Question about Lexmark X1240 All-In-One InkJet Printer
I have a lexmark x1240 model and can not get it to print anything..This is (over the years) my 8th or 9th printer from lexmark...I have replaced the cartridge and still nothing..I work at Wal-mart in Electronic Dept and have sold (over the years) thousands of your printers..WHY does the printer print only blink copies...Absolutly nothing even tho printer says--Pinting Complete,,,thanks Doug
  • Lexmark
    Lexmark Sep 27, 2010
    Do you get the same result when copying using the Copy button on the printer operator panel? If so, it might be cartridge-related. You can manually clean the cartridge nozzles using a damp paper towel. If problem continues, replace the cartridges. If copying comes out good, it may be software-related. Uninstall the Lexmark software, then reinstall. Use the driver from Lexmark.com to reinstall the software.
  • 10,421 Answers
Lexmark x1240 Feeding incorrectly/crooked
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Also clean The purge unit, called a spittoon assembly in an HP, Lexmark, Caonon and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
It also has an electrical pump to milk the print heads and test for ink flow.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Apr 29, 2010 | Lexmark X1240 All-In-One InkJet Printer
Flashing power button and doesnt stop
One of a few things. It can be the ink is too low, paper jam, or the chip board went bad in it due to dust, dirt, or just lousey building :)
Jan 06, 2010 | Lexmark X1240 All-In-One InkJet Printer
Have a lexmark x1240, I don't have a manual. It will print from the pc but I don't know how to make it scan or copy.
go to lexmark.com support drivers and manuals enter model number, you can get an online or printable manual there..
Nov 28, 2009 | Lexmark X1240 All-In-One InkJet Printer
My landmark x1240 donot print at all.
Download the driver from the lexmark website.
You should turn off the printer and the computer.
Unplug the printer. Turn on the computer. Bring it all the way up. Turn off the computer. Plug in the Lexmark. Turn on both machines. Install the printer driver.
Sep 08, 2009 | Lexmark X1240 All-In-One InkJet Printer
Lexmark X1240 will not work with my laptop computers.
try to pritner off then check also check that your cable is proeprly connected reconnect the cable.
Nov 15, 2008 | Lexmark X1240 All-In-One InkJet Printer
Not printing
First try checking the default printer setup on your computer, check that out from your "control panel" window, then try again (printers/faxes for winxp and printers ison from vista) Make sure that the model of your printer is set as default.
Nov 10, 2008 | Lexmark X1240 All-In-One InkJet Printer
Uninstall lexmark printer
Click on Start>Printers and Faxes.
Look for your printer. Double click it.
Click Printer>Cancel All Documents.
That should remove all of them from que. Be patient. It may be slow.
After they are gone, try to remove the software.
Oct 17, 2008 | Lexmark X1240 All-In-One InkJet Printer
All in one printer does not scan or copy
If the Ink Status is showing a ? symbol after you have replaced the tanks, you just need to tell the printer that you replaced tanks ,
To do that , open your lexmark solution centre from the Lexmark start menu group.
Click Maintenence
Click Install New Print Cartridge
Jan 18, 2008 | Lexmark X1240 All-In-One InkJet Printer
Lexmark X1240 All-In-One InkJet Printer Logo
91 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
