Question about Yamaha RX-V663 Receiver
Center channel doesn't work - Yamaha RX-V663 Receiver
  • 6,831 Answers
Hello
OK, have a look and see if the unit is still in warranty. If not, then you will need to open up the unit and see if the capacitor on that channel is still in tact. If not, you will need to get it replaced.
This can also be an IC on the center channel.
This is not something i will suggest you try doing yourself. Rather get it done by an professional.
Kind regards
Andrea
Posted on Sep 27, 2010
I have a HTR-3065 receiver and no sound in center speaker
Try changing surround modes - the center channel is not used in all modes. If that doesn;t work, check your speaker settingsw and make sure the center channel is not turned off
Feb 22, 2015 | Yamaha HTR-3065 5.1 Channel AV...
Sony Home Theater System Dav Hdz273 Green-plug speaker plugged into green outlet doesn't work. However, if green plug is plugged into one of the other color outlets, speaker works. If plug anot
Green outlet is the center channel which is not used in all surround modes. Make sure that you have a dvd in the unit, and make sure there is a prologic surround mode selected.
Jan 28, 2013 | Sony HOME THEATER SYSTEM System
HI, I have Receiver Marrantz SR- 5005, the center chanel does not work, please tell me what happened and solution to fix the problem. Thanks
Get the manual and open it up to the part where speakers are defined, then test it/them with tones. Try swapping a different speaker into the center if the current center channel speaker still doesn't work.
Web search "Marantz SR-5005 manual" (note the spelling)
Aug 07, 2011 | Audio Players & Recorders
The center channel is not working. according to the color of the plug that goes into the amp from the speakers. what color goes to which speaker?
Get the manual free...
http://www.retrevo.com/support/Sony-RHT-G2000-manual/id/11167dj888/t/2/
Um, this product doesn't use color coded or proprietary speaker wires nor does it have a connector for Center, which is built into the stand as well as the front speakers.
Jul 13, 2011 | Sony RHT-G2000 System
Onkyo TX-DS696 receiver center channel not working
Can you say explicitly that the Center Channel speaker is defined as something other than NONE?
And how does dialog sound? If it sounds ok you're routing it to the front speakers. This is from the manual...
"For ideal Surround effects, all speakers should be installed. If a
center speaker or subwoofer is not connected, the sound from the unused channel is properly distributed to the connected speakers in order to produce the best Surround sound possible."
Apr 10, 2010 | Audio Players & Recorders
Center channel stoped working on onkyo Dr-S2.2
Have you re-run the speaker definition and level steps? I can't find the manual. Perhaps you could flip a few pages in the Troubleshooting Section.
Mar 19, 2010 | Onkyo LS-V955 System
Center Channel not working on pioneer vsx-d608
Be sure the sound source has a center channel output ie. not a 2 channel source only, try the test tone setup for 5 or 6 channel balance, if no sound from the center channel still then it is looking like maybe the center channel is blown.
Jan 28, 2009 | Pioneer VSX-D608 Receiver
AMPLIFIER CENTER CHANNEL NOT FUNCTIONING
Center channel will not work unless unit is set for Surround or Pro Logic. Make sure center channel's volume is up
Apr 28, 2008 | Yamaha DSP-A3090 7-Channel Amplifier
Center channel
Just to rule out the easy solutions, have you made sure no settings changed? Make sure that you didn't accidentally turn off any surround sound settings or turn off the center channel in the MCACC setup or the like (I have the VSX-D814, so your receiver should have MCACC as well). If you're sure no settings changed and the center channel should be working according to the receiver, then it would appear that the center channel amp went out in the receiver. You can either get a Pioneer service center to take a look at it, or if you're comfortable with electronics, I believe you can get the parts straight from Pioneer.
Dec 10, 2007 | Pioneer VSX-816-K/S Receiver
Yamaha RX-V663 Receiver Logo
47 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
