Question about Brother HL-2070N Laser Printer
When attempting to print, the printer window gives me the message Back Cover is Open Checked the back, opened it, removed the paper that was stuck on the roller and tried again. Same message comes up. What do you suggest?
    Scholar:
  • 107 Answers
Hello, when you are looking at the back end of printer, open up cover, the cover will open and stop, look further in and you will a black guide, or black plastic, open that up, if it does not open on its own, there is a piece of plastic that might look like a stick, sometimes this will get stuck, use a flashlight, and you will see haw this thing works, if it does not move freely, it will trigger rear door open, be carefull with this piece of plastic, it does break. again it will trigger an open rear door error.
Posted on Sep 27, 2010
  • fightthefud Jan 13, 2011
    I take that back, this was very helpful!!!! The "stick" mentioned in the tip looks a bit like an "L" when you access the second cover, the longest portion of this stick is connected into the righthand side of the printer if you were looking directly at it. BTW, the second cover is technically called the "rear chute cover" in the printer manual. There is a short "branch" coming off of the longer portion of the stick. When clearing my paper jam, this must have gotten stuck - it's supposed to fit into a slot molded into the rear chute cover for it. I tried moving the branch into the slot and it felt like something snapped back into place. Just be careful not to break the stick, or then you'll really be SOL. All of this talk of sticks and slots might sound a bit dirty, but it really did fix the problem. Thanks!!!!
Printer eror code U051
Instructions
    • 1
      Press down and hold the "On/Off" button, which is located on the printer's operator panel, for one second. Wait 15 seconds and then tap the button again. Attempt to print or scan a document.
    • 2
      Check the paper feed tray on the front end of the Canon MX700 to see if there is any paper visibly stuck inside the printer. Open the printer cover by gripping the front edge of the printer and lifting upwards.
    • 3
      Grab the edge of the jammed paper and gently pull towards you to remove the paper from the paper feeder. Unplug the Canon's power cable and USB cable, and then turn the printer around.
    • 4
      Pull off the rear plastic cover tab and check if there is any visible paper jam. Grab the edge of the paper and gently pull toward you until the paper is removed.
    • 5
      Push the rear plastic cover tab back into place, and reconnect the power cable and USB cable. Attempt to print or scan another document to see if the error is resolved.
    • 6
      Lift open the printer's cover again and wait for the ink carriage to slide into view. Press the "Push" button on the front of the first ink tank. Pull the tank out and then push it back into place to ensure it is properly seated.
    • 7
      Repeat the process with the other three ink tanks, and then close the printer's cover. Power the printer off and then back on again.
Mar 07, 2012 | Canon MX700 Office All-In-One InkJet...
Code error 5100
  • 1.
  • Press down and hold the "On/Off" button, which is located on the printer's operator panel, for one second. Wait 15 seconds and then tap the button again. Attempt to print or scan a document.
  • 2 Check the paper feed tray on the front end of the Canon MX700 to see if there is any paper visibly stuck inside the printer. Open the printer cover by gripping the front edge of the printer and lifting upwards.
  • 3 Grab the edge of the jammed paper and gently pull towards you to remove the paper from the paper feeder. Unplug the Canon's power cable and USB cable, and then turn the printer around.
  • 4 Pull off the rear plastic cover tab and check if there is any visible paper jam. Grab the edge of the paper and gently pull toward you until the paper is removed.
  • 5 Push the rear plastic cover tab back into place, and reconnect the power cable and USB cable. Attempt to print or scan another document to see if the error is resolved.
  • 6 Lift open the printer's cover again and wait for the ink carriage to slide into view. Press the "Push" button on the front of the first ink tank. Pull the tank out and then push it back into place to ensure it is properly seated.
  • 7 Repeat the process with the other three ink tanks, and then close the printer's cover. Power the printer off and then back on again.
May 20, 2011 | Canon Office Equipment & Supplies
First of all I have a paper jam, one sheet got stuck after I tried to make a copy. Since then every time I turn on the printer it won't print or copy, of course the sheet is still stuck. I get the message:...
hello
first open the front cover remove the toner of the printer and remove the paper jam, and turn off the printer, unplug the power plug from wall outlet and at the back of the printer and after 2 minutes plug it back and turn on.
thank you
Mar 07, 2011 | Office Equipment & Supplies
Message says no paper in front tray. Paper is where I've always put it in back. Won't print.
go print -> properties -> page setup -> print options -> tick Disable the paper source setting of the application software -> hit ok and go back to "main" -> select the paper source that you want and hit ok ok and print
Nov 20, 2010 | Canon PIXMA MX700 All-In-One InkJet...
I received error code 5100.
  • Check the paper feed tray on the front end of the Canon to see if there is any paper visibly stuck inside the printer. Open the printer cover by gripping the front edge of the printer and lifting upwards.
  • Grab the edge of the jammed paper and gently pull towards you to remove the paper from the paper feeder. Unplug the Canon's power cable and USB cable, and then turn the printer around.
  • Pull off the rear plastic cover tab and check if there is any visible paper jam. Grab the edge of the paper and gently pull toward you until the paper is removed.
  • Push the rear plastic cover tab back into place, and reconnect the power cable and USB cable. Attempt to print or scan another document to see if the error is resolved.
  • Lift open the printer's cover again and wait for the ink carriage to slide into view. Press the "Push" button on the front of the first ink tank. Pull the tank out and then push it back into place to ensure it is properly seated
  • Repeat the process with the other three ink tanks, and then close the printer's cover. Power the printer off and then back on again
  • Oct 11, 2010 | Canon Office Equipment & Supplies
    When printing i get the paper jam message have checked for paper jam but dont see anything
    Open the cover on the back of the printer sometimes paper is stuck in there and thats why you can't see it.
    Sep 29, 2010 | Dell 1700n Laser Printer
    General error Delete all print jobs and turn the printer off. Remove any foreign objects from inside the printer. After a few minutes%2C turn the printer back on.
    general error Delete all print jobs and turn the printer off. Remove any foreign objects from inside the printer. After a few minutes%2C turn the printer back on.
    Nov 24, 2009 | Epson Stylus Photo R300 InkJet Printer
    Epson R320 "General Error" message - unable to clear
    If you are getting a 'carriage jam' error as soon as you turn on your Epson printer with no tasks in progress, then check for any piece of paper stuck in the carriage. Remove the paper carefully. If the paper tears, part of it might remain inside the paper path and damage the product.
    Fix 'Carriage Jam' : Open Door, clear carriage jam,
    and then press OK to continue' error message
    Turn off the printer and open it to see where the paper is stuck.
    Manually move the carriage toward the opposite side.
    Check the paper path and remove any piece of paper or any other object that is stuck in the path.
    Reconnect the power cord and turn on the printer.
    http://www.fixya.com/support/t5192341-epson_photo_1400_paper_feed_ink
    Feb 22, 2009 | Epson Stylus Photo R320 InkJet Printer
    Brother HL-2070N Laser Printer Logo
    733 people viewed this question
    James Cagle
    James Cagle
    Samyfam
    Samyfam
    Victorman
    Victorman
