I have a 49.F05 error message on my HP Laser Jet P3005n printer
Soulvisitor
  • 1113 Answers
SOURCE: Printer HP Laser Jet 7400
A critical firmware error has occurred that caused the processor on the formatter to abort the operation.
This type of error can be caused by invalid print commands, corrupt data, or invalid operations.
In some instances, electrical noise in the cable can corrupt data during transmission to the printer.
Other causes include poor quality parallel cables, poor connections, or specific software programs.
99 % of time it is a corrupt file or poor connection, I have also known it to be the firmware, dimm or formatter board on rare occasions.
Recommend check hp web for any firmware updates, check connections and that driver is installed impecablly and use known good files to test.
Posted on Dec 27, 2007
Joed911
  • 4338 Answers
SOURCE: My HP color laser jet
This is what HP says about error 49:
Control Panel Message:
49.XX.XX
PRINTER ERROR
To continue
turn off then on
Description:
abort operation. This type of error can be
data, or invalid operations. In some cases,
Other causes include poor-quality parallel
cables, poor-connections, or home-grown
programs. On rare occasions, the formatter
is at fault, which is usually indicated by a 79 Service Error.
Recommended Action:
1. Turn the printer off then on.
2. Press Stop to clear the print job from
the printer memory.
3. Turn the printer off then on.
4. Try printing a job from a different
software program. If the job prints, go
back to the first program and try
printing a different file. If the message
displays only with a certain software
program or print job, contact the
software vendor for assistance.
5. If the message persists with different
software programs and print jobs,
disconnect all of the cables to the
printer that connect it to the network or
computer.
6. Turn the printer off.
7. Remove all memory DIMMs or thirdparty
DIMMs from the printer. (Do not
remove the firmware DIMM.)
8. Remove all EIO devices from the
printer.
9. Turn the printer on.
10. If the error no longer exists, install
each DIMM and EIO device one at a
time, making sure to turn the printer
off and on again as you install each
device.
11. Replace a DIMM or EIO device if you
determine that it causes the error.
12. Remember to reconnect all of the
cables that connect the printer to the
network or computer.
13. If the error persists, upgrade the
firmware compact flash card.
14. Replace the formatter and calibrate
the printer.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Dec 11, 2008
  • 327 Answers
SOURCE: hp laser jet 2840 engine error
its the problem of the spinning wheel which pulls the paper that is called engine and that is either getting blocked by any dust particles or got broken internally and has to be cleaned or replaced to make it proper.
thanks.
Posted on Dec 15, 2008
leroyal
  • 2120 Answers
SOURCE: 49.c02 service error message on HP laserjet 4100
General printer error. Unplug the power cord for 10 seconds.
Posted on Feb 06, 2009
wheatlandsvc
  • 1110 Answers
SOURCE: HP Laser jet 4350 dtn printer gets 59.40 error. I
Print Cartridge Motor Error.
Try removing then re-installing the cartridge. If that does not work then you will need to try a different toner cartridge as the toner cartridge is "locked up". These are the most common solutions. If none of these work then you have a cartridge drive problem and will need to contact a service center.
Posted on Jan 05, 2010
Testimonial: "It worked. Thanks. I' just FIXYA again"
HP COLOR LASER JET 2605 PRINTER 49 ERROR MSG DISPLAY SOLUTION
49 errors are most commonly caused when the printer receives a print job with commands it does not recognize. You can try updating the firmware as this will often resolve the error. Go to HP's website to find the most recent firmware, however this model is fairly old and likely the firmware update will be fairly old.
Sep 25, 2014 | HP Laserjet 2605dn Workgroup Laser Printer
Error message 49.4602 on HP Laser Jet colour CM4730MFP
Need to load the latest firmware to resolve the issue.Go to hp.com..download the firmware..upload it.. Read carefully read me file before uploading.. if any thing goes wrong, formatter will far damaged permanently
Apr 09, 2014 | HP Hewlett Packard LaserJet P3005n Printer
Manual laser jet 4
The paper size selection knob or MP paper size does not
match the installed paper or more than one sheet of paper
was picked up.
Oct 23, 2011 | HP Hewlett Packard LaserJet P3005n Printer
Hp laserjet 3005n printer continuse printing error comming 49.2f9d
Hello, 49 errors can be troublesome and difficult yo solve, this relates to either an hardware or application error.
For more on 49 errors follow the posted link.
Support 49 Errors CLICKHERE
Feb 01, 2011 | HP LaserJet P3005n Printer
Printer error :"49.C02 service error " message
i think this caused by your windows is not genuine
Jan 14, 2011 | HP LaserJet 4700 Printer
49.460E Service Error ...and when it come on it freezes with a diplsy "ready", but could not respond to any key buttons.
Hello, 4 Errors in HP Laser printers are very difficult to resolve, since your printer is "freezing" likely the formatter board will need to be changed. For more information and troubleshooting guide, follow the posted link.
Aug 02, 2010 | HP LaserJet P3005n Printer
HP Laser Jet P3005 Printer is printing very slow
It is usually dirty and old fuser. It would takes longer time to heat up and also triggering error messages. Try changing that.
Feb 15, 2010 | HP LaserJet P3005n Printer
HP LASER JET ERROR 49
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=110&prodSeriesId=3377075&prodTypeId=18972&prodSeriesId=3377075&objectID=c01571503
May 15, 2009 | HP Office Equipment & Supplies
49.FF95 SERVICE ERROR
Please look on: http://www.fixyourownprinter.com/
There are much solutions of this problem listed ...
For example this (it see good):
http://www.fixyourownprinter.com/forums/printer/46157#1
HP Laser Jet 4250n by TLYNN (3/20/07 12:22 PM) reply + / -
Anybody know the error code "49. FF95 Service Error"
We can't get around this...
Firmware Error 49 by Stephen (edited 3/20/07 12:29 PM) reply + / -
It could be a bad job.
First disconnect it from your network and any PC it might be attached to.
Power cycle it, then if it goes to ready status try the built in test pages, do they work?
If the printer will go to ready status and you have a parallel cable with the proper connector, then you can try upgrading the firmware from a PC, you can also try to upgrade the firmware over the network.
More reading:
http://www.fixyourownprinter.com/search/forums?f=&q=49+4250
Re: HP Laser Jet 4250n by TLYNN (3/20/07 12:59 PM) reply + / -
Still won't go back to ready status. Turns on to the same error code....
Cold Reset HP Laser Jet 4250n by Stephen (3/20/07 1:03 PM) reply + / -
Try a cold reset, it will reset the JetDirect settings, but it's the next step.
Cold Reset:
Power off printer, wait about 5 seconds, then power it on, when asterisks start appearing on the display press and hold the check mark until all 3 lights come on solid, then use arrow keys to find cold reset and push check mark to perform the reset.
Re: HP Laser Jet 4250n by TLYNN (3/20/07 1:06 PM) reply + / -
Thank You so much for your help... but that didn't work either. Same error code showed up.
Re: HP Laser Jet 4250n by Stephen (edited 3/20/07 2:27 PM) reply + / -
Then you probably need to replace the formatter.
Do you have another printer you can swap parts with?
There is a slim chance the memory DIMM is bad, you can try it with the DIMM removed, if there is more than one DIMM you can try installing just one and then the other.
A 49 error indicates that the formatter could not understand or execute an instruction within a file or cannot interface with an accessory, DIMM, or EIO device. Troubleshooting 49 errors is done through process of elimination. First determine if the printer functions in a stand-alone mode then test communications to the printer.
These errors can be divided up into two categories; the associated troubleshooting depends on the circumstance the 49 errors are occurring.
A 49 error is always followed by Hexadecimal numbers, for instance, 49.00FF. The Hex code is a memory address. Most Hex codes are not documented.
Re: HP Laser Jet 4250n by dmzcompute (3/20/07 2:26 PM) reply + / -
I do not see anywhere where the printer has been disconected from everything. If you have not done so already disconnect every cable from the printer with the exception of the power cable and turn the printer back on and see if you get the error and if not report back here for further instructions.
Re: HP Laser Jet 4250n by Stephen (3/20/07 3:28 PM) reply + / -
You might also try disabling the embedded JetDirect.
To disable the embedded LAN port
Turn the printer power off.
Power on the printer and watch for the memory count to begin.
Hold down the SELECT (Checkmark) button, when you see the memory count begin.
Continue holding down the SELECT (Checkmark) button until all three printer control-panel lights flash once and then remain on. This might take up to 10 seconds.
After the message SELECT LANGUAGE appears on the display, press the UP ARROW button or the DOWN ARROW button until EMBEDDED LAN DISABLED appears on the display
Press the SELECT (Checkmark) button. The printer then continues its power-on sequence with the embedded LAN disabled.
If this works the JetDirect built into the formatter is bad, you can either replace the formatter, or buy an JetDirect to install in an EIO slot.
Re: HP Laser Jet 4250n by Trev Pearson (3/20/07 10:08 PM) reply + / -
The only other thing to try, before spending money, is to get the network administrator to clear the print queue for that particular printer and then turn it on.
The theory being that a 'corrupt' print job is still in the system and as soon as the printer is turned on, that 'corruption' floods the network card with garbage which promptly goes 49.
If the printer comes 'ready', great. Then do a firmware upgrade. If not, then you will have to spend money on a new formatter.
Regards
Trev
Re: HP Laser Jet 4250n by roadrunner178 (6/21/07 2:09 AM) reply + / -
hi.
With a cold reset ,my problem solved.
try this as a first solution.
thank you
Re: HP Laser Jet 4250n by Anonymous (7/31/07 1:20 AM) reply + / -
THANK YOU WERY MUCH
FROM TURKEY
ZAFER
Jan 02, 2009 | HP LaserJet 2420dn Printer
124 people viewed this question
k24674
