Maytag neptune MAH5500BWW ELECTRIC PUSH AREAS DO NOT ACKNOWLEDGE WHAT HAS BEEN SELECTED. WHEN ONE PUSHES THE START OR OFF BUTTON, NOTHING HAPPENS EXCEPT THAT YOU HEAR A BEEP THAT SOUNDS AS IF YOU HAVE MADE AN ERROR. ANY BUTTON THAT YOU PUSH MAKES THIS NOISE. HAVE UNPLUGGED IT, LET IT SIT AND THEN PLUG IT AGAIN IN HOPES THAT IT WILL RESET AND WORK. NO! IT JUST BEEPS AT ME. PLEASE ADVISE ASAP. THANKS
  • 1 more comment
  • libru101846 Sep 27, 2010
    this is a front loading machine. not in spin cycle and cannot get to spin cycle
    this is a front loading machine. do not know if it will spin or not. no response when any button is pushed. only a beeping sound, as if i made an error.
  • 2,272 Answers
The beep when any button is pressed. There are 3 possibilities for this problem. 1) Door not closed properly or faulty door switch. 2) The Front /membrane(also called the touch pad assembly) is faulty. 3) The main control board faulty. ----------- So first open the door and check the door assembly.On the door side as well as on the machine frame where the door connected.If there is any dust or some thing blocking the door to get connected to the door frame on the machine.If all is clean an ok then check the door latch which open/close.Is this latch looking cracked or broken any where.If that also looks OK then check the door close noise.When the door is closed you will hear a noise.That is a "CLICK" nose.See if that noise is coming.If not then its the indication of faulty door closing assembly,it has to be replaced.Press the door to close bit tightly then check.if the same beep comes.Many cases the door do not close properly causes this.Now in case door and its latch and assembly all checked OK then,in most cases the control board check out faulty.Because if the touch pad is faulty then ,you will not hear a beep as its faulty.But still in some rare cases the front membrane touch pad is faulty. ---------------
You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation
Posted on Sep 27, 2010
  • 10,865 Answers
Hello. If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it.
3 beeps on any button press, machine will not start, and will not go into service mode
Try unplugging and plugging it back in, carefully. The control panel most likely has gone out. These panels are generally readily accessible, so it is not a big deal to replace a circuit board or component. Be sure to unpower the machine if someone is to try this that is not a licensed technician. If you have a warranty it may be time to call someone out.
Aug 31, 2017 | Maytag Neptune FAV6800AW Top Load Washer
My maytag neptune dryer has the start button flashing but when push it nothing happens. I unplugged it and it is stil flashing when plug back in.
Did you have any power surges latley? Sounds like the control board is faulty. I think this model has a control board in the top counsel. Hopefully this helps
Jul 29, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Maytag neptune
i have maytag neptune wash,modelo mah5500bww,my problem is: no starting,flashing start/pause button,after ten minutes is off.And now is ready for start when press start/pause button
May 20, 2008 | Maytag Neptune Washer
Neptune mah5500bww
I've had the same problem with a Neptune MAH3000. I replaced the mother board to no avail. I replaced the timer control to no avail. I then replaced the door lock assembly (wax motor, door switch, etc.) and problem solved. Luckily, I had another machine that I could rob parts from.
Nov 02, 2007 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
101 people viewed this question
Top Washing Machines Experts
