Question about BenQ Joybook 3000-01 Notebook
When i connect my head sets,the speakers keep on producing sound,as well as the microphone,when i connect a microphone,the one that's built in keeps on recording,which distorts my recordings.
    Scholar:
  • 104 Answers
You can disable this in Control Panel/Hardware and Sound/Manage Audio Devices
Posted on Sep 27, 2010
Bose 321 power woofer buzzes but produces no audio sound
I assume the other two speakers are working fine. Contact Bose and ask them. Could be a simple fuse. Sounds like a fried speaker driver, but do this first. Take the back off and check the power amplifier for a blown fuse. If none, disconnect the power amplifier. Reconnect the speaker cabinet w/o the built-in power amplifier to a known good amplifier to see if the speaker works. If it works then you know its the built-in power amp that's fried. Contact Bose for a replacement or better yet buy a another one with a higher RMS watt capacity. Wattage ratings in other than RMS are worthless. JBL and Cerwin Vega produce high wattage units. You need to keep the volume lower to avoid the problem in the future.
Aug 27, 2012 | Bose Audio Players & Recorders
Tip
How to play computer sounds through microphone
<p>There may, of course, sounds from a microphone, because there is a speaker, but you can use sounds from a microphone or something speakers connected to the microphone system is played. Computer games, but might sound a bit complicated because they usually lead to loud sounds into the microphone to a number set. <br /> <p><br /> <p>1. Find the computer that you want to play sound. Go to Control Panel and click on "Hardware and Sound." Under "Sound" in "Changing the system sounds." You can access various Windows sounds by selecting them and clicking "Test". <br /> <p><br /> <p>2. External speakers to the sound card or audio output on a laptop. With active speakers is recommended, the stronger the better. Set the microphone in front of the speaker. <br /> <p><br /> <p>3. Connect the microphone and play the sound from computer speakers. That should pass the microphone for recording or performing live. <br />
on Jun 22, 2011 | Audio Players & Recorders
The speakers keep on cracklingand distorted when ever there is sound. Not sure if its the speakers or if the computer stuggling to keep up with what is loading or playing. Any thought what it could be...
trying muting any microphones, headsets or webcams that may be connected. They can pickup the sound and feedback to speakers. The only other thing - less likely - is a dual driver scenario where two software setups are trying deliver sound.
Jun 13, 2011 | Audio Players & Recorders
Hi i got some head phones i can hear people but they carn t hear me
Did you checked your Microphone Connection? if no. If you are useing windows then
on your desktop right botom, near the time display there is one speaker icon
double click on that speaker icon> volume control window will apear. In that
click Options > Properties> select Recording readio button, In below items, select all or select and tick mark Microphone> click Ok button. Recording control window will appear. In that
Select Microphone and set desired Volume level. you can also boost the mic volume, by
clicking Advanced button below Microphone Slider. Advanced control for microphone window will appear click or check Microphone Boost . close all the windows if any and now test your headphone. this will solve your problem. keep smiling
Jan 16, 2011 | Voyetra Turtle Beach Audio Players &...
My subwoofer keeps poping and then stops working
larryagross,
Sounds like you blew the speaker! The amp is sensing the voice coil is connecting to the speakers magnet or iron core and is going into a safe mode. It is possible to blow the coil even when the sub has a built in amp.
First make sure that you have the gains properly set ans not all set to their maximums. Second, disconnect signal to the sub then unplug the power for a few minutes. Third, plug the sub into a source of power on a different circuit using a surge protector.
Does the speaker make any popping at the time it powers up? If so you have a amp problem. If there is no sound produced, connect it back the the system using a different signal cable. Does the speaker now pop again when sound is produced. If so the speaker has failed. Contact a Velodyne repair facility.
-Chris
Aug 10, 2010 | Velodyne CT-80 Subwoofer
My sound driver can't install...a built in sound card, my motherboard is emaxx.
hi im josh in cebu phils.may i help you? friend try these solutions i gathered; Let's look at the simple stuff first. Is the card installed properly in your system unit? Have you connected the audio cable from your sound card to your CD-ROM/DVD drive? Are speakers (or headphones) hooked up to the card? Are the speakers plugged in and turned on? (And are they plugged into the correct jack? You don't want to plug your speakers into your microphone jack!) Are you performing a task on your PC that actually produces sound? Is the volume turned up loud enough (both on your speakers and in Windows)?
Okay, now that the easy stuff is out of the way, let's turn to something more difficult. The most likely cause of no sound is some sort of conflict. One by one, change your card's DMA, IRQ, and port settings. (This might entail resetting some jumpers on the card itself, as well as making some software-based changes.)
This problem can also occur if you add a new sound card to a system that has sound capabilities built into the motherboard. You'll need to disable the onboard sound before the new sound card can work. thats all for now good luck.
Mar 04, 2009 | Computers & Internet
HOME THEATER SAMSUNG HT-Q100
Your systemn is designed and built to perform 2.1 sound. If you want 5.1 sound you can do 2 things, connect another pair of speakers to the same speakerterminal as your front speakers, however this produces 5.1 stereo sound and not 5.1 surround sound.
You can buy a new system that has the proper connections.
This set will not have the proper decoding software to produce 5.1 surroundsound. sorry.
Jan 16, 2009 | Samsung HT-Q100 System
Microphone hissing sound
That sounds alot like the microphone booster in control panel. Depending on what version of windows your are using, you can just open the sound control from the taskbar and go to the advanced settings and uncheck the setting "microphone booster". Adjust microhpone volume accordingly.
Dec 31, 2008 | Yamaha WaveForce 192XG Sound Card
Sounds both in head set and speakers
Solution:
i) try somother headset(if you have spare ones...with u), if prob still exists there must problem with sound port(inbuilt sound on your laptop) which is not allowing the wire or chord of your headset to completely plugin to your laptop sound port.....
it is like this  connecting wire is  paritally inside your laptop sound port and partially outside and leading to sounds from both laptop speaker(builtin) and the headset you are connecting.....
Thanking you
M. Sridhar
Dec 26, 2008 | Compaq Presario 700 470024-192 Notebook
BenQ Joybook 3000-01 Notebook Logo
56 people viewed this question
Top BenQ Computers & Internet Experts
JP Services
JP Services
Tony
Tommmix
Level 1 Expert
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
