Question about Kogi L9CH 19" Flat Panel LCD Monitor
Hi, my PC screen has moved to the right by approx 2 inches, there is a faint grey line which marks the boundary and my mouse can advance no further than this, I have tried all resolutions that my monitor (HP w19) will except and have tried to move the screen via the monitor menu button, all to no avail, I have updated the graphics and monitor drivers and have rolled them back too, still no joy! I was playing Simcity when it happened and have since uninstalled it but again no joy, please please help
3 Suggested Answers
El Duderino
  • 47 Answers
SOURCE: Monitor Display Offset
Hi HarryH, Sounds like the web cam software may have changed a .dll or some other system file that the video chip is using. I would try uninstalling any software from the cam and removing and reinstalling the video drivers. Have your windows CD or the CD that came with the PC handy we might need it. Open Device Manager Control Panel > System > (or hit Windows key + Break key) and if you're using XP switch to the Hardware tab and click Device Manager. Double click Display Adapters. Right click the video adapter listed and click Uninstall. Click yes you're sure to whatever warning message comes up. Now reboot your PC. Windows should auto-detect the video and re-install the correct drivers. There IS a possibility that the first re-install could use the same bad files...so if while re-installing you DON'T get asked for the windows CD and you still have the problem after rebooting, go to the manufacturers web site and download the drivers for your system and force windows to install those files. If you don't know how and it comes down to needing to try that let me know I'll walk you through. Please come back here and comment this post, some people have been missing the "Add a comment" link at the bottom of the post. Starting a new thread to answer an Experts questions makes it hard on the prople trying to help. :) Let me know how it goes, Dude
Posted on Nov 27, 2006
  • 13 Answers
SOURCE: Problems After Power Outage
Sounds like the power outage damaged the video interface could be damaged. You might have had a spike that effected the red input of the monitor. You can try to order a video interface, or like I suggest to others, look for the same monitor but broken on ebay and swap out the interface board. Chances are this will fix your problem. Good luck
Posted on Oct 03, 2007
Samsung 46 inch LCD tv problem
AmanStino Mouse Pad with Gel Wrist Pad grey(9.0*7.8)
  • 1.Smooth and precise mouse tracking, Non-Reflective surface.
  • 2.Large round mousing area, Memory Gel Pillow keeps your wrist in natural position.
  • 3.Ergonomic design wrist support - Keep arms, wrists, and hands from getting sore while using the computer, reduce wrist stress and tirednes.
  • 4.Suitable for most optical, trackball, laser, and rollerball mi.
AmanStino Mouse Pad with Gel Wrist Pad black9 0 7 8 AmanStino
Feb 16, 2015 | Samsung LN46D630 46 inch LCD 630 Series TV
Hi, my syncmaster p2270 seems to have some kind of focus issue. Everything is sharp, but to the right of the visuals on screen there is a duplicate, reflection of whatever is being displated on screen....
Hi Jonhy, on the pc , try this steps:
1. At the mainscreen mouse rigth click and go to Properties
2. Go to Definitions and Advanced
3. A window with graphic board's properties will come up and the choose 3D setup/config (depending on graphic board mark)
4. Change from Direct 3D to OpenGL and then Apply and OK to close.
This procedure is to change from hardware aceleration to software aceleration of image on screen. As that it will be sent only one kind of image definition from the pc to the screen with no repeating or mirrowed data. Hope it will helps you.
Nov 04, 2013 | Samsung SyncMaster P2270 22 inch Monitor
I cannot place the cd tray into the printer to print a cd..Canon ip3000.
Hi, I have fixed my problem by sheer perseverance and obstinacy...
Every time I tried to print a dvd label it came up as an error...the arrow indicator marks on the type "B" caddy were not in the right place...
by centering the caddy into the printer tray about 1cm...approx 1/2 inch deeper then the arrow marks, the printer worked fine...this is a bad mistake by Canon...as they repeatedly state not to push the tray further then the marks...
all is well that ends well...
cheers
haitchhcee
Dec 08, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
1 yr & 4 wks old, bottom 2/3 of screen fuzz of lines
A couple of things that you might try.
1. Try changing the screen resolution - control panel - display - settings
Mar 11, 2009 | HP Pavilion dv9000z Notebook
No picture on tv
Move your mouse over to a empty part of the desktop and press the right mouse button. Select properties.
Make sure that your tv is connected to the computer, that it is turned on, and that it is set for line input on that device.
Select the settings tab. You should see this box appear.
Monitor one is your computer monitor. Monitor 2 is your tv. It should be greyed out. If you move the mouse over to 2 and press the right mouse button make sure the attached is checked off. If not do this right now.
You may have to click on monitor two as well and select the advanced button on this screen. Then look in the settings to turn the tv on (this happens with ATI cards, NVidia cards may have a similar setting as well). Once it is turned on and you hit apply the picture should come on the screen. If you check off extend windows desktop onto this monitor, you will only see the desktop without any icons. Make sure that feature is disabled when you use monitor 2 (by default it is).
This should keep you busy to get it to work. Let me know if you need anymore assistance on this.
Feb 14, 2009 | XFX GeForce FX 5200, Graphic Card
Shadows on screen
Try moving a medium powered magnet (not one for picking up heavy objects and not a refrigerator holding one) over the distorted area. If that doesn't work, try a more powerful one. This worked for my Toshiba LCD. Good luck!
Jan 04, 2009 | Sylvania 6626LCT 26 in. LCD Television
Screen flickers
Dear,
Try this one
Right click on desktop and select Properties.
Then click on advanced button and choose Troubleshoot from tab.
Now move the slider bar to middle level and remove the check form Enable write combining. After all restart the system, it will solve your problem.
Thanks & Regards,
Rakesh Kumar
Oct 28, 2008 | Fujitsu Siemens AMILO Pro V2010 Notebook
Kogi L9CH 19" Flat Panel LCD Monitor Logo
42 people viewed this question
Top Kogi Computers & Internet Experts
Laxman Bisht
Laxman Bisht
Computer Links
jay kaye
jay kaye
Are you a Kogi Computer and Internet Expert? Answer questions, earn points and help others
