Question about Canon ZR80 Mini DV Digital Camcorder
Nothing on screen
Hi...when i turn the mini on I get all the information on the screen, but nothing else...the machine turns on fine, but nothing on the focus..could it be the lense???
  • 2,039 Answers
Check this link.
Posted on May 23, 2008
My HP mini screen will not turn on but my computer will turn on , the power light turns on but the wifi light is orange? But mainly the screen will not turn on. How can i make it turn on?
Hi craryrayann...
Plug your mini into an external monitor and see if the screen is the way it is suppose to be...if so then you lcd screen needs replacement.
If it does not look normal...then replace the backlight/inverter
Please take time to rate me
Sep 11, 2011 | HP Mini 1000 Netbook
I turn the machine on, add the kcup and water...lights blink but nothing brews, then turns itself off...B30 unit; please advise Thanks
Here is a tip that I wrote that will give you some things to try that will help you get your Keurig coffee brewer working again.
Keurig Coffee Brewer not making a full cup of Coffee
heatman101
May 16, 2011 | Keurig B30 Mini Coffee Maker
I have a Dell Inspiron 10 Mini Netbook. It was working fine, I was online but started doing something else so it powered down, the screen going black. When I went to use it, it would not come back on. I...
try powering on with power adaptor connected, if works, battery needs charging, if not holding charge, battery needs replaced, if under warranty call DELL support to request onsite tech to repair.
Oct 10, 2017 | Dell Inspiron Mini 10 Netbook
HP mini 1000 with a blank screen
Mini PCs, aka Netbooks often use solid state memory, which breaks down after a time, and can become unusable, especially if you're not shutting down properly. It tends to last just fine, if you power up and down normally, but after, say, over a year of use, flashdrives and other solid state memory cores will corrupt or lose data. You may have to have the information on the disk recovered.
I checked and your Netbook comes with either an 8, 16, or 32 GB solid-state drive, or a hard-disc drive ranging from 60 to 160 GB. Hard discs can also be temperamental if they get banged around a lot. It's a hard decision, because solid state can handle abuse, but degrades, while the magnetic discs degrade slower, but can't handle too many bumps. Your best bet is to contact the manufacturer, and see if they can find the problem. It may simply be a problem with windows. Your machine may run Windows XP or Mi, the latter of which is based on Linux.
DON'T take the battery out. Only take the battery out, if you're using the machine while plugged in, unless the battery needs charging. Leaving the battery in all the time can shorten the life of the battery. The machine needs to always have a power supply, especially for the solid state memory to not degrade.
My honest solution is to give it some time to start up: however long it needs, but if it takes more than an hour, it's not really an easily fixable solution, and will require manufacturer action, or replacement.
Oct 23, 2009 | HP Mini 1000 Netbook
My dell Crashes within minutes of turning it on!
This could be a multitude of things, but the first thing that comes to mind is an overheating problem.
To rule out other things, remove and reseat the RAM, HDD, CD/HDD drive, Battery, Wi-Fi/BlueTooth mini adapters, etc.
Also, for further clarification, is there any error indicated on the screen prior to the machine turning off?
Thanks,
Rob
Mar 06, 2009 | Dell Inspiron 1525 Notebook
O2 Pocket Pc stopped working after upgrade installation
flash arom directly from bootloader mode (by pressing camera ****. and keep press. then press with sylus the soft reset ****. ,
then the 3 colors shows with usb in left bottom site of screen of device then run the flash utility normally .
May 06, 2007 | O2 Xda II mini
Canon ZR80 Mini DV Digital Camcorder Logo
69 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
