Question about Moultrie Feeders 6 Volt Rechargeable Battery Cameras Electronics Instruments (MFHRB6)
How do I test the Moultrie photocell controlled timer ( the one with 4 dip switches? I want to be sure it will run when the sun comes up and sets.
Where can I get a dusk till dawn timer master plug did one that I wanted a TDD-MP but cannot get them anywhere so now looking for a Paget dtd timer where can k get one
  • No Paget, but lots of others
  • DUSK TILL DAWN LAMP TIMER - Nexus Industries www.nexusinds.com/masterplug/downloads/pdf/TDD.pdf · PDF file DUSK TILL DAWN LAMP TIMER SWITCHING MODES i) Timer mode ii) Random mode iii) On mode iv) Off mode v) Dusk 'Til' Dawn mode i). Timer Mode The timer will turn ...
  • Dusk to Dawn Timer ' eBay > www.ebay.com/bhp/dusk-to-dawn-timer Find great deals on eBay for Dusk to Dawn Timer in Light Timers. Shop with confidence.
  • images of dusk till dawn timer bing.com/images b3eo0&w=105&h=105&c=7&rs=1&qlt=90&pid=3.1&rm=2">551o0&w=60&h=105&c=7&rs=1&qlt=90&pid=3.1&rm=2">6f9o1&w=72&h=105&c=7&rs=1&qlt=90&pid=3.1&rm=2">595o0&w=99&h=105&c=7&rs=1&qlt=90&pid=3.1&rm=2">773o0&w=107&h=105&c=7&rs=1&qlt=90&pid=3.1&rm=2">fcfH0&w=72&h=105&c=7&rs=1&qlt=90&pid=3.1&rm=2"> See more images of dusk till dawn timer
  • Dusk to Dawn Photocell Sensor Timer Switches 10.02 www.acetek.co.uk/id66.html Acetek manufacture Dusk to till dawn photocell timer light sensitive sensor switches for energy saving lamps LED 6v 12v 24v and 240vAC
  • Dusk Till Dawn' Self-Dimming Lighting. - D-D The ... www.theaquariumsolution.com/files/Dusk Till Dawn Instructions... · PDF file 3 Step 4 - Synchronising Programme with the Plug Timer It is necessary to synchronise the Dusk till Dawn chip to the time of day during which the unit has been ...
  • Amazon.com: dusk to dawn timer www.amazon.com > Search > dusk to dawn timer Amazon.com: dusk to dawn timer. Amazon Try Prime All Go. Shop by Department. Hello. Sign in Your Account Sign in ... after 2,5 or 8 hours / Dusk to Dawn default timer
  • Items found similar to "DUSK TILL DAWN PHOTOCELL ... - eBay www.ebay.ca/sch/sis.html?_nkw=DUSK+TILL+DAWN+PHOTOCELL+SENSOR... Photocell Timer light Switch Daylight Dusk till Dawn Sensor Light switch G8. ... 5 Pcs Dusk To Dawn Photocell Light Control Auto Sensor Light socket Black.
  • Amazon.co.uk: dusk to dawn timer www.amazon.co.uk > Search > dusk to dawn timer Amazon.co.uk: dusk to dawn timer. Amazon.co.uk Try Prime All ... Battery Operated Fibre Optic Snowman, Built in dusk till dawn light sensor. Kitchen & Home: ...
  • Feb 05, 2016 | Hardware & Accessories
    How to set legrand timer switch 12 hours model # 037-55 microrex qw31
    QW31 is 7-day analog timer, 230 Volt
    http://waterheatertimer.org/How-to-set-timers.html
    If there is a photocell override, then it will be wired into terminals U1 and 4, and will not be part of the timer setting
    Gene
    Water Heater Timers Save Money
    Oct 15, 2014 | Legrand Ivory Universal Timer Controlled...
    My son bought a new house. It has an Intermatic K4221 photo cell that never appears to work. It looks like it is connected to porch lights. They won't come on either by photocell or manual light switch. He...
    Place tape over photocell lens, and flash switch off-on. Did the light come on?If you know how - remove the photocell from the circuit and see if the light works. If the light works, then the photocell is probably bad. Check power from switch to photocell with test meter.
    May 17, 2014 | Intermatic K4221C Photo Cell Control 120 V...
    How wiring intermatic timer t51211bc i have one circuit control by timer ....and one circuit contro by photocel indor lite and outdoor lite
    T51211BC is 120Volt timer that can be wired many different ways because there are two internal relays, and each relay has NO and NC terminals. One relay is controlled by timer dial trippers, and other relay controlled by dawn-dusk photo eye
    Timer wiring cannot be fully explained with words.
    Below is basic hook-up for your 120Volt wiring application, and then you can use a tester and experiment with the knob settings, and tripper settings.
    http://www.intermatic.com/products/ec%204%20layer/mechanical%20time%20switches/24%20hour%207%20day/t50000%20series%207-day%20time%20switch.aspx
    1) You have 4 cables:
    one cable from circuit breaker box;
    one cable going to photo control;
    one cable going to outdoor Load (lite);
    one cable going to indoor Load (lite).
    2) Cable from circuit breaker has 2 wires:
    Black Hot wire connects to terminal 1
    White Neutral connects to terminal 2
    This will power the clock motor and timer relays.
    3) Photocell has 3 wires:
    Black connects to terminal 1
    White to terminal 2
    Red to terminal 3.
    Photocell turns relay on-off for Circuit B
    Do not mix different size wires under same screw terminal, or smaller wire will come loose over time. Also do not mix stranded wire and solid copper under same screw terminal for same reason.
    4) Terminals 4 thru 12 are 'dry'.
    Dry terminals receive no power when power is applied to terminals 1 and 2.
    To put power on dry terminals, so that Load will have power, attach Black hot wire from breaker to terminals 9 and 12.
    So add a jumper wire from terminal 1 to terminal 9 and another jumper wire from terminal 9 to terminal 12.
    120Volt power is now connected to terminals 1, 9 and 12
    5) Circuit B is dawn to dusk for outdoor Load.
    Outdoor load cable has Black and White wire.
    Connect outdoor Black wire to either terminal 10 or 11.
    To test which is correct for your application, set switch to Auto, and then test across terminals 12 and 11, and across terminal 12 and 10. Repeat test after dark. Rotate knob B to each position and repeat test.
    Connect outdoor White wire to terminal 2, and this will complete the circuit.
    6) Circuit A is Dusk ON and timer OFF
    Indoor cable has Black and White wire.
    Connect indoor Black wire to either terminal 7 or 8.
    To test which is correct for application, set switch to Auto, and then test across terminals 9 and 8, and across terminal 9 and 7. Repeat test after dark. Rotate knob B and repeat test.
    Aug 04, 2011 | Day-Timer Intermatic T51211BC 7-Day Dial...
    Friend left RCT100 timer programmed, it comes on the time programmed, but it goes off much earlier than it is supposed to. How can I correct this?
    Most digital timer problems can be solved by resetting timer.
    Open following link for possible instruction manual with troubleshoot steps
    http://waterheatertimer.org/UPM-timers-and-manuals.html#Garrison
    Check the following:
    Program disable feature is not enabled.
    Check 2 different sets of batteries: 1 set AA for transmitter, and 1 set button-cell batteries on back of timer
    Choose between 4 different functions: programmable, photocell, countdown, or random
    Using programmable mode: make sure there are no programming conflicts
    Jul 20, 2011 | UPM Remote Control Timer Set
    I have a ge timer 15132 and it is wired up properly feed to screw 1 and 2 , jumper from hot to com, load to no contact and the neutral tied with the other from the feed, all the time are set proper and the...
    I have tested this timer.
    GE 15132 timer can be wired muliple ways to accommodate different voltages and many different timing needs.
    http://waterheatertimer.org/How-to-wire-GE-15132-timer.html
    1) First thing is you must set dip switches BEFORE applying power.
    Timer arrives pre-set for 277Volts.
    For 120V, set all 4 dip switches to the left, or ON.
    2) Otherwise your wiring sounds correct.
    Hot black wire to far left 'clock' terminal.
    Neutral white wire to next 'clock' terminal.
    Jumper from Hot terminal to COM terminal.
    Black Load wire on NO terminal.
    White Load wire to same 'clock' terminal as Neutral
    3) Possible solution:
    Move wires to COM2 and NO2 and see if that relay is working.
    4) Make sure your programming does not have conflicts.
    See if manual override is working.
    Test for voltage across 'clock' terminals
    Move manual override and watch if relay clicks open-closed.
    Check that Load is operable by moving NO wire to COM terminal.
    5) If timer is not functioning, exchange at Home Depot.
    You can switch out mechanism without replacing box.
    Mechanism is held with hex screws.
    Add a comment for more free help.
    Also take advantage of fixya expert assistance live.
    For a price, expert works with you while you work on timer or any do-it-yourself project.
    Fixya is always less expensive than a service call.
    Mar 22, 2011 | General Electric GE 24-Hour Timer, 2-Pin...
    Wireing diagram do not no were thay go three wires
    K4221C photo cell page at Intermatic:
    http://www.intermatic.com/products/photo%20controls/commercial%20%20industrial/stem%20%20swivel%20mount%20-%20thermal%20type.aspx
    Photocell has black, white and red wires on photocell.
    Black goes to Hot from breaker.
    White goes to Neutral from breaker box
    Red goes to Load (light)
    Electricians don't guess, they test.
    You should have one wire coming from breaker box, and another set of wires going to light.
    Separate wires for testing.
    Since you are outdoors, stand on dry boards and tape tester leads to wood sticks to keep hands away from power.
    Turn power ON
    Test each wire to bare ground wire.
    Tester lights up on hot wire. This wire should be black.
    Hot wire connects to photocell black
    Hot is identified.
    Test Hot wire to all wires except bare ground.
    Tester lights up on neutral. This wire should be white.
    Neutral wire connects to photocell white
    Now the other cable goes to Load. This cable has a black and white wire.
    Connect photocell red to black Load wire
    Connect white Load wire to Neutral, along with photocell white.
    Ground wires are twisted together.
    Also take advantage of fixya phone service.
    For a price, expert speaks with you over phone while you work on any do-it-yourself project.
    Jan 11, 2011 | Intermatic K4221C Photo Cell Control 120 V...
    Lights do not come on at all. Breaker is not tripped. How do I test photocell?
    to test the photocell you will need a tester, a basic pen tester will do fine, you just need to make sure that power is going where it needs to, when it needs to. first you will need to identify the feed with the tester, this is the wire that should have power to it as long as the breaker is on. once you know which is the feed, the other should be your switch leg. after you have identified the switch leg, cover the eye of the photocell, it may take a few minutes before the switch activates, I would wait up to 5 min. but no longer than that, if you are not getting power past the photocell at this point, then it is most likely bad.
    Feb 24, 2010 | Intermatic K4221C Photo Cell Control 120 V...
    A t104 intermatic turns on and off sporadically
    Replace the trip levers, I dont think your timer turns off and on without trip levers? Unless your outdoor fixtures have photo cells on them or wired to them! Are they coming on at night and shutting off at Daylight, if so they are connected to a photocell or have internal photocells which means you don't need the timer unless you want to control different on off times.
    Dec 21, 2008 | Intermatic T104 24h 208-277v Mechanical...
    Moultrie Feeders 6 Volt Rechargeable Battery  Cameras  Electronics  Instruments (MFHRB6) Logo
    184 people viewed this question
    Top Moultrie Cameras Experts
    Steve
    AZBen
    AZBen
    Are you a Moultrie Camera Expert? Answer questions, earn points and help others
