Question about Frigidaire FGQ332ES Gas Dryer
How do i get to the inside of the dryer - i need to replace a part in the front and can't figure out how to get the front panel off
  • 205 Answers
Hello- First, BE SURE the dryer is unplugged, and then be sure again. You will need to release the two retaining clips that attach the top the the front. They are located under the front of the lid a couple inches in from each side. The best tool is a putty knife or something a flat paint scraper. Place the tool between the top of the front panel and the lid and pry up a little bit in order to see the clips, they are about an inch wide. You have to press hard right into in (its like a flat metal spring) and pry up at the same time and the lid should release. Repeat on the other side. They can be a bit tricky but just don't force it too much. Once the clips are released the top hinges towards the back. There should be a wiring harness that goes to the timer and switches and one that goes to the door switch, these have plastic connectors that should separate them as a unit. There is one screw on each edge of the interior of the front panel that holds it to the main dryer cabinet, take these out and pull the front panel forward and up and the panel should separate itself from the cabinet. You have to be careful when you put the front panel back on that it slides in on the bottom retainer clips and that the top of the drum is positioned correctly over the felt on the front panel. Just don't force anything. Hope this helps, best regards.
Posted on Sep 27, 2010
Testimonial: "Thank You so much you couldn't have explained it any better. I had it taken apart in less than 15 minutes with your instructions."
Manual on How to replace belt
  • 1
    Remove the power cord from the wall outlet.
  • 2
    Open the dryer door. Remove the screws located along the inside of the doorway with the Phillips screwdriver.
  • 3
    Pull the top part of the front panel away from the MDE5500AY dryer to disconnect it. Lift the front panel up to disconnect it from the metal clips on the dryer cabinet.
  • 4
    Unplug the wire connector leading to the door switch.
  • 5
    Unscrew and remove the four screws connecting the front panel to the rest of the cabinet. Lift the front panel up and away from the dryer to remove it.
  • 6
    Pull the idler pulley toward the left to relieve tension in the belt. Slide the belt off of the idler pulley and the Neptune dryer drum.
  • 7
    Route the new dryer belt around the drum and along the pulley system. Release the idler pulley to restore proper tension in the belt. Rotate the drum to ensure the belt is positioned properly.
  • 8
    Replace the front panel onto the dryer cabinet. Replace the four screws that connect the front panel to the cabinet of the MDE500AY dryer.
  • 9
    Plug the wire connector into the door switch assembly. Lower the front panel down into its original position.
  • 10
    Replace the screws along the inside of the doorway.
Sep 18, 2012 | Maytag Neptune MDE5500AY Electric Dryer
One of the "fins" inside the dryer is coming off and just needs to be tightened but I cant figure out how to get to the drum to tighten the screw.
The top cover needs to be lifted to the rear of the dryer to access the outside of the drum, but you have to remove the front panel first. Disconnect power to the dryer prior to servicing to avoid the risk of electric shock.
Open the dryer door and remove the four screws located vertically along the inside lip of the door opening. These screws hold the front panel to the front shroud assembly.
Once the four screws are removed, grasp and press in on the upper edges of the front panel posts then twist it inward to release the clips holding it to the cabinet. Tilt the top of the front panel and move it away from the dryer.
The top cover is held on each side of the cabinet by two hold down brackets. Locate and remove the 5/16" hex-head screws holding each bracket.
Swing the bracket to the outside and unhook it from the slot in the top cover lip.
Open the door then lift the front of the top cover and tilt it toward the rear of the dryer. The baffles securing screws can now be re-tightened. Reinstall the top cover and the front panel by following the removal steps in reverse order.
Sep 23, 2010 | Maytag Neptune MDE5500AY Electric Dryer
How to replace gas coil valves on Whirlpool LGR5636EQ3 Gas Dryer
DOES YOUR DRYER HAVE THE LINT SCREEN ON THE TOP? IF SO, REMOVE THAT AND TAKE TWO SCREWS OF(CARE NOT TO DROP IT INTO THE VENT). PULL THE TOP PANEL TOWARD YOU LITTLE BIT AND LIFT UP, THERE WILL BE TWO 5/16 SCREWS INSIDE FRONT PANEL, REMOVE AND UNPLUG THE LID SWITCH CONNECTOR, FRONT PANEL WILL COME OUT. THE GAS VALVES AND COILS ASSEMBLY WILL BE ON THE BOTTOM RIGHT. UNPLUG AND TAKE THE SCREWS OFF THE BRACKET AND REPLACE COILS. CHECK FOR CONTINUITY ON COILS, IT SHOULD READ 1.3 TO 1.9 OHMS. THE ONE WITH THREE TERMINAL, CHECK OHM FROM MIDDLE TERMINAL TO OUTSIDE TERMINALS.
BOYNISMO@YAHOO.COM 714-334-1998.
Aug 21, 2009 | Whirlpool LGR5636L Gas Dryer
I'm trying to replace the door catch on the front panel of a Whirlpool Dryer model GEW9868KQ1. I've replace the piece on the door but can't figure out how to get the front panel off.
Hi, You shouldn't have to remove the front panel. Just squeeze the latch hard enough to remove it. I hope this helps. Please let me know if I can be of any more assistance.
Thanks
Vic
May 16, 2009 | Dryers
I have a grinding sound (like metal on metal) when I turn my Kenmore 70 Series dryer on. So right now we are not using the dryer. Any solutions. I was going to open the top up but cannot figure out how to...
Your drum seals may need replacing.
Unplug the dryer.
Remove 2 screws under the lint filter flap.
Raise the hood by prying under the front top corner.
remove 2 screws from the top right and left front inside corners.
Remove the door panel by lifting up.
unplug the door switch wires.
remove the belt from the motor pulley.
remove the drum
also check the drum rollers attached to the inside rear cabinet.
Mar 10, 2009 | Kenmore Dryers
Screeching sound when dryer is running
This is a bit of a job. The dryer needs to be in the open. The top swings up by pushing a flat blade screwdriver in the seam between the top and the front panels about two inches from the sides to release the latches. With the top up and supported, Remove the two screws that hold the front panel to the side panels. These are inside the cabinet and near the top of the front panel. Disconnect the door switch wiring and remove the front panel. This is when you find all that lent that the filter missed. Remove the small louvered panel on the back near the bottom of the left side and reach inside and disengage the belt from the motor and idler pulleys. Remove the three phillips screws arraigned in a trangle on the back of the drum near the hub inside the dryer. Remove the small plastic spacer? located in the center of the cabinet where the top and front panels come together. I never could figure out what that thing was for. Now the drum will come out the front of the dryer. Go slow as to not mash or cut a finger. The rear bearing is now accessible for lubrication or replacement. It's not that hard, it just takes a while. Good luck.
Dec 24, 2008 | Frigidaire GLER331A Electric Dryer
How do I remove the front bottom panel of my Whirlpool gas dryer
Yahoo! I figured it out on my own. There are two clips on top that are recessed. I had to use a regular screwdriver and push the clips down and pull the panel out at the same time. It was easy after I realized what needed to be done.
Sep 14, 2008 | Whirlpool LGQ9858P Gas Dryer
Lint trapped inside dryer housing
SHUT OFF POWER AND GAS
1. Begin by opening the door removing the two screws on the left side of the door opening.
2. Then remove the screws that secure the door hinges to the cabinet. Lift off the door (may take some wiggling)
3. Grasp the outer top sides of the front panel and pull toward you.
4. Lower the front panel and lift off.
5. At each top corner remove the screw and latch that hold down the top.
6. You should be able to do the rest from here.
Jun 14, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Frigidaire FGQ332ES Gas Dryer Logo
236 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
