Question about CTX PV 700B 17" LCD Monitor
CTX monitor SAB802 pivots to vertical cannot get it back normal
Ctx pv720a monitor goes blank
This is what inverter board looks like:
http://www.shopjimmy.com/catalogsearch/result/?q=CTX%20PV720
Look for bad caps also, more likely to need new inverter board, warning, you can have bad lamp assembly also.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Capacitors kit: http://lcdalternatives.auctivacommerce.com/
Jul 27, 2010 | CTX PV 720 17" LCD Monitor
I'm missing the power adapter for the CTX Monitor S500. Where can I find one?
http://www.google.com/#hl=en&source=hp&q=power+adapter+for+the+CTX+Monitor+S500&btnG=Google+Search&aq=f&aqi=&aql=&oq=&gs_rfai=&fp=ff274912d96214e6
Jun 24, 2010 | CTX S500BA (Black) 15 in. Flat Panel LCD...
CTX P922E LCD monitor
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, falied inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what goes wrong: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further.
Mar 30, 2010 | CTX P922E (Silver) 19" LCD Monitor
I have a ctx moniter says undectected mode
CTX 15"1024x768 TFT LCD-Black Monitor · i have a ctx moniter says ... Answer. i have a ctx moniter and wen i plugnitin to pc tower itsays undeceted mode watdoes this mean. Close Close. ASUS Eee PC 1000H
Dec 03, 2009 | CTX 15"1024x768 TFT LCD-Black Monitor
Ctx monitor
try lowering the screen resolution
Oct 19, 2009 | CTX S762A 17" LCD Monitor
Looking for AC power Adopter for CTX LCD monitor
Check it on Radio Shack maybe they got something
Jun 03, 2009 | CTX SV900MD 19" LCD Monitor
My CTX VL701 EX701F monitor keeps going black with just a horizontal light showing, it happened for briefly at first and then returned to the screen but the length of time its black is increasing - any...
If you are referring to a conventional CRT monitor, then the fault you have described is indicative of a cold solder in the vertical section. Often, this would be any of the pins of the vertical IC. The vertical IC is the only IC that is heatsinked and sits at the back of the flyback transformer.
This of course would require a fair familiarity of electronic components/circuitry and safety procedures, use of a DVM and a soldering iron. It would be to your added advantage access to a service manual or at the very least a schematic diagram with voltage readings. Should you be uncomfortable performing a DIY (do-it-yourself), perhaps your best bet would then be to seek the services of a qualified professional.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 19, 2008 | CTX Computers & Internet
New CTX x762 LCD Monitor
inside the round bit there is a bolt its very tight but you will have to dissasemble to get to it apart from the obvios ones there are 4 hidden behind rubber covers on the sides and then th fron frame unclips this i difficult to start off but by the power button on the side there is a square lump of plastic sticking out place a flat head skrewdriver between this and the front lip and gently twist and the first clip wil come undone and from there you can get the rest good luck
Feb 01, 2008 | CTX S761 17" LCD Monitor
Open Questions:
See all CTX PV 700B 17" LCD Monitor Questions
CTX PV 700B 17" LCD Monitor Logo
131 people viewed this question
Top CTX Computers & Internet Experts
Jerry Greenberg
Jerry Greenberg
Martin Murray
Are you a CTX Computer and Internet Expert? Answer questions, earn points and help others
