Question about Viking DMOR205SS Microwave Oven
The door does not open. The push bar is not working and off center
I have a Viking Micro/Hood combo. The door latch was not working.
I removed the handle by pushing up on the right side and then pulled out.
There is a hollow cylinder on the left side of the handle that extends out to trigger the door to open. For some reason it wasn't triggering so I extended it out by inserting a rod into the hollow part and pushed it in until the cylinder was extended by 1/4 inch. It works fine now. Hope this works for you.
Posted on Dec 02, 2011
Open door if latch is broken
And you can't just pull the door open? I know it's easier to push the open door button but both ways should work unless the safety switch bracket moved from it's intended position. I hesitate to offer this solution, but who wants decayed food smelling up the home? Let's assume it's a counter top oven, remove all cover screws and the cover. STAY AWAY FROM ALL WIRING and I should have said first unplug the power from the appliance. Locate the door latch area and lift up on the plastic/metal bar that has a spring attached to it and the door should be released. Pushing the door release button should lead you to the latch. Once you see how it works you may find the reason the latch is malfunctioning. If it's a over the range type you will have to remove a grill at the top of the oven to access the mounting screws that release the oven from the bracket but the latch reference above will apply to this type as well.
Dec 06, 2014 | Microwave Ovens
Food not cooking in center
What make and model?? Sounds like it is not a carousel model. Have you tried a "Micro Go Round" ?? Otherwise, try rotating the 'plate' each quarter cycle...ie; every 30 seconds on a 2 minute cook time. Be sure to push the stop button first before you open the door to save wear and tear on the door switches......
Nov 04, 2013 | Microwave Ovens
The push button to open the door does not engage door, so door does not open
in most cases this is due to a snapped of push bar as they are made of plastic its a common fault. if the push bar is not snapped then its lost a plug that holds it in. as the microwave holds a constant 1000 watts of power i always recommend to people to have them fixed by lic techs the repair cost for this fault is around $ 100 if the part is still available
hop this helps please rank advice below
Dec 28, 2010 | Whirlpool GT4175S Microwave Oven
Door won't open. push button doesn't work
It may be a broken door open lever or a worn door open button or both.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Oct 06, 2009 | GE Microwave Ovens
Sharp Microwave model R-1850A door won't open
buy a boddle of WD-40 and try spray some in the raded spots.Im not a big specialist in microwaves.hope it helps
May 10, 2009 | Sharp R-930AK Convection/Microwave Oven
Hi ,there are two posibility to repair . 1. by ordering parts to the web site of sharp .
2. You may check from shop same type of part bring sample or in the appliances center near you.
Jan 14, 2008 | Sharp R-1850A Convection/Microwave Oven
Door won't open
Im sorry to say, but the housing will have to come off to unlatch the door from the inside.Not difficult ,Unplug the unit and remove all of the screws around the top of the housing cover if any,also
rear and both sides will have to come out.When they have all been removed, lift the rear of the top housing cover and pull back.You will be able to see where the two door latches are locked in place.With a screwdriver,you can push up on the bottom latch and the door will open. All this can be done without spilling the milk inside.Just slide the microwave around slowly to get to the screws.The broken part inside should be able to be replaced.Contact repair parts center.
Oct 31, 2007 | Danby DMW139 Microwave Oven
Microwave door won't open when I push the button!
check door open mechanism, any broken change the mechanical parts,
Oct 27, 2007 | DCS CMO-24-SS Convection/Microwave Oven
Worked Off & On if you wiggled the door or
There is a internal locking mechanisim that has 2 or more switches that is usually attached with two or more screws next to the door latch side. Crack open the micro and adjust this by shutting the door then pushing this assy toward the latches untill all the switches look like they are being pushed in fully. If this doesn't solve the problem one of the switches or possibly more are defective. Call a local appliance repair center and get a switch there called micro switches.
Sep 15, 2007 | Goldstar MV-1501 Microwave Oven
Microwave stopped working
Sep 14, 2007 | GE JE1540 Microwave Oven
Viking DMOR205SS Microwave Oven Logo
439 people viewed this question
Top Viking Microwave Ovens Experts
William Miller
William Miller
Colin Stickland
Colin Stickland
Gerry Harvey
Gerry Harvey
Are you a Viking Microwave Oven Expert? Answer questions, earn points and help others
