Question about ASUS K8N Motherboard
K8N motherboard I've got an ASUS K8N-EAYVZ mobo and it went dead. No fans working or HD. Only sign of life is the Green power LED which is ON. I've tried resetting bios - but no change. I know power supply works if you short out the ps on pin to com. So it looks like the mobo isn't starting the power supply? power supply is Eagle ATX400w. Any ideas
  • George Somerville May 30, 2008
    Thanks for your advice. Unforetunately I don't have a sparespower supply, however I was able to start by PSU by shorting the ps-on pin on the 20pin connector and this powered fans ok. So I believe something on the mobo is stopping the PSU from starting.
  • George Somerville Jun 14, 2008
    my problem has progressed a little. I treid a replacement power supply, but this made no difference. I've now replaced the mobo to an almost similar type, however when booting from the HDD the system shuts down. I can get into bios, but any booting from the HDD shuts down the pc.
    any ideas?
  • 187 Answers
Have you tried a secondary PSU? (though it sounds like your motherboard needs replacing)
Posted on May 25, 2008
  • Steven Burn
    Steven Burn May 30, 2008
    Shorting the pins to get the power through usually indicates a short on the board and/or a faulty PSU.
    I'd still advise getting a new PSU before proceeding (a new PSU will only cost around £10-£15)
Hello, I have a problem with my mobo asus K8N-VM. Not send signal to the monitor. Please give me some advice!
make sure battery is in mother board make sure the fuse is good and in mother board make sure aluminium tower is clamed on black chip to mother board and also make sure fan is cecurelt tight on mother board.
Feb 26, 2011 | ASUS K8N-VM Motherboard
I'am working on ASUS P5PE-VM mobo, I removed the memory, video card and isolate the mobo away from the casing so no short circuit may occur during test. I plugged in the power supply and the front switch...
Clear CMOS or remove CMOS battery, Press the on off switch for 30 seconds.
Now go to BIOS setup,and set bios fail save default,and press F10>enter.If the problem same change the RAM if you have a spare.
Hope it helps.
Jan 13, 2011 | ASUS P5PE-VM Motherboard
Motherboard no power
In this order:
check PSU is working ( fans run in the psu), test with another psu installed,
See of there is a green LED lit on the mobo
Check capacitors are not bulging or leaking and there are no signs of burned circuit traces on mobo
remove ram and try booting see if you get power to the cpu fan
try bypassing the PW switch and touching the PW terminals on the fpanel header to eliminate swith problem.
If that fails, suspect dead mobo
Jan 11, 2011 | EliteGroup ECS P4M900T-M2 Socket 775...
Pc not starting from pressing power on. Green LED for SB_PWR is on and when power switch pressed, fan & cool fan flicker momentarily but nothing happens. They do not spin. No LED light appears on front...
> PC had been suddenly powering off several times intermittently for a few days leading up to this state. Does this mean the PSU or Motherboard is at fault?
Yes, either CPU or PSU or motherboard are the likeliest culprits.
It's easier to try a different PSU than to try a different CPU or motherboard.
Nov 18, 2010 | ASUS K8N-E Motherboard
No video after replacing chip fan
Try a different video-card -- a "no-spin" fan and "no-video" implies a dead video-card (or at least a video-card that is not "seated' properly).
Check that the PC-speaker leads are connected to the motherboard, so that you could hear any "beep" codes. There should be one "beep" to indicate 'OK', or multiple "beeps" (bad RAM, no video-card detected).
Apr 09, 2010 | ASUS A8N-SLI Deluxe Motherboard
Serious problems with an Asus M2N E SLI motherboard.
try the board with out memory and hard drive.
Do fans run?
Nov 21, 2007 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
No power and blinking green LED
It may not be that the bios needs clearing, take the left side panel off and look for the 'JBAT1' terminal on the mobo and put jumper cap from pins 1-2 to pins 2-3 for a few seconds then back to pins 1-2. start the pc then set the time and date when prompted ans save settings.
Feb 09, 2007 | ASUS K8N Motherboard
Asus NRL-LS P4 MB power on issue
unplug the power wait for 30 secs, then plug in and retry
Dec 27, 2006 | HP (311185-001) Motherboard
ASUS K8N Motherboard Logo
440 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
