Question about Amana ARGS7650SS Gas Kitchen Range
Oven door will not lock at self clean, I get F-9 error code. This happened after wife tripped into door when open. Is this an adjustment or do I need a locking motor?
  • Amana Master
  • 3,051 Answers
Hello there:
This code is a common
F9 Problem with door lock circuit such as pinched wire between Electronic Range Control (ERC) and door lock switch Check wiring and test operation of switchif the latch is alright unplug the oven for 1 hour and the internal reset device will reset the oven then plug in the oven and it should be all right
Posted on Sep 27, 2010
  • 2 more comments
  • eeengineer Sep 27, 2010
    I took the assembly apart and the microswitches seam to work OK. I ran the closer motor, out of the range, and it goes through a complete cycle.
    I reassembled and still get the " door" fault. I did find that if I sit in a chair in front and simultaneously push the top and bottom of the door it will lock and go into the clean cycle.
    I think that when my wife banged into the door she sprung it somehow. I have no Idea hw to adjust it however.
    Jim B.
  • Michael Thomas
    Michael Thomas Sep 27, 2010
    Hey Jim
    Thanks for the reply i think what you said is true however adjusting it can be a pain normally the pieces that the door sits in is what breaks or cracks and makes the door go out of alignment so you may be facing that issue as well if you have a service rep in your area i would contact them to see if there is a online repair manual that has a exploded parts diagram that you can look at so you can get a better idea of what you are up against i will use the model number that you providedd to see if i can find any thing if so i will let you know ok?
    keep me informed please
    Best regards michael
  • Michael Thomas
    THIS IS WHAT THE HINGES LOOK LIKE
  • Michael Thomas
    Great hope that helps you out it should i think i would change out the door hinges to be on the safe side
Why is oven door locked after self-cleaning mode?
How To Fix Oven Door That Doesn't Open After Self Clean ...
www.partselect.com/...Stove-Oven/Door-Will-Not-Open-After-Self-Clea...
How To Fix An Oven Door That Won't Open After A Self Clean Cycle ... This may reset the control and allow you to unlock the door. If you still cannot unlock the .
Repair - Dead oven after self clean mode, blank display ...
? 9:38
https://www.youtube.com/watch?v=UylZKwzAPow
Feb 22, 2014 - Uploaded by Random Repair
Repair - Dead oven after self clean mode, blank display, locked door Kitchen Aid Whirlpool How to repair an ...
Nov 26, 2015 | Kenmore Kitchen Ranges
Frigidaire gallery error code f9
How do I reset an F9 on Frigidaire oven? ' ShopYourWay
www.shopyourway.com > Manage My Life > Questions
Oct 26, 2009 - My Frigidaire oven, model feb24s5asb, door is locked and says f9. The door locked is beeping, I need code to know what the code means and how to unlock it.How do I reset an f9, door ... F-9 Error Possible causes: Door motor failure/jammed. Latch motor switch failure. ... Frigidaire Ovens Gallery 30 in.
F9 Error Code - Can't get it to stop beeping - Appliance Repair Forum
forum.appliancepartspros.com/.../400915-f9-error-code-cant-get-stop-be...
Jan 9, 2012 - 6 posts - ‎5 authors After that it flashed betwed F9 and dr and won't stop beeping. ... say that the last time I used the self clean, the dorr would not unlock and I got similar error codes. ...Frigidaire BFEF374EB1 Frigidaire Canada/electric Range Frigidaire Door Lock F9 error code and now F1
1 post
Dec 6, 2010
Frigidaire Door Lock and F9 error code
Jul 10, 2010
Frigidaire Error Code F20 - Upon Cleaning
Dec 3, 2008
Frigidaire error F-9
Feb 18, 2008
More results from forum.appliancepartspros.com
Oct 29, 2015 | Toaster Ovens
I have a Kenmore Elite double oven, model 790.48123801.(4 years old). My wife attempted to operate the self-cleaning feature and 29 seconds later an F90 error message appeared, the oven began to beep
Oven door latch error code. The oven door latched but the control board did not receive a signal that the door was latched.
The only time that the latch is used is during the cleaning cycle.
KENMORE ELITE Walloven Parts Model 79048123801
How to unlock Kenmore oven
Oct 18, 2014 | Kenmore Kitchen Ranges
My oven is flashing a F10 code and the door is locked. This happened while the oven was in self cleaning mode
more than likely the tco thermal cutout fuse has opened during cleaning and now the ovens latch motor cant get power to open,its under the top cover where the surface elements are located its a frequent thing with all ovens/stoves
Jan 12, 2013 | Kenmore 40494 / 40495 / 40499 Electric...
The oven is giving error code LOC
amana self cleaning convection oven displays an F9 code.
Sep 06, 2011 | Maytag Kitchen Ranges
Can't disengage oven door lock
Lock disengaged on its own after a day. Oven is now clean, everything working properly.
Jul 06, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
I have an electric wall-mount double Whirlpool self cleaning accubake oven. Can't fnd my manual, so I don't have the model number. It is 9 years old. Put on self clean feature, and it shorted out, and...
If you can see through a grill just above the door, then you might can see the lock linkage, and get something to push the linkage over (be sure to disconnect power first.).
If you can't, you'll need to pull the unit out from the cabinet and access it from the top.
The problem is often a thermal fuse in the top of the oven. But if you can provide more detail info on the oven, I can investigate further.
Jan 29, 2009 | Kitchen Ranges
Oven Door Locked
the oven door does lock during self clean, otherwise it will not work. however, the door is supposed to unlock after the oven has cooled. if it is still locked, turn the oven to self clean and wait about a minute and then hit cancel and see if the door unlocks. if not, there may be a probelm with the door lock mechanism. Joe
Nov 18, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
E2/F2 Error
The Model number is a RBD306PDB6 i found that one as far as the code
F2=
E2 Keypad not connected
1. Check keypad connector for firm connection.
E3 Key held down too 2. Press CANCEL. If error code returns after 60 sec., replace keypad.
long, or key is shorted
Feb 17, 2008 | Ovens
Whirlpool super Capacity 465 gas range-Door Lock
your latch is defective. they have parts that melt when you use the self cleaning cycle. they also just go out. the door should auto latch when you start the cycle but it times out when it is not seen.
Jan 02, 2008 | Whirlpool GS460 Gas Kitchen Range
Amana ARGS7650SS Gas Kitchen Range Logo
371 people viewed this question
Top Amana Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal DeAngelo
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
