Question about KitchenAid 24 in. KUDI02IRBS Stainless Steel Built-in Dishwasher
Kitchenaid dishwasher KUDS01....
Dishwasher would occasionally completely lose power and then begin working again. Unfortunately, this last time in didn't come back on. Then as we were about to call a tech I shut the door the control panel lit up and it began to hum. But that's it. I accessed the control board and check for continuity and got it in the fuse on the control board. When I reconnected the wires it no longer hummed, but now it won't do anything. I have power, but nothing happens. Is my control board bad?
  • 5 more comments
  • Anonymous May 23, 2008
    Dishwasher
    Dishwasher does not turn on. It may have overheated
  • sssuperd May 23, 2008
    I decided to take the spray arms off and check under the filter. I was able to get the dishwasher to hum again. It bubbles water up and hums. I pulled the dishwasher out and checked the motor. It's not stuck. I unhooked the water line and tried it again. It still bubbles with water. Seems like it's not draining or not sucking in water from the water line. After messing around I went to try it again and now nothing. The power is on but it won't hum/bubble anymore.
    The overheating thing makes sense but what could be causeing it?
  • sssuperd May 25, 2008
    Had no continuity to the water inlet assembly so I replaced it. Still nothing works. It's got to be the control board but I don't want to spend the money and then be wrong.
  • garlamorriss Jul 28, 2008
    I noticed the detergent was not washing out and noticed that only a small amount of water was in the machine when it started spraying . I have been adding water at each cycle and it works well, but what a chore. I believe the water supply is open and wonder if this might be a part needed.
  • jculle1 Sep 15, 2009
    dish washer leaking from electriclal motor pump to washer
    Problem Solver:
  • 3 Answers
The pump is stuck. remove motor.insert plastic pen into bottom of motor.remove impeller by turning counter clockwise.file bottom of impeller stem.put enough washers on the keeper clip to prevent the impeller and the pump housing from binding.reassemble and there you have it!!!!
Posted on Sep 21, 2010
KitchenAid KUDS30FXSS Dishwasher won't complete cycle
Press the Cancel/ Drain cycle for a few seconds. The dishwasher should reset itself. See if this makes any difference. Also first turn the mains power to dishwasher off and back on.
Apr 13, 2014 | KitchenAid KUDS30FXSS Builtin Dishwasher
KITCHENAID DW KUDS30FXSS - 18 months old, will not complete cycles. Runs for 15 mins and stops & lights go out. Cleaning tablet often left in dispensor.
See my problem and solution. Sounds like you, too, are having a problem with the main control board (computer chip that controls the dishwasher), which is apparently a common problem with this model dishwasher. The part can be found here, for $211 (tax + shipping), and they have a 30-day return policy in the event that it does not fix the problem. It's an easy DIY fix. Hopefully this helps!
Aug 15, 2012 | KitchenAid KUDS30FXSS Builtin Dishwasher
Dishwasher starts then pauses and drains.
Fixed! I had the issue where the cycle would start, the KUDS30IXBL8 would hum 4-5 times and then drain. Plastic folk pieces jammed in the disposer. These instructions took a few minutes (only 5 screws and a couple clips) to figure out how to take it apart, and it only took 60 seconds to put back together. How To Repair Dishwashers KitchenAid Repair Chopper Replacement
Apr 25, 2012 | KitchenAid Dishwashers
Kitchenaid diswasher replaced control panel and dishwasher is not working again
Check the door switch, it could be a loose wire or broken door latch switch.
Feb 29, 2012 | KitchenAid KUDS01DJ - Multiple Color...
Kitchenaid kud101tj "cancel drain" light and "Rinse Only" lights are falhing and DW won't start???
Don't know if this will help, but when I had problems with my control panel (lights blinked and nothing worked) I fixed it by disconnecting the power completly from the dishwasher at the fuse box. Leave it off 10 or 15 minutes and then repower. That reset mine and it worked again...has happened several times and each time I could fix it by cutting the power. If that doesn't work, you may need a new control panel.
Sep 11, 2010 | KitchenAid 24 in. KUDS25SH Built-in...
Kitchenaid dishwasher model kuds01
you have a water heating problem. there is a tech sheet taped to the inside of the toe plate
Dec 31, 2009 | KitchenAid 24 in. KUDS01FLBL Built-in...
I have a Kitchenaid Dishwasher about 5 years old. It has completely stopped working no lights power nothing. Water standing in the bottom. We have flipped the breaker but it doesn't seem to be an...
Removed power line from panel board # 11 as seen in appliance parts pros and shocked the board. It came to life and completed a cycle nominally. Then it died again. Tried to shock it again and sometimes it works but most times it doesn/t. Similar posts indicate a transistor failure in the board assembly. The board is easy to replace and costs about 90$. I'm replacing mine. Turn off power. Remove #15 torx screws (6) from the upper cover and lean panel forward. Remove board power . Diagram where connectors go back. Board is held in with 6 clips. Gently push clips open on one side and tilt board to remove board and ribbon cable. Reverse installation.
Sep 01, 2009 | KitchenAid 24 in. KUDS01FLBL Built-in...
Dishwasher fills but does not wash
Is your Kitchenaid Dishwasher a model KUDI02?
If yes, you need to order item 10 on the page link below:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5137276
Good Luck!
Feb 09, 2009 | KitchenAid 24 in. KUDI02IRBS Stainless...
No power on KitchenAid (KUDr01tj) dishwasher
You must have fuse 16 amps or 20 amps.16A is enough if is heater
OK.If heater is broken You must replace it.
Dec 16, 2008 | KitchenAid KUDR01TJ Dishwasher
KitchenAid 24 in. KUDI02IRBS Stainless Steel Built-in Dishwasher Logo
915 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
