Question about Maytag Kitchen Ranges
OUR ELECTRIC RANGE MODEL MWE5770AAA IS BEEPING AND SHOWING AN 'F1' IN THE READOUT
  • Maytag Master
  • 3,051 Answers
Hello there
Here is the best way to troubleshoot this ill wr4ite it the best i can for you
* Here is a simple test that you can do to determine whether the clock or the touchpad are defective when the display reads F1:
- Disconnect power to the range.
- Gain access to the back of the ERC (electronic range control, or "clock").
- Unplug the touch pad ribbon connector from the ERC. This will be a flat wire about 1 ½" to 2" wide.
- Make sure everything is clear and will not short out when power is turned back on. Replace any covers removed to gain access to the ERC.
- Turn the power back on to the range.
- Watch for the F-1 and listen for the beep.
- If you get the F-1 and beep, replace the ERC.
- If after approximately 60 Minutes you do not get the F-1 fault, replace the touch pad.
NOTE: Some models incorporate the touch pad and the clock control as one part so F1 = bad clock control.
Warning: If you do not feel comfortable doing this test or making this repair please contact a qualified appliance repair technician.
Posted on Sep 27, 2010
Testimonial: "THANK YOU; MOST HELPFUL. IT RELIEVES ME THAT IT IS NOT A DANGEROUS SITUATION"
Kenmoe Electric Cooktop and started beeping and fan is running
A F1 code is a bad ERC electronic range control.(clock).
The ERC must be replaced.
Mar 18, 2010 | Kenmore Kitchen Ranges
Error Message F1
no your control is out and needs to be replaced. the alarm is in the control itself. most ge ovens cannot be used, will not go into the bake or broil mode
May 15, 2009 | GE Kitchen Ranges
My kenmore oven is beeping and will not stop. the display shows F-1.
Please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacment of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
KENMORE Range/Stove/Oven Fault Codes – 362 Series (General Electric)
F1 = Stuck Touch Pad Key - Replace Electronic Range Control (ERC).
KENMORE - 911 Series (General Electric/Roper)
F0-F1-FF = Failed transistor in Electronic Range Control (ERC).
KENMORE Range/Stove/Oven Fault Codes- 665 Series (Whirlpool)
F1-E0 EPROM Error - Electronic Range Control (ERC).
F1-E1 EPROM Error - Electronic Range Control (ERC).
F1-E2 U/L ERC Errors - Electronic Range Control (ERC).
F1-E3 Fuel Type Fail
Kill power 30 seconds-Cancel-Start/Enter-5 seconds-Should see “E” for electric-
“9” for gas-If code changes again-replace Electronic Range Control (ERC).
KENMORE - 790 Series Electronic Oven Control (Frigidaire)
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal checksum error.
Runaway Temp = Replace Electronic Oven Control (EOC).
Kill power 30 seconds - if error returns - replace Electronic Oven Control (EOC).
Dec 16, 2008 | Ovens
I need help with my frigidaire self cleaning confection range it is flashing F1
Hello traden,
Welcome,
You said, What do I do to get my range to stop beeping and flashing F1
Please send me your complete model number including that number at the end of the model number.
pull open the storage drawer and you will find a sticker down low on one side.
Mean while you may try unplugging the range for 5 minutes and that should reset the system if it is only a glitch!
Waiting for your Complete Model number.
Huuum
Oct 09, 2008 | Frigidaire FEF366 Electric Kitchen Range
F1 service code
The owner's manaual states that F1 means Control Malfunction.
The manual recommends the following:
Press Oven cancel pad or disconnecting power supply may eliminate F code. If failure continues contact an authorised dealer.
Aug 02, 2008 | Amana ACF3325AS Dual Fuel (Electric and...
F1-6 Fault Code
This code is in responce to a fault/failure in the lower keypad assembly. It is possible the keypad was bumped.
Maytag Gemini fault codes.
Fault code Suspect area Fault code Suspect area
F0 - 0 None
F1 - 1 Runaway cook upper oven
F1 - 2 Runaway cook lower oven
F1 - 3 Runaway clean upper oven
F1 - 4 Runaway clean lower oven
F1 - 5 Keypad cancel upper
F1 - 6 Keypad cancel lower
F1 - 7 Keypad disconnected
F1 - 8 Keypad shorted
F1 - 9 Slave
Dec 29, 2007 | Maytag MER6769 Gemini Electric Kitchen...
Oven will not turn off.
Sounds like an oven control problem. Give me the complete model # from the sticker on the range so I can look into this for you.
Nov 13, 2007 | Kitchen Ranges
-F1- is showing on panel
F1 ERROR IS A KEYS STUCK ERROR...If you are not technically sound i advice that you get it replaced by a technician..They keypad is not very expensive..If you want to try doing it yourself then let me know..
Nov 02, 2007 | Kenmore 91112 / 91114 / 91117 Electric...
Kitchen Ranges Logo
211 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
