the heating element in the duct.
Step 4: Slip the new heating element into the heating duct the same way the old one came out. Be careful not to damage the resistance coils. Replace the screws that hold the heating element in the duct, reconnect the leads, and screw the unit back into position
Aug 04, 2008 | Kenmore 63942 Dryer
Replaced cut-out and limit switches and still no heat?
this is one of only a few models with an electronic control board behind the contol panel nex to timer, is your power checks good, and all fuses nad thermos and heater have continuity as well i would look there, nice when theres an obvious blow out on the board but not always the case, it reails for about $60 part num,w10116566
Feb 27, 2008 | Whirlpool GEW9878LW Electric Dryer
Heater element problems
Why did you decided that it is an heating element problem,it could be a thermostat issue as well. Check with a multi-meter whether you have power on the heating element tags. In case you have power on its tags, the heating element should be replaced.But in case you can't read any power on its tags, it's probably a thermostat issue. Good luck!
Sep 10, 2007 | Hoover 24 in. DT999 Free-Standing...
No Heat
more than likely that u have blown heater element u can test your element with a power cord connect it to the live earth and neutral and plug it in and element should heat up if not it will be your element that has blown
Dec 29, 2006 | Hotpoint TDC32 Electric Dryer
Dryers Logo
137 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
