Question about Dell E172FP 17" LCD Flat Panel Monitor
Dell Monitor 17" power is on at the time display working fine.and few second after display is hide so solve the problem. By S.Balamurugan
  • 11,361 Answers
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed DELL monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Replacement board: http://www.lcdrepair.us
Posted on Sep 28, 2010
Monitor stays on for a few seconds then goes black
could be your wires or your moniter itself check those replace the wires and see what happens if it doesnt work just pm me
Feb 26, 2012 | Dell E173FP 17" LCD Monitor
Dell E173FP 17 monitor went dark and not working. I restart the pc it shows for only few second and went out again. I plug in one other monitor in my pc and it work fairly well. So something not right with...
Hi!
There are three possible cause why your monitor went black and start working..
1. If your monitor is dead set.. no reaction or lights turn on after power on.. then it needs to check if there is blown capacitor in its power supply section..
2. The high voltage ballast transformer of the backlight inverter is burned - it needs to be replaced so that it will not have a direct effect on the power supply section of the monitor.
3. The backlight inverters are all busted - the backlight was located at the upper and lower back edge of the monitor.. If these lights are busted then all that will be seen in your monitor is black screen.. It will need to be replaced so that image display will come out from your screen..
These 3 reason and its solutions can only be done by yourself if you have the knowledge, proper skills and the right tools to open the back cover of the monitor and replace the problem parts....
Otherwise, bring your monitor to a credible technician and if there is warranty,, avail of this...
Hope that answer your question..
Much appreciated if you rate this help..thanks..
May 20, 2010 | Dell E173FP 17" LCD Monitor
Dell LCD screen - powers up...i see the log on then black
I guess your monitor needs some maintenance.
Have it checked by a technician
Mar 28, 2010 | Dell E172FP 17" LCD Flat Panel Monitor
Dell E173FPb 17" TFT LCD Flatpanel
Video cards that can handle two monitors at the same time have cables with two plugs on the monitor end.
If your video cable has two plugs on the monitor end, try the other plug.
Dec 29, 2008 | Dell E173FPb 17" TFT LCD Monitor
Dell F1703 17 in. Flat Panel... Problem
There may be problem of heating the inside components. see him to expert.
Mar 03, 2008 | Dell E173FP 17" LCD Flat Panel Monitor
Philips 17PF9936/37 17'' Flat HDTV slow to start working
mi tv turns on but only in color blue,next tv turn off red light apear one time and second time flash twice,whit mi remote control power on tv turs on ,then whit mi remote control send change chanes or any other funcion the tv turns off,letme now if you solve yor problem ,and i apreciate if you have some tips for me,thank.
Jan 09, 2008 | Philips Epic 17PF9936-37 17" Flat Panel...
Dell e171fp + turn off after a second
hi, are you able to browse thru the LCD menu, there must be some settings for power management.. let me know?
bye
Dec 15, 2007 | Dell E171FP 17" Flat Panel LCD Monitor
Display goes black after 5 minutes
Repairing the DELL E171Fpc LCD Monitor with the complaint of display shutdown after few seconds (power LED still on) was not difficult. Normally when this type of problem happens, we would first suspect the inverter board, then the filter capacitors and lastly the main board. A defective in one of the lamps and a faulty TL1451AC PWM IC or inverter ic may caused the display to shutdown as well. If the lamp is defective, it will send a feedback to pin 3 or 14 of TL1451AC IC and caused it to stop producing output signal thus the display just shut off once you switch it on.
Dec 09, 2006 | Dell E171FPb 17" Flat Panel LCD Monitor
Dell E172FP 17" LCD Flat Panel Monitor Logo
mukhtar21 shaikh
mukhtar21 shaikh
