Question about Sony VPL-DS100 Multimedia Projector
Sony VPL-DS100 Hi I have this projector that I put a brand new bulb into 6 months ago and then used once and it has been in storage ever since. When I plugged in yesterday to watch a movie the top left hand corner of the picture on the screen is a pink shade. Would there be something on the bulb?
  • DianeMcF May 23, 2008
    Also do you know where I could get a new filter cover for the projector - mine is missing. Thanks
  • 563 Answers
Hi DianeMcF
There is only two things that could cause a pink colour to appear on your screen.
Try using a different cable - which I'm sorry to say - I doubt will fix the problem.
This is most probably a LCD that will have to be replaced , and do take my word for it that this is not something you would want to replace yourself as it is extrememly difficult and a very delicate process not to harm the other LCD's.
Posted on May 26, 2008
Blue dots
http://www.nodevice.com/user_manual/sony/projectors1/vpl-ds100.html
Use this link to download your manual troubleshoting tips, to see if problem referred on.
Aug 09, 2008 | Sony VPL-DS100 Multimedia Projector
Sony vpl-px30 clicking noise on power-up, lamp will not come on
I had the Problem, I replaced the bulb and it fixed the problem.
a year ago I was not able to find this bulb under 450.00, I bought it last month from amazon for $73.00 and free shipping.
Jun 17, 2012 | Sony VPL PX30 Multimedia Projector
How do I reset the lamp timer on the Sony VPL-DS100?
Yes, press RESET, <, >, ENTER keys on remote simultaneously to reset lamp timer. Display of lamp will also change to zero.
Make sure projector is just plugged in and should not power On (in standby mode) to reset lamp timer.
Jun 03, 2010 | Sony VPL-DS100 Multimedia Projector
Where exactly is the fuse located for Sony VPL DS 100?
Take out the screws on the bottom. Flip it over and take off the top plate. Pull (from the connectors) the wires going over what looks like a steel plate with several small holes. Take out the screws (6 total) holding that plate and the circuit board on. Pull off the steel plate and the plastic under it. Lift up on the circuit board under that: there are to connectors on the underside that have to be removed. Once you get it out, the fuse is near the end, about 3/4" long and ceramic white.
Feb 07, 2010 | Sony VPL-DS100 Multimedia Projector
LMP-H150 reset hours on sony cineza VPL-HS2
These instructions are for a Sony Cineza VPL HS3, but may be the same for the HS2
1st thing to check - is the cover properly/completely closed - this can stop the projector from working.
Connect the power and set the projector to standby mode.
Press these buttons on the remote control in this order, for less than 5 seconds each.
Reset - Left Arrow - Right Arrow - Enter
This is required, to reset the lamp timer.
Also, something I found interesting from the internet - lamp life isn't when the bulb dies, but when a bulb has lost 10% of its brightness - so you might well be able to reset the timer and get much more use from the bulb - the image just wont be as bright.
Jul 04, 2009 | Sony Cineza VPL HS2 Multimedia Projector
Sony VPL-DS100 will not turn on
I had same problem. The cause was a blown fuse (T5.0 Amp 250V). You have to open the case and then get below the print that is under the alloy cover. it is quite simple to fix. A fuse costs 60 cents.
Apr 18, 2009 | Sony VPL-DS100 Multimedia Projector
Sony VPL-DS100
I have solved this problem. Seems the rotating stand on the front bottom needed to be pushed and turned so that it inserts well inside. If it not well pushed the projector keeps shutting down itself every 10-15seconds. Took me about an hour to open the projector and doing all kinds of experiments to finally try that. :)
Jul 06, 2008 | Sony VPL-DS100 Multimedia Projector
Reset after using emergency close feature
Hi jimmac123
Where exactly in the UK are you ? I'll try and locate another - more helpfull company.
May 20, 2008 | Sony VPL-ES1 Multimedia Projector
Blue Bleed
Hi there
Does this only happen once a signal is inserted ?
Does it happen on both PC & Video signals ?
Have you tried using a different cable yet ?
Apr 16, 2008 | Sony SuperLite ultracompact Project...
Sony VPL-DS100 Multimedia Projector Logo
318 people viewed this question
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
