Tv problem hello,My tv screen looks like green,yellow and red shaods around tv screen.What should do,to fix it.
  • cossack12 Jun 30, 2008
    Depending on the remote control setting, the screen is either black and white snowy or wavy distortion.I believe I have programmed the life out of the television. Is there a way to completely de-program the set and start anew? I have a 2 year old 52' Phillips HDTV.
    I also am unable to play the DVD or VCR.
Picture rolling, and vertical hight problems
Posted on May 23, 2008
I bought a new TV and hooked up the Wii like I normally would and when I turned it on and was looking at the selection screen, (game, netflix, other various things) I noticed that the Netflix icon was...
Hello.
Try inserting the RCA (yellow, red, white cable) into a different port. There are usually an RCA port at the back and at the side of TVs. You can also try interchanging the RED and WHITE cable and see if the problem will be transferred to the WHITE cable, then you will need to replace the cable.
Aug 06, 2011 | Video Game Consoles & Games
Yellow highlights on the picture around images.
projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 18, 2011 | Zenith R57W46 57" Rear Projection...
Yellow circle in the middle of the screen. It has
Not sure if this will help...
Projection TV sets have several common problems listed below.
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - TV makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 06, 2010 | Toshiba 42H83 42" Rear Projection...
Picture has ''double vision'' with red.
This is a common problem. Its called a convergence failure.
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • TV shutdown - does not display video
Feb 20, 2010 | Televison & Video
Started see red and green in the tv picture and a funny looking line in upper left corner. words on screen are shaddowed with red and green
Replace both of your STK convergence ICs will have part number on them also ck pico fuses around ICs they will look green or yellow like resistors, but are Fuses.STK392-110 example.
Sep 16, 2009 | Sony KP-57WS500 57" Rear Projection...
Sony 43 inch rear projection tv, I have lined up the convergence but still seeing red and green around edge of the tv on the images, seems fine in the middle of the screen though.
Always start at the vary center of the screen with Green. Position Red over Green, then Blue over what now will look yellow. If all is perfect except the outside, you will need to adjust "Mid-Size" until the middle is just as far off as the outside lines. Then adjust the main "Size" adustments to match. Go very slow or you can make a mess of it.
Mar 06, 2009 | Sony KP-51HW40 51" Rear Projection...
Philips flattv wont turn on
I had the same sympton on my tv...it worked fine one day and the next day it would flash a green light a few times you would see the screen power on, but still be dark then the power light would go red. I couldn't do anything on the tv no menus or sound. It turned out to be a bad power supply, a new power supply will run around $200-300 - in my opinion it wasn't worth fixing. My neighbor was able to fix my tv - he repairs electronics - ended up cost me $100.00 - its been running for 7 months now no problems so far...I can have him fix this for you if you are in the area - shipping makes this to expensive..he is located in south jersey...or you can try a tv repair shop ( i called for this but they wanted between $75-100 to just look at the unit + repair cost - i would of been back to the 200-300 range) let me know if you need help...John
netplus@comcast.net
Oct 08, 2008 | Televison & Video
Blurred TV - double vision with red hue
I was searching online about what could be the problem with our TV and I came across your page. We have a 52" JVC Projection TV that now has a "blurred" screen. We can see the channels but it looks like it's has a shadow around the images. The screen in in a red hue with green blur.
If you have any suggestions on what caused this and what we can do to have this fixed, I would greatly appreciate your advice.
Sep 07, 2008 | JVC AV-56WP74 56" Rear Projection...
Phillips 55' tv big screen
You should check and see if the red tube is showing any light. The green and blue make yellow when the red tube stops working. If it is showing red but looks dull, you will need to change out the fluid inside the tubes, as it is corroded. I will post a fluid change procedure on the repair tip for this set. I cannot post it here as they will not let me. They say it is too long. Go figure. They do not let you post what you want I guess.. Good luck with your repair.
Apr 26, 2008 | Philips 60P8341 60" Rear Projection...
My tv is picture is blue and green
Hi there my t.v has a similar problem, I turned it on and the colours arn't right, there the colours go out in three circles mainly mainly blue, green, red yellow, but depends whats showing on the t.v? Please help.
Apr 17, 2007 | Bush 5693D 24" TV
Televison & Video Logo
230 people viewed this question
Top Televison & Video Experts
