Question about Microwave Ovens
GE microwave: model 1840 circuit breaker trips when strarting micro wave
  • hwcook822 Sep 27, 2010
    I have changed the 20 amp circuit breaker prior to seeking your help
    I reported to you that I did change the 20 amp breaker prior to me contacting you. The problem still exixt.
  • Microwave Ovens Master
  • 43,501 Answers
There is a short internally in the microwave...the fisrt place to look would be the high voltage transformer, but realistically it could be a rubbed through wore or even the capacitor shorted out...
The best way to check would be to start ohming out everything till you find the short and then fix it...
Just make sure you discharge everything first or you will blow your meter...
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Posted on Sep 27, 2010
    Brigadier General:
  • 3,917 Answers
Circuit Breakers do weaken over usage. It is not usually a time factor as much as a load factor. Each time a circuit breaker trips, it loses its ability to carry the same load as it did previously. In other words, a 15 amp breaker only carries the ability to carry 15 amps once. I recommend replacing the circuit breaker with one that has a matching rating. If you do feel up sizing is necessary, check the load rating of the appliances to make sure the additional size really is necessary. Increasing power to appliances that shouldn't need it increases the risks of potential electrical fires and masking real issues. Try changing it with higher amp breakers.
Please accept the solution if it's helpful. Do get back to us for any further query.
Thanks for contacting fixya.com
Hotpoint model 6671P convection microwave keeps tripping mains panel Fuse when start is pressed. Could this be a problem with a fuse in the Microwave or is is a dud magnatron? How best to test?
Too many watts on same circuit. Plug it into a different outlet and see what happens, not on same circuit. So one that stays live when micro trips circuit breaker.
Mar 05, 2015 | Hotpoint Microwave Ovens
Breaker trips when using microwave. Electrician can't find electrical problem. Could it be the microwave itself?
Answered earlier, another tips is to disconnect the power to the board and see if the circuit breaker holds, if not check the main line circuit.
Jan 31, 2013 | GE Spacemaker JVM1640SJ Microwave Oven
Trips electricity
I would check out your breaker at your box . See what amps it is rated and see what your microwave is . Also your micro wave should only be on 1 breaker with nothing else on it
Sep 23, 2012 | LG Microwave Ovens
GE Spacemaker Microwave JVM1441 BH04 tripping circuit breaker
your power transformer for the magnetron could have a shorted primary power winding,the door safety interlock switch could be mis-adjusted,this normally blows the internal unit fuse,a shorted high voltage capacitor,or diode,a bare wire inside the unit,more than the microwave on that circuit or a weak circuit breaker in the house power panel
Jun 19, 2010 | GE JVM1441 Microwave Oven
Microwave Model WES1450DM1BB I boiled 4 cups of
Owners of a GE WES model might want to look at this blog post.
I'm sure the magnetron overheated and tripped the magnetron's thermal cutout.
I'd strongly suggest taking it back if you can.
Dec 24, 2009 | GE Microwave Ovens
Amana aco 1840 over stove micro wave. heating not working .
FIK IT THE HEATING ELEMENT IS STRIGHT FORWORD AND COST IS CHEAP, GO FOR IT .
Oct 24, 2009 | Amana ACM1580 Convection Microwave Oven
The circuit breaker to the micro wave was tripped and when reset the microwave did not work it just hums also the lights and fan does not work. What's up with that?
the hi voltage transformer is still operating, but the rest is dead, you could remove outer cover and see if there are 2 fuses, most only have 1 fuse, sounds like new microwave time
Oct 09, 2009 | Microwave Ovens
Model JVM 1650sho1
is there a fix for this problem mine does the same thing, i changed the powerstrip and it worked fine for a month, now it's doing it again runs for too minues or so then it trips the circuit breaker in the power strip
Aug 19, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
81 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
