Cycraft simulator no movement on capsule also error fffe mcu error thanks
What is error code H4-00
From the manual -
Entering the simulation mode
1) #/P key (program) ON ? Asterisk (*) key ON ? CLEAR key ON ?
Asterisk (*) key ON ? Ready for input of a main code of simulation
H4 00 Content Main heater lamp abnormally low
temperature detection
Details The setup temperature (about 90°C) is not
reached within the specified time (about
17sec) from turning on the power ON SW.
(When the temperature of main heater
lamp thermistor falls below 140°C in the
standby mode or printing.)
Whether temperature of main heater lamp
thermistor falls below 50°C in the pre-heat
mode.
Cause Main heater lamp thermistor defect
Main heater lamp failure
Main thermostat failure
Control PWB failure
Check
and
remedy
Check the heater lamp blinking with SIM 5-
2.
When the lamp blinks normally:
Check the thermistor and the harness.
Check the MCU PWB thermistor input
circuit.
When the lamp does not light:
Check for disconnection of the heater
lamp and thermostat.
Check the interlock switch.
Check the power PWB and the MCU PWB
lamp control circuit.
Clear the display of self-diagnostics with
SIM 14. Online Virus Removal 39 99 Online Virus Removal and Online PC Help
Dec 19, 2014 | Toshiba e-Studio 350 Copier
Error F2 on Sharp AR5516
CRUM data read trouble
Replace the toner cartridge.
Replace MCU PWB.
Replace MCU PWB EEPROM
Check and fix connection between
CRUM (toner cartridge) and MCU
PWB.
May 09, 2014 | Sharp Office Equipment & Supplies
Error h4-00 code on AR- 5127. please what can i do to reset it. Thanks. It also says call for service even though the machine is new.
this error occures if:
The setup temperature (about 90°C) is not reached within the specified time (about 17sec) from turning on the power.
When the temperature of main heater lamp thermistor falls below 140°C in the standby mode or printing.
When the temperature of main heater lamp thermistor falls below 50°C in the pre-heat mode.
AS POSSIBLE CAUSE:
Control PWB failure
Check the heater lamp blinking with SIM 52.
circuit.
If lamp lights and stays lit:
Check for disconnection of the heater lamp
and thermostat.
Check the power circuit and the lamp
control circuit on MCU PWB.
SIM 14.
To clear, enter sim mode:
2) Entering a main code with the 14-key ? START key ON
3) Entering a sub code with the 0-key ? START key ON
4) Select an item with the scroll key and the item key.
5) The machine enters the mode corresponding to the selected item.
Press START key to start the simulation operation.
To cancel the current simulation mode or to change the main code
and the sub code, press the CUSTOM SETTINGS key.
* Canceling the simulation mode to return to the normal mode
1) Press CLEAR ALL key
if clear with sim 14-0 doesn't helps, choose sim 52 to check the lamp, or call service!
Sep 13, 2011 | Office Equipment & Supplies
I have sharp copier ar-m205 it makes l4 error when start booting , what the problem ? i tried to change main motor and MCU but does not fix thank you for help
1 ) First u check it the main motor running or not. Go to simulation mode i mean put this code, press # key then Press INTERUPT key then C key then again INTERUPT. It should put it very fast, now the dispay shows blank then press 25 and START key and then press 1 key then again 1 . now check the main motor run it or not. A good condition main motor will work it when we put this simulation.
2 ) Check the Main motor cable, its conncted to mother board so removed very carefully. The both side ends should not bend or any other damages,then the cable is good. other wise u can change the cable also.then also it will work
3 ) Now also not solve the problem u remove the main motor and change new one.
4 ) Dont change the MCU.L4 is mainly problem due to the main motor
Jul 05, 2011 | Sharp AR-M205 Copier
We have a Sharp AR 207 and are getting an error message of U 2. How do we fix it. Do not have a manual.
U2
Content EEPROM serial communication
error
Detail-
Error in communication with
EEPROM
Cause
EEPROM failure
Installation of uninitialized EEPROM
MCU PWB EERPOM access
circuit failure
Check and
remedy-
Check that the EEPROM is
properly set.
To prevent against loss of
counter/adjustment values, record
the values with simulation.
U2 trouble cancel with SIM 16
MCU PWB replacement
Mar 05, 2010 | Sharp Office Equipment & Supplies
F07-AWM 9000
The F07 indicates a Motor Control Unit (MCU) Error.
  1. Disconnect mains power and unplug unit.
  2. Check wire harness connections between the Drive Motor and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
  3. Check the MCU
  4. Check the Drive Motor
  5. Check the Wire Harness
  6. Reconnect power and plug unit in.
  7. Check the MCU operation by looking for movement of the drive motor, and check drive motor for fully powered rotation.
  8. Replace failed component. Note: If this failure occurs during high-speed spin, the door will be unlocked after three minutes.
Select PAUSE/CANCEL twice to cancel the cycle.
Select DRAIN/SPIN if there is excessive water in the washer.
Re select cycle and select HOLD TO START.
Oct 26, 2009 | Whirlpool AWM9000 Front Load Washer
Error code
fuser has oevr heated - needs resestting or replacing
Mar 29, 2009 | Sharp AR-5316 Advanced Digital Imager...
ESky Simulator FMS (0905A) doesn't work
When I re-started my computer and calibrated the simulator again, it started to work. As simple as that.
Thanks for your help.
Zlatko
Feb 12, 2009 | E Sky Flight Simulator Training Kit
F 19 error on Whirlpool AWM 8085
F15 - Motor Control Unit (MCU) Error - Disconnect power and unplug unit to check wire harness connections to the motor, MCU, and Central Control Unit (CCU).
Check the drive belt and reconnect power and plug unit in.
Check the MCU by looking for operations of the drive motor and check the drive motor for powered rotations.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Dec 01, 2008 | Whirlpool AWM8163 Front Load Washer
Computers & Internet Logo
71 people viewed this question
David Payne
David Payne
