Question about JVC RX-8020V Receiver
Subwoofer-no output Yes, it is an active subwoofer, & I have tried it with both subs I have to no avail (both subs work with my other system) I know the subs are not the problem. Thanks, dgh
    Genius:
  • 1,066 Answers
Ther should be a diagram in the left hand corner of display of speakers hooked up, make sure sub is shown right under the left right (and possibly) center speaker icons. under adjust, there is a subwoofer volume level. Under settings there is sub (yes, and no for on and off) there is a sub crossover frequency, and i believe there is also a "LFE" att, which is another subwoofer level.
Posted on May 27, 2008
What are the available subwoofers for sony mhc-gnz88d
you need 'line level input .. left and right'
front speaker to subwoofer input = subwoofer works + speaker outputs Use The ( Wharfedale SPC-8 Active Sub)
Sep 02, 2017 | Sony Audio Players & Recorders
Htddw7600, brand new, sub amp is not working, only way to get any bass sound is to unplug the sub cable from back of main amp and touch it on side of sub out port.
H?,
You have a very good system...one of the best of SONY..SUB does not get activated automatically especially on STEREO mode.DIRECT STEREO Notes • No sound will be output from the subwoofer.
.your system has Dedicated Power Amplifier for 2 Externally Driven Sub-Woofers (200W RMS x 2)..in order to activate the sub woofer amplifier you need to make a selection on the surround modes while you are switching the modes of the surround you will see the speaker position on the display of receiver as well..if you do not see the sub woofer it wont be activated..Sound Field Program (A.F.D) is a good example to test it..
Take care and please Remember to rate/vote and give me 4 Thumbs Up
for Helping out the Community :)
Hope this helps!
Additionally please follow the instruction on your user manual to activate the SUB ,as is follows..
BASS-OUT
Low-frequency (bass) signals can be directed to the
subwoofer and/or the front left and right speakers
according to the characteristics of your system. This
setting also determines the routing of the LFE (low-
frequency effect) signals found in Dolby Digital or DTS
sources.
Choices: SWFR (subwoofer), FRONT, BOTH
• Select SWFR if you connect a subwoofer. LFE and
low-frequency signals from other channels are directed
to the subwoofer according to the speaker settings.
• Select FRONT if you do not use a subwoofer. LFE and
to the front speakers according to the speaker settings
(even if you have previously set the front speakers to
SML).
• Select BOTH if you connect a subwoofer and you want
to output low-frequency signals from front channels to
both the front speakers and subwoofer. LFE and low-
frequency signals from other channels are also directed
to the subwoofer according to the speaker settings. Use
this function to reinforce low-frequency signals using
the subwoofer when playing back sources such as CDs.
Jun 23, 2011 | Audio Players & Recorders
I have a sony HTDDW7600, i cannot get the dedicated subwoofer amp to work. The fan is running on it, but for some reason the only way i can get it to do anything is to unplug the cable that goes from the...
H?,
Hope this helps!
BASS-OUT
sources.
SML).
Jun 23, 2011 | Sony MUTEKI HTDDW1600 Theater System
Yes does anybody know how to hook up a two channel amp to two 12" subwoofer's
Active or passive subs (size is irrelevant)? Do you have the manual(s)? It might talk about that. If active subs, get an RCA splitter cable and share the subwoofer output.
Jun 14, 2011 | Pioneer 750-Watt Home Theater System,...
I have the Subwoofer plugged into the output and have it turned ON but it's still not working!
It only drives a self-powerd sub.
The manual...
http://www.retrevo.com/support/JVC-RX-8010VBKC-Receivers-manual/id/315dj079/t/2/
Page 17:
Setting the Subwoofer Information
Register whether you have connected a subwoofer or not.
Before you start, remember....
• There is a time limit in doing the following steps. If the setting is canceled before you finish, start from step 1 again.
On the front panel ONLY:
1. Press SETTING repeatedly until "SUBWOOFER" appears on the display.
The display changes to show the current setting.
2. Press CONTROL UP / DOWN to select "YES" or "NO."
• Each time you press the button, the display alternates between "YES" and "NO."
YES: Select this when a subwoofer is connected.
NO: Select this when no subwoofer is used.
Note:
You cannot use SUBWOOFER OUT ON/OFF on the front panel (see page 14) and adjust the subwoofer output level (see below) when "SUBWOOFER" is set to "NO."
Then continue with setting its relative level and other things.
Feb 06, 2011 | JVC RX-8010V Receiver
No sound out of subwoofer
Connection from receiver subwoofer output jack RCA plug male go into your powered subwoofer low level input with other end of cable, then you need to select Subwoofer YES/NO on the JVC receiver speaker setup menu option, select YES if this is a powered subwoofer you are using, should power up the subwoofer, may have to adjust a test tone balance for multi speaker output also, try trimming up on the subwoofer channel to initiate the signal on if the sub has an auto-on feature.
Feb 07, 2009 | JVC RX-5020VBK Receiver
Sony Active Subwoofer noise
The circuit that should be turning the sub on and off based upon the presence of an audio signal is not working correctly and the sub is trying to reproduce 60 cycle hum. The unit needs service.
Dan
Mar 09, 2008 | Audio Players & Recorders
Subwoofer: Active or non active?
Hello Smegboy,
Yes, you are right. This receiver is rated at 100WRMS output in all 5 channels (2-front, 1-center and 2-surround) while in Dolby Pro Logic operation. The subwoofer output is line level only (not amplified), which means you need a powered subwoofer to be connected to this output. A non-powered subwoofer could be used but, you need an additional amplifier connected to the subwwofer output from the receiver to drive it.
Let me know if this helps.
cancerags
Dec 29, 2007 | Technics SA-AX710
Cerwin vega ht-10d subwoofer won't work in yamaha reciever
Well, as I know, your Cerwin Vega subwoofer is designed for use with stereo systems. Therefore, it has only 2 channels for input, and 2 channels for output as well. However, you can try this out; the first thing I suggest is that you hook up your main front channels through the subwoofer. All you have to do is to connect the subwoofer input to the front channel output on the amp, then hook up your front speakers to the satellite output on the subwoofer. As long as you make sure that system is working on 8 ohms, I believe this can activate the subwoofer.
Sep 15, 2007 | Athena AS-F1 Main / Stereo Speaker
JVC RX-8020V Receiver Logo
252 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
