Question about Kenmore PRO 24 in BuiltIn Dishwasher with Ultra Wash HE Filtration 13173
I just bought the Kenmore Ultra Wash Dishwasher model # 665.1389. It worked about 4 times then before the it finished it lost power while it was running. Now it won't turn back on at all. I done everything in the trouble shooting manual and nothing worked. It's not the circuit breaker either. Everything else on the same breaker works fine. What could it be?
  • 209 Answers
SOURCE: Kenmore Ultra wash model 665 17779990-Cycle wont finish- Lights blinking
heater element if its not warming up, you didn't say, if it worms up then check the pump
Posted on Oct 15, 2007
markevans
  • 148 Answers
SOURCE: Kenmore Ultra Wash Dishwasher wiring diagram
if unavailable on line, contact mfg's parts and you should be able to order it.
also, they likely do not make the unit. the sears may be able to tell you who made it. that company would be able to get you a diagram. just make some phone calls.
Posted on Dec 21, 2007
SOURCE: Kenmore Ultra Wash Dishwasher - 665 - 13783
dcvxzcxzcxzczxc
Posted on Feb 26, 2008
SOURCE: My kenmore ultra wash model
my model #665 dishwasher will not pump water into the unit
Posted on Jul 15, 2008
  • 83 Answers
SOURCE: Kenmore Ultra Wash dishwasher
check and see if you are getting ac 110 volts to your water vave when trying to start the unit. if no power check your breakers and /or the incoming power to your dishwasher if they are ok and show 110 voltage coming to the unit then you probably have a control board or touchpad problem which would need a little more detailed check out.
If you do have ac 110 to your water valve then you may just have a bad water valve. Because the washer has to fill first. Hope that helps!!
Posted on Jul 02, 2009
How do I cancel the 4 hour delay wash on the control pannel. it is a Kenmore Elite dishwasher model 665.1392
Press cancel. If the 4 hour delay is still lit, you have a shorted control panel.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jeffrey_634abadf963e31e5
Aug 14, 2014 | Kenmore 24 in. Elite Built-In Dishwasher...
When finished with cycle the dishes are still wet. It is a ultra wash quiteguard 3
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
How to Replace the Dishwasher Heating Element
Dishwasher Maintenance
heatman101
Asker
Apr 22, 2011 | Kenmore Dishwashers
Normal wash light blinking, d/w wont start
Wish I could solve this, as I'm having the same problem too. Normal light blinks not matter which wash button is pressed. Cancel light will light, but still NOTHING happens. Same model as yours.
Jul 23, 2010 | Kenmore PRO 24 in BuiltIn Dishwasher with...
Smelly dishes from Kenmore Ultra Wash
If you post the model number of your dishwasher plus its approximate age (in years) I can help more.
But the most common cause is a weakening pump motor. On many dishwashers, the wash pump motor is also the drain motor. Replacing that motor / pump assembly will solve the problem. While you are replacing the pump, check the heating element to confirm that it is not shorted out or broken.
For now, add a cap full of bleach to the water _after_ the initial dishwasher fill cycle ends and the wash cycle begins. White vinegar would also work, but this will not fix your problem.
Good Luck!
May 04, 2009 | Kenmore 24 in. 15932 Built-in Dishwasher
Kenmore Ultra Wash Dishwasher LIghts are blinking....
I suspect for either of these units that the timer control boards are bad.
Jan 24, 2009 | Dishwashers
Kenmore ultra quits working pf and e8 light come on
If your pf light comes on that means that your outdoors fuse needs to be replaced. The same thing happened to me and I bought another dishwasher for the same proble to occur. I don't know if it's to late but the only thing wrong is your fuse is blown. Good luck!!!!!
Nov 23, 2008 | Kenmore 13599 / 13594 / 13592 Built-in...
Kenmore ultra wash dishwasher control lock light flashing
Just press the 'Air Dry' button for 5-6 seconds....I have an ancient Kenmore Dishwasher (ULTRA)
Oct 02, 2008 | Kenmore 15899 Built-in Dishwasher
I just read this for the same problem: push sanitize, then heat and dry, sanitize, heat and dry, sanitize, heat and dry, cancel, then open and close the door. It worked. The dishwasher is running correctly even as I type this.
Feb 11, 2008 | Kenmore 24 in. 17262 Built-in Dishwasher
Kenmore PRO 24 in BuiltIn Dishwasher with Ultra Wash HE Filtration  13173 Logo
213 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
