Question about Bialetti Venus 4 cup stainless steel stovetop espresso maker
I bought 3 days ago this coffee maker after using
I bought 3 days ago this coffee maker after using 2 times (the part where we put the water) the bottom of the coffeemaker became like oxidized with black and white spots into part to save water, is this normal? I'm worried for our health and hygiene awaiting for your answer thank you sincerely Isabella
4 Suggested Answers
co7196
  • 3433 Answers
SOURCE: my bialette does not boil all the water to the top!!!!!
put some vineger in it and heat it up, like a flushing and then rinse out thoroughly. See what that does for you.
Posted on Jun 21, 2009
  • 7 Answers
SOURCE: barely any coffee rises to upper chamber after cooking
It's the gasket!!!!! Store the pot with the two parts screwed TIGHTLY together for about a week. Tighten it up as the new gasket compresses. Problem solved in two weeks or less. Also cook on medium to low heat. High flame seems to make the problem worse.
Posted on Sep 12, 2009
SOURCE: Dark Grey or Black oxidized metal on all surfaces
You cannot wash aluminum items in a diswasher with phosphate based detergent. You'll corrode the aluminum. Best practice is to handwash any aluminum items. Phosphate over time will also etch your glasses, so I suggest always using a non-phosphate detergent - look for Seventh Generation or similar "Eco-friendly" detergents - it will save your glassware too.
Posted on Aug 06, 2010
I have the Mr Coffee Keurig model BVMC-KG5. It has only been used probably used less than 15 times. Now the water just drips out. Cleaned it per instructions which did not help. The machine was bought from...
It depends where the water just "drips out". It could be a leaking hose, or it could be the parts weren't put back together properly after you cleaned it. More information would be helpful.
Download Mr Coffee BVMC KG5 Manual
Feb 01, 2014 | Saeco Odea Go
Cuisinart coffee pot
his EXACT situation happened to me 2 days ago because it gets clogged. Flush and dump clear HOT water threw the tank several times. When I did this, clumps of coffee came out and the coffee maker worked great again. In hindsight..it was my bad because the manufacturers say to run a clear vinegar flush threw them once every 6 months, followed by 2-3 clear water flushes to remove these "clots" that plug it up. Hope this info is not too late and you didn\'t throw your machine out. :)
May 07, 2013 | Coffee Makers & Espresso Machines
We have a Bunn thermofresh coffee maker and I use it about 2 times a week. I have lost the instructions and am having a problem. I remember I am suppose to to put a thermo pot of cold water into the...
Are you leaving the machine on all the time? If not, you need to turn it on and leave on for 15 minutes before brewing a pot of coffee. If you will get the model and date# from the bottom of the brewer and give us a call we will be happy to assist you with this.
Oct 27, 2010 | Bunn NHB Coffee Maker
No water coming through but steamer working
Check the shower screen it might be clogged.
Aug 11, 2009 | Gaggia Baby Espresso Machine
GE 169164 Coffee Pot Not Brewing
Loosen the charcoal filter. You only need to GENTLY place it in. Your problems will all be solved. I just did it 5 minutes ago and i just brewed a 6 cup pot of coffee completely.
Jan 07, 2009 | GE 106591 Coffee Maker
Xp2070
Most likely a defective unit. Hope you got a replacement unit. Mine is working again after replacing the power module and the water flow meter.
Dec 18, 2008 | Krups XP2070 10 cup Coffee Maker/15 bar...
Metal Tasting Coffee
vinegar is not the best it remove calcium in little piece descaler produit melt go buy the descaler produit 1part descaler 1 part water put in water container start the machine after a few second turn it off leave it there for 15 minute repeat untill empty rinse very good after that product is corosif 2 or 3 full rinse thanks for using fixya pierre
Feb 12, 2008 | Cuisinart 12 Cup Digital Thermal Coffee...
Lasting plastic smell
Obviously, this should not be! First, we need to know if the coffee maker is working correctly. If you have a candy/oven thermometer, check the output temp of the water. Be careful...it will be hot! The correct temp should be about 180-185 degrees. If it is hotter than that...return the machine. It has a defective thermostat.
What you can do about the taste: try taking some baking soda and mix it with the feed water. Use about 2 tablespoons in at least two cups of water. Then, add plain water. The baking soda can't hurt you but throw it away and clean the pot. Now, take some water and run it through. If the taste is gone...enjoy! If not, try another unit.
Nov 20, 2007 | KitchenAid Pro Line Coffeemaker Coffee...
Bialetti Venus 4 cup stainless steel stovetop espresso maker Logo
83 people viewed this question
Top Bialetti Coffee Makers & Espresso Machines Experts
Ross Keen
Frank Russell
Frank Russell
Shrikant Shinde
Shrikant Shinde
Level 1 Expert
Are you a Bialetti Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
