Question about HP Pavilion dv4000 Notebook
I have an intermittent chirping sound coming from my hp pavillion laptop. What's causing this?
  • 212 Answers
There are only two kinds of moving parts in a computer that may cause a chirping noise:
- the hard disk: you better make a backup of critical data on your hard drive
- the fan: less critical since the data on your disk is not affected in case of a break-down, but annoying nonetheless. attention: a broken fan may cause the CPU to overheat. in general the pc turns itself off in case of overheating, but if it doesn't, the CPU may be damaged severely.
Posted on Sep 27, 2010
I also have this intermittent "chirp" sound that randomly emits from the left side of my HP Pavilion DV7.
I recently applied this mute all microphones fix, and so far the problem has been solved.
http://forum.notebookreview.com/6347979-post1478.html
Posted on Dec 02, 2011
Hp pavillion dv6 on but dark screen
sounds like the black screen of death
a lot of dv hp laptop have this problem the gpu has to reflowed are your keys also blinking. if they are count the number of blinks it will point to problem
HP DV7 Laptop Graphics Fix Black Screen of Death
would not fix it his way
Jul 04, 2015 | HP Pavillion DV6-1355DX Notebook PC -...
My hp pavillion goes to black screen (no signal) intermittently and emit a beep tone
The video graphics card is one of the main problems with the HP line, it gets to hot causing the solder to break down. But I would test with a monitor on the video output to be sure.
Jun 26, 2012 | HP Computers & Internet
HP Pavillion Laptop 1/3 Bottom Screen intermittently inaccessible
Sub out the ram memory one at a time and to see if this will make the difference.
Apr 22, 2012 | HP Computers & Internet
There is no sound coming out of my hp pavillion dv4 1118ca
check the sound icon bottom right corner right click on it to adjust volume or to untick mute if this does not work you might not have a sound driver loaded.type in your comp details and download sound driver from internet.
hope this helps.
Apr 28, 2010 | Computers & Internet
MY HP PAVILLION DV 1000 HAS NO SOUND DEVICE NOW
Below is a link to download the sound drivers for your laptop. Download, install and reboot and everything shoud be fine.
ftp://ftp.hp.com/pub/softpaq/sp28001-28500/sp28481.exe
Jan 22, 2010 | HP Pavilion dv1000 Notebook
Princeton 19 inch LCD blinks and chirps. i need a
Here is a direct link to the HP Pavilion zd7310 maintenance & service guide:
http://h10032.www1.hp.com/ctg/Manual/c00218664.pdf
Nov 26, 2009 | HP Computers & Internet
''My HP Pavillion ZE5300 Laptop Doensn't Come On At All!''=v.v=
when you press the power button, does any light flash for 1 second?
remove the memory, hard disk, cd writer from the laptop. then try to switch on again. do it using the power adapter.
if it doesnt come on then its an internal problem. you will have to open the laptop case and remove all parts for test
good luck
Oct 06, 2009 | Computers & Internet
My HP Pavillion DV100 notebook shuts down whenever it feels like. What could be causing this.It is 3 years old now so off warranty. It will work just fine for a little while and then voila! shut down.
Sounds like classic overheating, check your power supply fan, or the fan of your heat sync that seats over your CPU as well as the heat resistant insulation thermal lubricant that's there to keep it cool.
When fans starts to go the bears or motor starts to stick and will intermittently stop. When when it goes altogether it ceases to turn and can cause serious overheating damage to your circuitry.
Jul 27, 2009 | HP Pavilion dv1000 Notebook
Hp laptop dv9500 noisy and loud fan ...
The sound you are hearing is probably the fan, This fan has a noisy bearing and will eventually lock up and the fan will stop spinning and therefore the CPU will overheat and shutdown.
The fan needs to be replaced.
Feb 13, 2009 | HP Pavillion ZV6000 Athlon 64 3500+ 15.4in...
Hp Pavillion laptop
try unplugging your power supply it may be failing and causing te noise.
Alternately your fans may be coming on when the machine warms up causing the noise - listen close by the vents on the machine and you should be able to narrow down where the sound is coming from
Dec 18, 2007 | Computers & Internet
HP Pavilion dv4000 Notebook Logo
831 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
