Question about Yamaha HTR-5280 Receiver
No left rear channel sound and no bass or lfe
All channels work except the left rear and LFE or bass checked all settings acan sdjust all but just no rear left channel.
4 Suggested Answers
guitarman002
  • 80 Answers
SOURCE: No test tone from subwoofer during balance testing Yamaha RX-V430
there's no test tone under normal use for the sub. It only shoud test the three front and two rear. ther' are disc you can use to test all the speakers. ( If you are into Pink Folyd, the movie The Wall has what you need to help balance the speakers
Posted on Jan 19, 2010
walesarumi
  • 6993 Answers
SOURCE: The LFE channel on my
First, test the non working channel with another speaker, crosscheck your speaker wires, and your connections to the amplifier. Make sure the left and right wire/cord entering into the input of the amplifier are good. A bad RCA can cause one side of a speaker to work.
Also, test the receiver with another CD, there are some Audio CD's that brings out only on channel output, either left or right.
If above are intact and problem is not still solved, then it might be the fuse on the channel of the amplifier.There is a fuse on each channel. Get a screw driver, disassemble the unit, and check the fuse on the channel.
If the fuse is intact, then it means a capacitor or diode may have become defective. Use a meter to detect the bad component on the non working channel, this will reveal the problem.
If you have any more questions, please let me know.
Good luck.
Posted on Jan 15, 2011
  • 3 Answers
SOURCE: I have already purchased a yamaha receiver rx-v667
The 667 has two line level outputs to feed a subwoofer. They are identical. You only need one for most sub woofers. You need a suitable length pin audio (RCA) audio cable to connect.
Posted on Mar 24, 2011
Can't get bass through subwoofer of my old sony surround sound system when i connect my laptop to amp using 3.5mm jack. laptop is Samsung rv511 and sony amp doesn't have optical in or hdmi in. any ide
If I understand correctly, you have a 3.5mm plug into your Samsung laptop, which is then connected to your Sony surround system via the red/white RCA plugs. I assume for the input to the Sony you're using a standard audio-in. I would check the speaker setup settings on the Sony to ensure that the "bass" and not just LFE (low frequency effects) are being sent to the sub-woofer. My understanding is that LFE is found only on Dolby or DTS encoded soundtracks, and if the subwoofer is limited to just LFE you wouldn't be getting any bass when listening to two channel stereo from your laptop.
Mar 20, 2014 | Sony Audio Players & Recorders
My Yamaha RX-A830 won't play the sub. I've reset the speakers with the mic multiple times but it's still not working. I confirmed that the sub works on another receiver.
There is a difference between SUB and LFE. In 5.1 mode, the LFE is the ".1" channel. It will output bass only when audio information signal is addressed to this channel. In stereo mode, depending of the receiver setting, it can output normal bass when front speakers cannot handle low frequency. In setup menu, you'll probably have to set your Front speakers as "Small" to make the sub channel taking the relay in low frequencies. There also can be many other reasons for your problem but this might be the solution. Good luck!
Dec 02, 2013 | Yamaha RX-A830 A/V Receiver -
I have Denon AVR-2310...but lost operating manual ! In audio set up, more specifically speaker configuration, a choice is given between " FTE", and "FTE +main". What is the...
The manual... http://www.retrevo.com/support/Denon-AVR-2310CI-Receivers-manual/id/23452bh638/t/2/
I'm pretty sure you mean "LFE + Main".
You need to identify the speakers to the receiver as Large or Small regarding their bass-handling capacity more than their actual size.
"LFE" removes the possibly overloading bass in a given speaker channel containing 'small' speakers and sends it to the subwoofer.
"LFE + Main" is sort of explained on page 29 "Bass Setting". The intent of LFE+Main is to task your subwoofer with the bass that ALSO exists on all other speaker channels regardless of their ability to handle it all by themselves. As you can imagine, this might make the subwoofer respond to sonic events that are actually supposed to be directional from, say, the rear channel(s). In that case the event might seem to come from wherever the sub is located instead of the intended direction; or at the very least it might seem to come from both places which is probably not what the sound engineers intended when they recorded the piece.
Having full-range speakers 360-degrees around PLUS a subwoofer, I don't subscribe to the 'bass-is-non-directional' school of thought. If you've ever felt the concussion from and subconsciously glanced toward one of the speakers after, say, a huge explosion, the system is working.
Sep 03, 2011 | Denon Audio Players & Recorders
Htddw7600, brand new, sub amp is not working, only way to get any bass sound is to unplug the sub cable from back of main amp and touch it on side of sub out port.
H?,
You have a very good system...one of the best of SONY..SUB does not get activated automatically especially on STEREO mode.DIRECT STEREO Notes • No sound will be output from the subwoofer.
.your system has Dedicated Power Amplifier for 2 Externally Driven Sub-Woofers (200W RMS x 2)..in order to activate the sub woofer amplifier you need to make a selection on the surround modes while you are switching the modes of the surround you will see the speaker position on the display of receiver as well..if you do not see the sub woofer it wont be activated..Sound Field Program (A.F.D) is a good example to test it..
Take care and please Remember to rate/vote and give me 4 Thumbs Up
for Helping out the Community :)
Hope this helps!
Additionally please follow the instruction on your user manual to activate the SUB ,as is follows..
BASS-OUT
Low-frequency (bass) signals can be directed to the
subwoofer and/or the front left and right speakers
according to the characteristics of your system. This
setting also determines the routing of the LFE (low-
frequency effect) signals found in Dolby Digital or DTS
sources.
Choices: SWFR (subwoofer), FRONT, BOTH
• Select SWFR if you connect a subwoofer. LFE and
low-frequency signals from other channels are directed
to the subwoofer according to the speaker settings.
• Select FRONT if you do not use a subwoofer. LFE and
to the front speakers according to the speaker settings
(even if you have previously set the front speakers to
SML).
• Select BOTH if you connect a subwoofer and you want
to output low-frequency signals from front channels to
both the front speakers and subwoofer. LFE and low-
frequency signals from other channels are also directed
to the subwoofer according to the speaker settings. Use
this function to reinforce low-frequency signals using
the subwoofer when playing back sources such as CDs.
Jun 23, 2011 | Audio Players & Recorders
I have a sony HTDDW7600, i cannot get the dedicated subwoofer amp to work. The fan is running on it, but for some reason the only way i can get it to do anything is to unplug the cable that goes from the...
H?,
Hope this helps!
BASS-OUT
sources.
SML).
Jun 23, 2011 | Sony MUTEKI HTDDW1600 Theater System
Conncet a sony sub to a denon reciver
Depending on the model, there are two ways to connect a subwoofer to an amplifier, receiver or processor. The best way is to connect the subwoofer to the SUB OUT or LFE output of a receiver, but some subwoofers can be connected to the speaker level outputs of the receiver or amplifier.
1. How to Connect a Subwoofer to the Subwoofer Output
The preferred method of connecting a subwoofer is through the LFE or Subwoofer output (SUB OUT) of a receiver. Almost all home theater receivers (or processors) and some stereo receivers have a subwoofer output. The LFE (Low Frequency Effects) is a special output for subwoofers and is often labeled 'SUBWOOFER' not LFE. 5.1 channel programs on DVD discs have a dedicated .1 channel output with bass-only content that is best reproduced by a subwoofer. Connect the output of the LFE or Subwoofer jack to the Line In jacks of the subwoofer using a single RCA cable (the two jacks on the left in the photo). A 'Y-Cable' may be necessary to connect the LFE output to both the left and right channels of the subwoofer.
2. How to Connect a Subwoofer to Speaker Level Outputs
Some receivers and amplifiers do not have an LFE or Subwoofer output. In this case you can use the speaker outputs of the receiver to connect the subwoofer. Using speaker wire, connect the left and right channel speaker outputs of the receiver to the left and right channel speaker level inputs on the subwoofer (the speaker inputs on the right side of the photo). Using speaker wire, connect the left and right channel speaker outputs on the back of the subwoofer to the left and right channel front speakers.
Hope it helped..
Apr 20, 2011 | Denon Audio Players & Recorders
I just installed a Denon 1610 A/V. I used my speakers from a older Sony 5.1 channel home theater system (DAV-S300). I got all the speakers to work except for the subwoffer. In order to hook-up the SW, I...
If you go to Manual setup/ select speaker setup/ select bass setting/ does it show LFE? If it does it is sending to main speakers only and you'll need to change to LFE+Main.
Oct 20, 2009 | JBL SCS135 System
Xbox 360 Not Playing LFE Signal
i dont know anyy thing about xbox
Feb 19, 2009 | Microsoft Xbox 360 Console
Denon avr 2802 can't get subwoofer to work all else fine
in the Denon setup under speaker configuration set the sub to LFE+Main
Jan 02, 2009 | Denon AVR-2802
7.1 channel onkyo home theater -- no sound out of subwoofer
You might try different listening modes; Some modes (Direct, DTS, Dolby - though I'm not sure which, offhand) require a seperate LFE track for sound to be output by the subwoofer.
Nov 25, 2008 | Onkyo 630-Watt 7.1 Channel Home Theater...
Yamaha HTR-5280 Receiver Logo
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
