Question about Bissell 1715-G Spotlifter Bagless Handheld Vacuum
Need Bissel 1715 wiring schematic. Charging circuit has burnt resistor. Need to know resistor details.
Can not believe NO ONE could answer this.
The R1 resistor basically drops the 9V to around 5V for charging the battery pack. The resistor is a 10 ohm , 2 watt resistor. The other resistor is 220 ohm. This only limits the current to the LED.
The 10 ohm resistor burnt because the battery pack was left to sit too long without use and charging. So the cells shorted causing excessive current through the resistor when you attempted to charge the batteries.
After replacing the resistor, you will need to replace the battery pack before charging. Otherwise, you'll just burn the resistor again.
Posted on Dec 23, 2010
How do i put the wand back together on a rainbow e-series ?
The wire schematics in the handle assembly has four total wires. Two from the hose and two from the Receptacle Nozzle. Take one wire from the hose and one wire from the receptacle and connect together. Take the second wire from the hose and connect to the Switch Handle PN2E PN2. Take the second wire from the receptacle and connect to the other switch terminal. If you need more details, you can download the schematics at Rainbow Vacuum Schematics or you can call us at 800-523-0510.
RainVac
www.rainvac.com
May 30, 2014 | Rainbow E series Canister Wet/Dry Vacuum
I have a bissel proheat upright steam cleaner that will not spray water....why?
I know exactly! You need a new pump. I have 2 of these beauties. They work great till they quit all of a sudden. Did you register your warrantee? Bissel has great coverage. Call the number on your machine!
Sep 01, 2011 | Vacuums
My wife's Viking 6690 smoked this last weekend. I opened up the end where the power switches are and the board had a 0.01 ufd capacitor the blew up. That would be easy enough to repair. However when the...
According to you your machine's resistor burnt out. This resistor is located above the 240 volt capacitor which white base. change the resistor soon. For color code of the resistor you can follow the manual. You can visit also the product website for tech assistance.
Mar 10, 2011 | Vacuums
My pump motor burnt out I need a part number for a replacement one. I have the little green bissel 1729-1. It is about 7 years old.
Good after,
The item# for the pump motor is not listed in the user guide or anywhere else on Bissell's site:
http://www.bissell.com/assets/0/132/134/228/2b48eb5a-312d-43be-b570-9f7012a773a8.pdf
This might be the kind of situation where you should contact your nearest Bissell service center. You can do this by putting in your zip here:
http://www.bissell.com/customer-support/
Let me know if you need more clarification. Hopefully this will get you started. Please rate this solution!
Thanks,
~PCF
Mar 05, 2011 | Bissell 1720-1 Little Green Wet/Dry Vacuum
Burnt out resistor
I'm in the same fix. I learnt that a new pcb is £68 so had the pcb repaired but after the machine has warmed up it now cuts in and out. Like you, I haven't been able to locate a wiring diagram so am trying a last minute lash-up before binning the machine:
A friend suggested that since we all seem to only operate the cleaner on full power I should connect the on/off switch direct to the motor bypassing the rheostat and the pcb as in old fashioned machines.
Aug 31, 2008 | Miele S251i Plus Bagged Canister Vacuum
Bissel Proheat 2x circuit board
Use this link: http://www.4cleanerfloors.co.uk/cgi-bin/product.pl?PID=1278118_amp;brand=Bissell_amp;model=_amp;part=
I had the same problem. Ordered a PCB from Bissel it took 2 weeks to arive. I fitted it, then it blew again, turned out the brush motor was short circuiting. Ordered a new motor it took 10 weeks. I have now had to order the second circuit board.
Over 3 months to get this vac fixed - my advice is - don't buy Bissels!
Jul 09, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell 9400 Carpet Cleaner
I assume you checked the belts to see if any cogs were stripped of of the belt. If ok, then I wuld suspect the brush roll motor, it is any inexpensive part and doesn't take much for it to fail. Undo the top so you can get to it and unhook the belt and see if it still shuts of, if it does, ten replace it, it it doesn't, then there is a problem with brush rolls or belts.
May 13, 2008 | Bissell 9400 ProHeat Upright Wet/Dry...
Need directions for use
http://uk.bissell.com/images/UserGuides/1719E.pdf
This is a similar model to the one you have. Would give you some indication of how to use.
Nov 23, 2007 | Bissell 1715-G Spotlifter Bagless Handheld...
Bissell 1715-G Spotlifter Bagless Handheld Vacuum Logo
403 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
