Question about Dome SCAN SPEAK D2008/8512 3/4" TEXTILE TWEETER Car Speaker
Greetings i have a pair of spendor sp2 speakers and one of the tweeters are out? a scan speak d2008/ 8512 can this be fixed or 80 bucks for a new one? thank you ernie
Polk Tweeter on RT 1000i
it sounds like its the cross over
Mar 25, 2013 | Polk Audio RT1000I Speaker
Replacement (upgrade) tweeters
go to a radio shack if not in stock ..than order one...i would suggest a piezo style ...about 8 bucks each...
Apr 22, 2011 | Cerwin Vega Cerwin-Vega V-12F Floor...
Tweeter not working
Check the continuity of the removed tweeter with a VOM meter (I use an original Heatkit MM-1 available on eBay for $20) and do the 1.5 volt battery click & scratch test mentioned above.
Celestion A3 tweeters (also used in the A1 and A2 speakers) or the replacement diaphragms are no longer available from Celestion. A1 speakers show up regularly on the United Kingdom eBay website for $300 or less and are small enough to economically ship to the USA. You would also end up with a midrange spare speaker (assuming it is the same as in the A3 cabinets)
The part number for the A series 3 bar tweeter is T4969/P. The 3 bars refers to the 3 bars in the casting to protect the dome. I got this number from the box of my spare tweeter I have the earlier 1 bar castings in my A3's.
Go to www.ersatzteil-versand.at do an "artikelsuche" (article search) for the number T4969/P and something extremeley similar shows up except that they list the manufacturer as Onkyo. The part number and description are so similar to what is printed on my spare tweeter box it would be worth 81 euros to see what shows up.
I have designed an adapter plate for either a Scan-Speak Revelator Tweeter D2904/710002 4 ohm, 1" soft dome, 70 mm diameter magnet, $220 or a Vifa D27TG35-06 6 ohms, 72 mm diameter magnet, 91 db, $37.50..Both are available from:
http://www.speakercity.com/ in Burbank, CA
I only modeled the front flange of the tweeter to save time. I have not built any of these yet but the price would probably be $400 for a pair of adapter plates and speaker flange modifications. But when you are done you would have replaceable tweeter for a long time to come. The 2 protective bars are drawer handles available for $3 each.
Other possibilities are:
http://www.audioloudspeakers.co.uk/boultons.shtml voice coil rewinding in the uk
http://www.speaker-repairs.com.au/coils.htm voice coil rewinding in australia
http://www.speakerex.com/diaphragms_new.html in Florida can rebuild the woofer and replace the midrange but no longer have the 4 ohm diaphragm for the tweeter.
If you want the drawings (and 3D geometry file necessary for the machinist to make the curved edges) for the adapter plate and tweeter flange modification contact me at mercedes280se-4@yahoo.com
Feb 11, 2010 | Celestion A3 Speaker
2001 cherokee front speakers not working
well your deck might be bad, you could have a lose connection in your wiring to your speakers, you might not have a connection to your speakers, or your speakers could be bad.
Jun 28, 2009 | 2000 Jeep Grand Cherokee
2002 Grand am gt monsoon, hook up rear aftermarket speakers
You have to test them, either should work fine (as in use either pair) if that doesn't work connect one pair at a time and listen for the difference, one pair might be for factory midrange and other for tweeter.. there are two different wiring configurations...
Jan 28, 2009 | 2002 Pontiac Grand Am
Tweeter soldering snapped !
Do you mean the support wire that comes from frame of speaker to back of tweeter? More info. PIC if able pls.
Feb 08, 2008 | Hifonics AS6.5Ci 6.5" 2 Way 125W RMS...
KLH tweeters stopped working
hi, have u first disconnected the tweeters and then checked, as if its on a cross over, the tweeter is in series with a capacitor,if u have a ohms meter or a continuety tester check the tweeter coil if its open,secondly you can have the coil replaced, check if u can get one before buying a new,let me know
Jan 11, 2008 | KLH HT-9930 System
My tweeter in my atlantic 500 isnt working.
If you did not hear any sound from the tweeter, but you did on the new one, the old one is bad my friend. I tried to find an original replacement for you but I could not find it. I did however speak to someone on your behalf about your problem. I was informed that if you call them at 1-877-732-5374 and give them the dimensions, they can get you a nice not too pricey replacement that should sound good to you. I was told they go for about 70 to 100 bucks. Good Luck
Jun 05, 2007 | Wharfedale Atlantic 500 Main / Stereo...
Car Audio & Video Logo
139 people viewed this question
Top Dome Car Audio & Video Experts
xxxxxx xxx
Are you a Dome Car Audio and Video Expert? Answer questions, earn points and help others
