Question about Samsung LE40R73BD 40 in. HD-Ready LCD Television
Television went blank but still has sound turned it off then on and it seems ok but what could be the problem
Were you watching television through antenna or video through HMDI or video RCA cable when it happens? If it happened only once, then I wouldn't think that's a serious problem. Most TV firmwares today are based on complex linux OS. Would expect a software glitch or two.
Check whether your TV manufacturer had any firmware update.
Posted on Sep 27, 2010
I have Samsung 46" rear projector TV the TV just went blank
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
May 8, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV With a Black No Image on the Screen ... the show I'm watching and then it turns ...
LED TV Repair Main Board Overview Blank Screen-TV Has ...
? 2:57
https://www.youtube.com/watch?v=-TU2KSuect4
Mar 4, 2014 - Uploaded by ShopJimmy.com
i have SAMSUNG led tv with NO picture and there is back light and sound OK, ... Apparently the TV was on ...
Dec 15, 2015 | Samsung Televison & Video
Bauhn 80cm tv model no. ATV-32HDC1N
Could be internal power supply failure.
Dec 25, 2013 | Televison & Video
MY SONY TV LCD MODEL KF-50WE620 screen went blank. When I turn on the green light it blinks on 40-46 times every second, then turn to red color to Stand mode and blinks for 160 times, then move to power...
There is no reply from the jungle IC301 (data bus is busy, shorted to ground, or held high), IK video path is defective.
Might check fuse, R607, Q601, IC601, R612 and VDR601 (should show open).
Tom Miller
Broadcast Eng
Mar 04, 2011 | Televison & Video
BELL HOWELL 17462 PROJECTION SET TV SCREEN WENT BLANK
Do you still have sound? Can you see light at the back of the set when the screen is blank -if so the bulb is ok and you've just lost video.
Oct 14, 2009 | Televison & Video
Blank Screen With Sound!
in 1965 a color tv was a years wage for an electrician.
they are cheap today.
yours has an 80 volt power supply problem.
May 28, 2009 | Vizio P4221 Television
Mitshubishi VS-6041 No picture, sound ok
It has been my experience with that model mitsubishi that the usual culprit is loss of vertical sweep. If the beams in the picture tubes stops moving up and down this is detected by the micro processor and the video is blanked, but the set is not shut down. The usual cause of loss of vertical sweep is bad solder connections on the deflection yokes or a failed vertical output IC.
May 27, 2009 | Mitsubishi VS-6041 60" Rear Projection...
Screen went blank sound ok
Do yo have the remote? Do you have the manual? Manuals are usually available online.
If you are feeding the Toshiba with cable wiring then the problem is with the Toshiba. Maybe something as simple as the wrong input is selected on the remote control. If you are feeding the Toshiba with audio and video cables then the input to the Toshiba would be suspect. Either cabling (the inputs and outputs are plugged in wrong. If you changed anything I would retrace your steps.
Let me know by clicking on 'ask me' and if solved please do the rating. Thanks.
Jul 08, 2008 | Toshiba 65H80 65" Rear Projection...
BLANK TV
hi, what you need to do is find the source button or av button on your remote control as it sounds like its changed source this causing your problem. As you probably know your telly has many inputs for dvd vcr cable or sky but these plug into one of the inputs in the back of telly. Usually the problem is just that your on the wrong input channel like av1 instead of av2 or rgb their are many inputs so you might need to press this button 2 or 3 times till you get the right channel, i dont mean 1 to 9 channels i mean input channel like rf input or av input. This depends on what your getting the signal from if its cable and its plugged in via scart lead then it will be an av input but you might have av1 av2 av3 av4 this depends on your telly.
If your still having problems then give me a shout back ok best to check all the leads are in the telly correct as this will cause the problem your having ok.
Let me know how you get on ok or if you need further help
May 14, 2008 | Philips 32PFL5322D Television
Akai Plasma 42" PDP4294
I had the same problem I was told to unplug then reset but still no luck. Mine have been broken since Aug 2006 and seems like it's so hard to find somebody to fix it. Please let me know if you fix yours.
Jan 21, 2007 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Samsung LE40R73BD 40 in. HD-Ready LCD Television Logo
107 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
