Question about West Bend 72122 Electric Skillet
Power Cord with heat control where can I find a replacement
    Filmmaker:
    Uploaded 5 video answers.
  • 131 Answers
You can find vintage small appliance replacement parts here. As of the time I'm answering this, there is a WB#1 heat control cord. http://www.etsy.com/shop/lauraslastditch?section_id=8148638
I hope this helps!
Posted on May 28, 2011
  • Linda Bauer
    Linda Bauer Nov 29, 2015
    Thanks, Laura for your suggestion. I think I will buy a new skillet since the power cord I wanted to replace started on fire and when I think about it, I think the skillet probably needs replacing.
Need a power cord for a Lektro Maid Skillet (Heat Controlled Dial No: 3679)any ideas?
go to any electrical shop or appliance repair shop and ask them
Oct 26, 2016 | Heating & Cooling
Tappan oven won't come on
follow this steps and fix it.God bless you
Power Cord
If the power cord fails you still may have the control portion working but no bake or some other functions. The reason this happens is the oven takes in 220 volts then splits that to 2 110 lines. Some for the controls, lights, bake and broils elements, and stove top. If your cord has failed on one half of the 220 line or the terminal block were the wires are connected may have melted or failed. You may need to replace the power cord and terminal block.
Heating Element
This is usually the problem. To Check this first turn oven on to a bake setting,say @350, check to see if element glows, if not shut oven off. If it is warm but does not glow it is getting power and the elements need to replaces. If it does not get warm remove the element and check to see if it is getting power if it does get power replace the element. No power it is the main control that has failed. Check element for continuity, if none replace.
Temperature Sensor
This is a long thin tube like part located usually in the top rear of the oven. It is held in by 2 screws. This can easily be removed by removing the 2 screws and carefully pulling it out. Usually there will be wires connected and insulation so you will need to work it out. Then unplug the connector and check with an ohmeter. It Should have around 1000-1100 ohms if not replace sensor. Some will have a thin capillary tube attached in this case the problem will be in the control attached to this tube.
Main Control
This can cause your oven not to heat. Sometimes the oven relay gets burned out, when this happens the control is unable to send power to the bake element. There will usually be separate relays for bake and broil if you have 2 different elements. If your heating element gets no power replace the control. If your control does not respond at all check to if youhave power entering the control. If you do and it does not respond replace control board No power to the control Check or replace the power cord .
Jul 29, 2013 | Tappan Kitchen Ranges
Oven doesn't heat up all the way on our Jenn-Air duel-fuel range
all repairs should be performed by an authorized service person. if your breakers were tripped there is a high voltage short or weak home breakers. when resetting the breakers make sure the dual breaker switches are in the on position. if the is ok check for the proper voltage is at the power outlet is correct.if it is ok unplug the range. be sure not to break the gas line. remove the rear panel check to see if the power cord power cord is secured to the power cord terminal.if the terminal is damaged do to the shortage at the terminal replace the terminal and power cord. when replacing the power cord and install the power cord restrain that usually comes with the.power cord.
Jun 02, 2017 | Jenn-Air JDS9860AAS Dual Fuel (Electric...
Iron will not heat
see the causes and proceed according, fix it. God bless you
If the iron doesn't heat, make sure power is on to the outlet, check the electrical cord, and check the thermostat (see the Appliance Controls Fix-It Guide) and replace if necessary.
If the iron heats but steams improperly, inspect the soleplate and clean the vents (see below) and flush sediment out of the steam chamber (see below).
If the iron produces too much or too little heat, test the electrical cord . Also test and, if needed, adjust calibration of the thermostat (see the Appliance Controls Fix-It Guide).
Sep 22, 2012 | Rowenta Irons
Will not heat
see the causes and proceed according. fix it. God bless you
Sep 22, 2012 | Rowenta Advancer Iron
Reset buttom on Samsung Range
please see the next steps with common sense: God bless you
Power Cord
If the power cord fails you still may have the control portion working but no bake or some other functions. The reason this happens is the oven takes in 220 volts then splits that to 2 110 lines. Some for the controls, lights, bake and broils elements, and stove top. If your cord has failed on one half of the 220 line or the terminal block were the wires are connected may have melted or failed. You may need to replace the cord and terminal block.
Heating Element
This is usually the problem. To Check this first turn oven on to a bake setting,say @350, check to see if element glows, if not shut oven off. If it is warm but does not glow it is getting power and the element needs to be replaced. If it does not get warm remove the element and check to see if it is getting power if it does get power replace the element. No power it is the main control that has failed. Check element for continuity, if none replace.
Temperature Sensor
This is a long thin tube like part located usually in the top rear of the oven. It is held in by 2 screws. This can easily be removed by removing the 2 screws and carefully pulling it out. Usually there will be wires connected and insulation so you will need to work it out. Then unplug the connector and check with an ohmeter. It Should have around 1000-1100 ohms if not replace the sensor. Some will have a thin capillary tube attached in this case the problem will be in the control attached to this tube.
Main Control
This can cause your oven not to heat. Sometimes the oven relay gets burned out, when this happens the control is unable to send power to the bake element. There will usually be separate relays for bake and broil if you have 2 different elements. If your heating element gets no power replace the control. If your control does not respond at all check to if youhave power entering the control. If you do and it does not respond replace the control. No power to the control Check or replace the power cord.
Jul 27, 2012 | Samsung RESF3330D Electric Kitchen Range
Is no workig i needcramic heat control
1. you need a multi tester.
2. check the power supply of your outlet, or check the fuse or circuit breaker.
if has power go to 3.
3.open the back of your electric iron, the end of the cord or plug. then try to check the continuity of two wires if any is open. if its open or no continuity replace the cord or plug, either cut the only open wires and reconnect it again.
4. Or check the heating element of your electric iron if no resistance replace the heating element or you buy a new one.
Feb 16, 2011 | Conair Irons
PTC153B50AM REPLACED POWER CORD ON RECALL
First off, you need to unplug power from the unit before handling anything on it, not just the master switch on the control board. There is still live power being fed to the unit while it is plugged in!
Now, the clicking sound you are hearing is a faulty relay on the control board. You have to replace the control board. The new ones are available from Amana/Goodman Mfg.. You will find, assuming you have more of these, your other units are going to start doing the same thing. It will be the same problem. When they send out the new control board, make sure you program the board. They no longer come pre programmed. It is actually a huge improvement on the older control board upgrades. Hope this helps, I have 140 of these in my hotel, I know them all too well. Let me know if you have any other questions and please rate this as a fix ya.
Dec 25, 2008 | Amana PTH123B25AJ Heat Pump Air...
Malfunction heating pad
Same F2, quick off problem here. Then I noticed that the gray plug on the power cord was not completely flush with the connector on the pad. I shoved them together until there is no gap. The unit's worked perfectly since then.
Mar 24, 2008 | Sunbeam 805810 HeatSense Heating Pad...
West Bend 72122 Electric Skillet Logo
974 people viewed this question
Top West Bend Kitchen Appliances - Others Experts
Irene Tulloch
Angel Joseph Jr.
Angel Joseph Jr.
Jerry Greenberg
Jerry Greenberg
Are you a West Bend Kitchen Appliances - Other Expert? Answer questions, earn points and help others
