Water does not drain out from my washer
I have a Maytag washer, model no. LAT5005AE. Water is not draining out. The washer is spinning but the water is not draining out. Pls advise.
  • networktech Dec 13, 2008
    Sometime during the cycle the washing maching (LAT5005AAE) stopped working leaving the drum full with rinse water and clothes. Pushing in and pulling out the switch netted no results (top shut), not even a motor or timer hum. Electrical outlet is good. Where do I go from here?
I have determined one of the reasons ( I feel this is the primary reason) why many BOSCH washing machines will not drain the water, Bosch uses the same drain pump in many of their 500-800 series washing machines, part number 436440. The drain pump is a electrical controlled magnetic driven pump. Simply a electrical current produces an electrical field which a magnet rotates, spinning the pump blades. I have determined that the internal seal on the pump part is allowing water to leak into the magnet area of the pump. This is causing corrosion, and water build up around the magnet, interfering with the magnetic field. How I came to this conclusion. After removing the end of the pump, and allowing the water to drain out, drying out the pump, the pump will work as advertised. But of course the pump cannot be used in this condition. A new pump is required. To determine this yourself, if the machine is not under warranty (good luck getting service). Unplug machine, remove back panel, unplug the drain pump, remove drain pump (separating the drain pump from the large plastic holder, there are three screws holding it to the housing). You can shake the pump, and if water comes out of it this is most likely the problem. Now hook the pump back up to its electrical feed, and place it on a rubber sheet. Set the machine to drain, if the pump attempts to spin then stops, or hums this is the problem.
Posted on Nov 10, 2008
    Problem Solver:
  • 10 Answers
I opened the control housing and found a blown fuse. Replaced the fuse only to watch it blow again as soon as the power was supplied.Traced the circuitry from the fuse to the Water Level switch, replaced it and Viola!
Posted on Mar 02, 2010
Maytag neptune model number mah5500bww washer not draining
Washer will not drain:
Thedrain water pumpis the main part in your washing machine that pumps out the water. If this is defective or has failed in any way, this will be the reason why your washer will not drain the water. Before you order a new drain pump, make sure tocheck the pump to be sure a small object like clothing or similar has not lodged itself insideof it causing the NO DRAIN issue and even a no spin issue?. If the drain pump is not clogged, you can test it with a multimeter and remove and replace if needed. Go to Google or YouTube and search for "Replace Washing Machine Drain Pump" then type your brand and model number of washer to show you details on replacement.
Read more:http://removeandreplace.com/2014/10/30/fix-washing-machine-that-wont-drain-washer-not-draining-water/#ixzz3X2LbXMWJ
The washing machinedrain hoseis where the water flows through to get the water out.If this drain hose is blocked, kinked, bent, or clogged, the washer will NOT be able to remove the waterfrom the tub. Check the drain hose to be sure it allows the water to flow freely. You can take the drain hose off and run water through it in your sink to be sure it is not blocked. If there is water STILL in the washer when you remove the drain hose, grab a bucket as the water will exit from where you disconnected it
Thewater pump belt(to drain out the water) may have broke or become frayed or loose.If this belt breaks then it is unable to drain and remove the water from your washer. Inspect the belt to see if this is causing theNO DRAINissue and remove and replace if needed.
If thelid switchis not working as required it will cause your washer to not drain (and many other problems).This may be unlikely as a bad lid switch will usually cause your washer to alsonot agitate or spin.However on some models this can vary. The best thing to do if you have a suspected bad lid switch is to test it. It can fail electrically and or mechanically. If mechanical failure is the issue, you should be able to see if it is cracked, broken, or not in place to make contact with the lid. To test it electrically, use a multimeter set on Ohms and test it for continuityMy advice is free cuz God is good!
Fix Washing Machine That Won Drain Washer Not Draining Water
Dec 26, 2016 | Maytag Washing Machines
Washer won't drain or spin.
What to do when your washer won't spin or drain water ...
? 2:23
https://www.youtube.com/watch?v=oFB1jEdXVsQ
Jun 20, 2012 - Uploaded by searspartsdirect
What to do when your washer won't spin or drain water ...Washer Repair - Not draining or spinning ...
Maytag, Whirlpool & Roper Washer Diagnostic - Water Does ...
? 6:33
www.youtube.com/watch?v=diRuMkf9_Vs
Sep 12, 2013 - Uploaded by ApplianceVideo.com
Fix your own Maytag Top Load Washer which has some of the following ... Troubleshooting Why the Washer ..
Oct 31, 2015 | Maytag MHWE450WW - Performance Series HE...
WHY ON MY MAYTAG EPIC WHEN IT GETS TO SPIN IT JUST MAKES DRAINING NOISE AND WATER WONT DRAIN?
Sounds like your drain line is clogged. You may also have stuff clogging a water filter just before the pump, or the water outlet coming from the drum.
It could also be a problem with the pump, but until the drain line is opened up, you still won't be able to empty the water from the washer.
Aug 11, 2014 | Maytag EPIC MFW9700S Front Load Washer
Maytag atlantis washer mav6300aww drains water but does not spin
my maytag washer model #MAV6300AWW will not spin out during cycle but can turn it back to spin and will spin out
May 30, 2010 | Maytag Atlantis MAV6000 Top Load Washer
LAT9604AAE No agitation but drum spins and drains water
cold possibly be just the agaitor but odds are u need a transmisson not worth repair
May 20, 2009 | Maytag PAV2300 Top Load Washer
Maytag washer, model: LAT8415AAE top loader. Washer fills with water but will not start agitating,spin or drain.
Check lid switch. Most will not run with lid open and the switch may not be pressed down when door is closed
May 17, 2009 | Washing Machines
Washer does not remove water in final spin
If washer hums when it should spin, and the washer will not drain, you may have 2 issues.
First check that the drain pump, drain hose, and wall drain are free of debris.
The washer may not spin properly if the drain system is not operable.
Once you are sure the washer drain pump, drain lines, wall drain, and drain hose is okay, run a test wash.
If the washer hums but now drains, you fixed one issue.
If the washer still hums, you may have a bad belt, motor coupler, motor itself, etc...
Check parts for wear and replace as necessary.I pulled the drain impeller and found a sock from my little guy stuck in there. Fixed!
check all water outlets to make sure there is nothing blocking the pipes.
you could also go to this link it might help you out..... Washer does not remove water in final spin Google Search
Oct 24, 2017 | Maytag MAH6700AWW Neptune Front-Load...
Washing Machines Logo
560 people viewed this question
Top Washing Machines Experts
