Question about Pentair MiniMax 100 Aboveground 100,000 BTU Propane Gas Electronic Heater
MiniMax 100 ignites but shuts off shortly after igniting
  • Greg Waller Sep 28, 2010
    Does it make a lot of noise first? Are you using Propane? How much is in the tanks?
  • 139 Answers
SOURCE: we have a pentair minimax 100 pool heater it was
start with pressure switch,likely out of adjustment or it could be faulty.if you're going attempt to adjust,press sw,you should be familar with using a multi-meter.improperly adj could result in ruining htr and possibly a fire hazard
Posted on Jun 21, 2009
  • 246 Answers
SOURCE: Minimax 250 Cycling on and off after reaching 20 degrees
change the assembly valve
Posted on Oct 13, 2009
  • 990 Answers
SOURCE: Purex Triton Minimax 400 pool/spa heater not igniting
This sounds like you have a problem with your pilot. You can check this with a small mirror to see if their is a spark when you turn it on. If you have any soot build up on the pilot that will stop the spark and keep it from lighting also. If you have a short on your pilot wire this could be the problem also. I hope this helps, good luck.
Posted on Dec 12, 2009
  • 760 Answers
SOURCE: I have a PacFab MiniMax 100 pool heater. The
First thing to check is the flow switch. You can bypass it temporarily, and see if it lights. DO NOT OPERATE IT WITHOUTH FLOW SWITCH. If it isn't the flow switch, then it could be the thermostat or a bad connection on this low voltage millivolt circuit.
Posted on Jul 04, 2010
UglyPoolGuy
  • 46 Answers
SOURCE: Pentair Minimax CH Propane Millivolt Ignition
If you are firing, and then going off and getting an E05, your igniter is to blame. It may be glowing but it's getting weak. The diagnostic goes further but that is usually the fix.. With inactivity, the igniter is always to blame. You really need to fire it off weekly to make it reliable and make sure that your heater is serviced at least one time a year to keep all the internal components operating as designed.
  • PILOT ASSY LP MV CH150 IID
  • Manufacturer: PENTAIR WATER POOL AND SPA INC
  • Manufacturer Part #: 471291
  • Description: Propane pilot assembly for heaters with millivolt ignition.
  • Retail Cost: Approximately $65.00
Posted on Dec 08, 2010
How do i install an igniter in minimax
Pentair 472604 Igniter Replacement MiniMax NT STD Pool and Spa Heater
The ignitor is simple to replace, It is either a spark ignitor or a Hot surface ignitor. The above link will take you to a picture of the Hot surface ignitor, it is normal held onto the bottom of the burner tray, at right about the middle, by 1 or 2 sheet metal screws.
If a Spark style ignitor/electrode, then the bottom link is the one want to look at. Again, held in place the same way as above description.
Pentair 471090 Ignitor Electrode Replacement MiniMax 75 100 Pool and Spa...
Good Luck
Jun 04, 2014 | Pentair Minimax NT Heater
Igniter works gas kicks on after igniter stops if it would spark a little longer it would lite I can lite it with a match
Check igniter! You don't have the right spark? Lots of times it will short out & you can see the sparking elsewhere other than just at the gap at top of the igniter. The other thing to check is ensure that the orifice is completely clean at the pilot burner. A clean pilot orifice and the proper spark will ignite the heater.
May 19, 2014 | Pentair MiniMax 100 Natural Gas Swimming...
We just replaced our old minimax 100 with a new one. Plugged it in, turned on the heater and it ignited perfectly. There is water flow and it has heated up but smoke is coming out from under the coils. Is...
I've never had smoke, but I have experienced a " smell " that burns off the first few times direct from the factory. I would call technical support to share your experience. 1-800-831-7133 or 1-888-755-7946.
Apr 02, 2011 | Pentair MiniMax 100 Aboveground 100,000...
I have a PacFab MiniMax 100 pool heater. The pilot remains on... but the burner will not ignite unless I hit/jar the heater. Any suggestions on what may need replacement or repair?
Jul 04, 2010 | Pentair Minimax 100 Pool Heater
We have a pentair minimax 100 pool heater it was working the other day, now our pool is cold as it won't even try to ignite. does anyone have an idea as to what part to start with replacing to see if we...
Jun 21, 2009 | Pentair MiniMax 100 Aboveground 100,000...
Jun 05, 2009 | Pentair PUREX MINIMAX HEATER; THERMOSTAT,...
Pentair MiniMax 100 Aboveground 100,000 BTU Propane Gas Electronic Heater Logo
35 people viewed this question
Top Pentair Pool & Spa Experts
Pj Kiley
Pj Kiley
Level 1 Expert
Jay Finke
Jay Finke
Bill Jordan
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
