Question about Mantis 2-Cycle Tiller
Tiller been sitting several yrs; won't start.Cleared gas line.Won't fire.What to do?
    Scholar:
  • 71 Answers
The problem is likely in either the carburetor (needs rebuild kit) or the fuel lines (deteriorated).
Rebuild kit: available directly through Mantis or through a number of sources including ebay. This is a relatively inexpensive and can be a DIY project. Cost around $15.
Fuel lines: become cracked and allows air to get into the system. Check closely (especially within the carburetor where line attaches to the fuel filter pickup). Again, an inexpensive project in which parts can be alternatively picked up at some of the bigbox stores such as Lowes Hardware (in the trimmer section).
Posted on Sep 27, 2010
2 year old gas in tank. tiller won't stay running
When you drained the gas from the gas tank did you also take the carb apart and clean it. There should be a bowl that the fuel line from the gas tank goes to. There is a float in that bowl that has to go up and down to regulate how much gas goes into the engine. You may have a build up of varnish from old gas on the piece that the float moves up and down. Also there should be an idle jet that you screw in and out to adjust the idle. That also could be junked up.
Apr 18, 2013 | Ariens 902032 - 12"/22"/24" 6HP/169cc...
Craftsman tiller won't start unless I manually prime cylinder with gas. There is no primer bulb. Can I retrofit a primer bulb in the gas line?
Hi
You can insert a primer system into your fuel system
Just follow the fuel flow below
Please take time to rate me
Bud
Oct 23, 2012 | Craftsman Garden
My MTD Yard machines riding mower won't start.
Probably dead gas from sitting too long. Dump it out & put in fresh gas.Could have moisture in it. Pull out spark plug & crank it over several times after putting gas & let it sit a while to dry out or blow it out with compressed air. It should go.
Apr 04, 2012 | Mtd Garden
Car has been sitting; will turn over but won't start. Used starting fluid and car starts but quits. Won't fire without starting fluid. There is fuel in the tank. Help!!
My first thought is to check the fuel pump operation.
Check to see if fuel pump is getting power.
This is how I check the pump.
Usually there is an in-line fuel filter that can be removed.
While its removed...bump the starter to see if gas shoots out the gas line.
If not, there might be a clog at the pump...or the pump needs replacing.
Hope this helps...
Jul 24, 2011 | 1989 Oldsmobile Delta 88
My rear tine tiller, 18 inch - model #21AA40M1029 by yard machine has been sitting in my storage shed for two years and will not crank. I have changed the old spark plug with a new one and I have drained...
need to check for spark---- magneto [magnet-pulse to coil] may have rust causing failed spark can clean lightly with sandpaper but more than likely u need to clean the carb-buy a rebuild kit about 10 bucks -take off carb tear apart and let soak in parts cleaner use a carb cleaner and spray all the nooks and crannys in carb rebuild replace and try firing up because more than likely the carb is completely gummed up from the old gas
Jun 08, 2011 | Yard Machines Tiller 208cc 18in Tilling...
Mantis tiller will not start. Cannot get primer bulb to draw fuel.I replaced all of the lines,primer bulb still won't work. Tiller will start by priming cylinder by removing spark plug. Help?
Make sure there are no leaks in the bulb. Did you reattach the fuel lijnes correctly? You should feel resistance after pushing 3 or 4 times to ensure fuel is getting to the carb. If necessary replace the bulb. Otherwise check with Mantis at www.mantis.com or give them a call for troubleshooting assistance.
May 22, 2011 | Mantis Gas Mini Tiller/Cultivator, 2 -...
Old (1981)Troy Prof. 8hp tiller runs 30 sec. and stops.
Clean the carb and if this machine was kept outside all winter make sure no water in tank. I realize you stated that you removed old gas but how it was removed is the key. Try the carb thing first though.
Apr 28, 2010 | Troy-Bilt Pony Garden Tiller
Tecumseh 8 hp tvm220
it is a standard magneto fired engine --- go on line and google up magneto
Jun 22, 2009 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
Mantis 2-Cycle Tiller Logo
191 people viewed this question
Top Mantis Garden Experts
paulfvincent
Jim Parker
Jim Parker
Mike Squire
Are you a Mantis Garden Expert? Answer questions, earn points and help others
