Question about GE Profile Spectra JGBP90 Gas Kitchen Range
Converting GE XL 44 Gas range from propane to natuiral gas
I have a GE XL44 Profile gas range I want to convert from Propane to natural gas. I have the 4 natural gas burner orifices and have read the blurb on converting, BUT:
1) How do I get at the orifices in the stove that I have to change?
2) Where is the regulartor in which I have to turn around the "plastic part"?
3) What do I look for when adjusting the gas flow into the oven?
billyonghui
  • 3 more comments
  • Anonymous Sep 25, 2008
    I have same problem how did this get answered?
  • palobo6676 Dec 01, 2008
    I already have the the 4 stove top orifices changed but how do I change over the oven for baking, this is a GE XL44 Model
  • boblaituri Jan 11, 2009
    I need instruction on converting oven ,my burners are done.
  • redfish123 Jan 12, 2009
    I have almost same problem but am converting from natural gas to propane. It is same model GE. Where can I find the new orifices for propane
  • btdor Feb 19, 2009
    I have the same problem with or xl44 range. We easily converted the upper burners by changing the orifices on located in the back, but what do you do for the oven? Everything I bake gets black soot all over it...Did you get an answer on the, or the conversion booklet? Thx, Bar
I needed parts for my GE XL44 propane converted stove. This site was very helpful. I found the part and there is online live help or toll free help. Go to: AppliancePartsPros.com
Thanks,
nnb704
Posted on Jan 29, 2009
Ge j2s968 convert to propane
On the back of the range there should be a conversion kit with intructions on how to convert from natural gas to l.p. good luck..
Nov 05, 2011 | GE Profile Spectra JGBP90 Gas Kitchen...
Gas stove need to switch to propane
Hotpoint supplies the orifices and instructions with each range for converting. It is just that it is hidden, they attach it to the gas regulator. The regulator is near the bottom back typically. Here is a cut out from your use and care manual.
CONVERTING TO LP GAS (or converting
back to natural gas from LP)
This range leaves the factory set for use with natural
gas. If you want to convert to LP gas, the conversion
must be performed by a qualified LP gas installer.
The conversion instructions and LP orifices can be found
attached to the range next to the pressure regulator.
Keep these instructions and the orifices in case you want
to convert back to natural gas.
May 13, 2010 | Hotpoint RGB745 Gas Kitchen Range
Convert GE XL44 from LP to gas
replace original orifices and adjust regulator to natural gas
Dec 30, 2009 | Kitchen Ranges
Converting a Propane Thermador 36" range to Natural Gas
I have the same range but need to convert it from natural gas to propane....we should trade...9j antiques
Aug 31, 2009 | Thermador PGR366 Gas Kitchen Range
I have a ge profile xl44 oven and do have the
I just converted aXL 44 from natural gas to propane and I don't have a manual for it do I need to do anything for the oven part?
Also how do I light the pilot light or do I need to?
Greg
Jun 28, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Natural Gas to Propane for Ge xl44 Gas range
The kit is located at the rear of the range right near the gas valve, there are probably 5 spuds and an extender for the large burner, directions are with the range. For the bake and broil you will need to tighten the brass orifice nuts down as tight as possible, also the brass nut on the gas valve needs to be reversed
your local LP dealer should be able to do this for you if you are uncomfortable doing it yourself.
Jan 27, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
GE44XL propane to gas
contact the gas company and they will install the kit needed for the conversion. I hope this helps.
Jan 21, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
GE XL44 propane to natural gas conversion.
your going back to natural from LP??? of so tyhere is no new orifice , but hte "hood" on the end of the bake, needs to be adjusted out"loosened", LP the "hood" is secured snugged down,
Jan 11, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
GE XL44 and soot from burners
propane burns very dirty.you need to remove the burners and orfices and clean them good with oven cleaner.make sure their rinsed and dried well before installing,this should solve your problem.
Nov 08, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
1,688 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
