HOW DO I SET UP TO ONLY PRINT BLACK. - Office Equipment & Supplies
  • 240 Answers
Buy a monochrome laser machine. There are no ink printers that only ever print black. Laser machines are 1/2 the cost per page, never clog, and run forever.
Posted on Sep 28, 2010
Is there a way for me to set my copier to default print black and white? I know this can be managed by each PC but sometime folks forget so i would like to deafult all print jobs to B/W unless otherwise...
TO SET THE MACHINE FOR BLACK AND WHITE ALLL YOU NEED TO DO IS SELECT BLACK ON THE COPIER PRESS THE UTILITY USER KEY THEN PRESS COPIER BUTTON DEFAULT BUTTON THEN SELECT CUREENT SETTING
THIS WILL DEFAULT THE MACHINE TO COPY IN BLACK TO SET PRINTING IN BLACK YOU CAN SET UP THE DRIVER TO PRINT IN BLACK ONLY
Jun 03, 2011 | Konica Minolta Bizhub 222 Black and White...
The black prints as grey. The only time it will
Go into Printer "Properties" look for "Print in Greyscale" set it to OFF, OR set to color,either way
Mar 05, 2010 | HP PSC 1610 All-In-One Printer, Scanner...
Will only print color even though there is black ink left...If I set it to print with black ink, blank pages come out. I know there is black ink left so why doesnt it print when I set it to print black??
Hi Mel,
It sounds like your print head could be blocked or the black cartridge has gummed up.
Have you tried taking the black ink out, put a rag over the hole where it would normally come out (carefully as it could go all over you) and gently shake the cartridge, then replace it back in to your printer.
Try printing in black and see if it helps, if not then i would be quite sure that its the print head, if this is the case then the only way would be to contact HP as I'm not sure if its possible to remove the print head or even if HP supply replacements.
I hope this helps a little
Mike
Sep 26, 2009 | HP DeskJet D2560 InkJet Printer
Changing ink default to BLACK
Not possible.
Epson uses the black cartridge mostly, but also adds color to the black printing in order to keep the color inks from drying in the print jets on the printhead.
They also make lots of money that way...
===sorry===
Sep 14, 2009 | Computers & Internet
Won't print black when set for plain paper
Try removing all ink bins except black then you won't have any problems. You should also be able to go into your printer settings and select "Black and White" or "No Color" and it will print ok. Removing the ink trays is the easiest way though.
May 28, 2009 | Canon PIXMA iP4200 InkJet Photo Printer
Wont print in color
Have you checked the driver to see if it is defaulted to black in the properties?
And have you scrolled your machine set up on the screen to be sure it did not get set to black?
Print out a test pattern and see if there is color on it. An internal test pattern. There are sample prints you can print out. If they come out in color, then your driver is most likely set to black and white.
Go into the properties of the driver and then graphics. See how it is set.
May 14, 2009 | Xerox Phaser 8560MFP Laser Printer
How do i get my printer to print in color instead of always black?
make sure you have a reasonably full color cartridge in the printer and check its color settings. start, control panel, printers, right cilck your printer and go to properties..make sure its not set to black and white. Also in the program you're printing from, click on print (dont use the print icon that auto-prints)..so file, print and make sure theres no options set there that are also set to black and white. if the printer has an lcd screen on it with a menu, you can also look there for settings.
Apr 26, 2009 | Office Equipment & Supplies
I have Windows XP with Rx580 Epson Printer and need black print
Get one of the resetters for the ink cartridges (might not be easily available in the US - I know they are available in Thailand. Reset (electronic resetting of the internal chip) the color cartridges to "full" and then set the printer to "BLACK ONLY". Don't print in color and you can print black. Alternately get a set of refillable cartridges (I got a set again in Thailand for about $20 for the set of 6) fill the black and ignore the others. it will ONLY print BLACK
Mar 31, 2009 | Epson Stylus RX580 InkJet Photo Printer
I can't print in color
There are several possibilities here:
1) The default printer settings in your OS (operating system) were set to black only. If you are in windows, go to the windows control panel and choose the printers icon. Find your printer and modify the settings to allow color.
2) The application is overriding the default print settings. Look for something under the application's menu system like "File...Print Setup", or "File...Printer Settings" and change the print mode there to color.
3) The application's page setup is set to black or greyscale only. Look in the application's menu system for something like "File...Page Setup" or "Format...Page" and make sure it's not set to black only.
You will probably get better answers to your question by providing more info like what OS, or version of Windows you are using and what program you are trying to print from.
Dec 19, 2008 | HP LaserJet 2840 Printer
Print black w/o color ink cartridges loaded
No, in general all current inkjet printers require the installation of a color cartridge even if you want only black printing.
(If you had an old cartridge "Empty", you might be able to purchase a resetter (Epson) and set you printer to print in black only.)
You can, set up your computer to print in black only by selecting Mono printout in your print set-up.
There are a few Canon printers (Older) that used to print in Black or Color only printing....but no longer available......
Feb 09, 2008 | Office Equipment & Supplies
18 people viewed this question
jasbo
jasbo
