Question about Honeywell Heating & Cooling
I programmed my AC at 79ºF, when i got home last Saturday the temp inside the house was 86ºF! my daughter and i tried to troubleshoot using the Honeywell pamphlet but we're getting fan not cool air. We made sure the AC is cool mode but only warm air coming out. PLEASE HELP, it's going to be 110ºF today.
  • Honeywell Master
  • 43,501 Answers
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
Air Conditioner Trouble - Review the Possibilities
heatman101
Posted on Sep 28, 2010
Haier AC changing temperature by itself
Have you tried calling the manufacturer? If you need more questions for your Air Conditioning Repair needs, check us out online
Jul 05, 2017 | Haier Heating & Cooling
How much r410 gas pressure in 1.5 ton inverter ac
Usually on any 410a freon system you can use a pt chart, and for any other freons also. At 120psig yours indoor coil temp is around 40°f. You want this temp/pressure above freezing. Your pressures are going to depend on indoor/outdoor temps. Hope this helps!
Mar 23, 2017 | Inverter Heating & Cooling
Compressor fails to restart
indicates that the compressor is not communicating with the program board in the inside unit
could be a relay problem
call in the service technicians for a proper diaganosis
Sep 12, 2017 | Honeywell Heating & Cooling
Adjusting Apollo hot water tank
I am not sure what you are asking, But i am going to assume that you want to know about changing the Temp on the heater for inside the house.
If the floor heat was installed properly than it should have a temperture manifold or adjustable thermostat for seperate heating.
You need to find the thermostat or manifold for the garage heat and set it at what ever temp you want the garage to stay at.
Then you can change the A B C knob to a higher setting A is cold B is warm ac is hot. So Increase your temp setting on the heater and this will increase your house water temp for hotter showers and faucet temps. However, they recommend not setting the temp above 120 degrees to prevent severe burns.
If you have a newer home increasing the Hot water heater temp setting may not change the temp at the shower or faucets if you have scald guard faucets installed in the house. This will require adjusting the scald guard valves on each faucet.
I recommend using a candy thermometer or digital thermometer to check the faucet and shower Temp prior to using them and make sure that you inform everyone in the house after you change the temp so that no one gets scalded.
I hope this answers you question, feel free to contact me if you need more help!
DR Wilkins
Oct 15, 2013 | Water Heaters
The AC is on and it says it is 86 in the house and cold air is kinda blowing but it is HOT in the house.
Check outside unit to see if running if not check breakers and see if there is float switch inside the air handler inside. There is only so much you can do. Calla service tech for free estimate. Russ
Aug 15, 2009 | Heating & Cooling
AEW10AJS1 a\c digital panel keeps climbing to its
I have the same problem, 4 little kids in the house trying to keep them cool. Did you find out how to fix this?
thanks
Ian
Jun 28, 2009 | GE AJCQ08ACB Air Conditioner
Hello, We bought a Perry Home in Georgetown TX last March and it is still under its two year warranty. Our air conditioner stopped cooling today. It has been working well for over 1 year. We came home...
You have a 10 year warranty on your AC. Call a Goodman rep and have it serviced. It will probably be a bad compressor capacitor. Bad wire or no refrigerant.
Jun 26, 2009 | Goodman Heating & Cooling
I have an old 1985-86 coleman central heat and air need manual
The filter is located before the blower if your Coleman is in a mobile home it will be in the door facing. If it is a standard ac/heat application and a regular residential furnace the blower in the cabinet on down flow (ducts in floor) will be above it and possible in the duct connecting in the top. If its the other way (ducts in ceiling) it could be right under the blower. Either of these could have a filter cabinet on the furnace or could have a filter grille at the end of the return air duct (where the air is sucked in).
Mar 10, 2009 | Coleman Heating & Cooling
AC thermostat does not control AC. AC runs continuously. Have to shut system off to stop AC.
are you using the old coventional thermostat? using mercury
or was it digital?
chances are the reason it is not stopping because it can not detect the right temp inside your house, if you have set this for example 74F AC would run continouisly until it reaches that right temp, until that time, it would surely not stop,
check for any windows, door that might cause some air leaks inside your house for a start, close all exhaust fan and see if you can see any difference, if not this might be the right time to change for a digital temp control, it not that expensive and easy to install
Jul 25, 2008 | Heating & Cooling
My AC unit keeps freezing up on the copper lines going into the house from the outside unit. It also freezes up on the inside lines and the air is not cooling my home down.
Operate your air conditioner with the fan in the on position. But first turn the fan on, turn the temp up or shut the cooling off. Your coil is more than likely frozen over. At night when outside temperature drops the refrigerant pressure and temperature in the system also drops. This action can cause icing of the cooling coil, with the fan in automatic everything shuts down at the end of a cooling cycle. Thus no air movement to melt ice on previous cooling cycle.
May 09, 2008 | Heating & Cooling
Heating & Cooling Logo
163 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
