Question about Elna 2007 Mechanical Sewing Machine
I have an Elna 6003Q sewing machine. My light bulb went out and I need to replace it. How do you get it out and replace it?
  • Elna Master
  • 7,365 Answers
Some call it a lamp cover door or face plate it's on the left side of the sewing machine
some sewing machines have a hinge at the back of the face plate, you can gently pull it open to change the bulb
some machines -in the middle of the face plate there is a plastic plug, use a screw driver to gently lift the plug & then unscrew the screw & change the bulb.put the face plate back on put the srew back in & put the plug back in to concile the screw
Posted on Sep 27, 2010
How does one change the bulb on an elna 6003 sewing machine
Hopefully you have a manual that shows how to replace the bulb. Online Elna manuals have a fee.
Perhaps something here will help:
Change bulb elna 6003q
How do you change light on elna 6003 sewing machine
Watch Me For Minute Elna Lightbult Change
Jun 06, 2016 | Elna Sewing Machines
How can I replace lamp?
The owner's manual should have instructions how to replace the bulb, but sometimes that information is not provided. However, this link may be helpful:
Elna quilters dream 6003 apart to replace light
Feb 26, 2016 | Elna Quilter's Dream 6003Q
Lena sewing machine 6003 how old?
Hi, I'm Julie. Is the model of your Elna machine called Lena? Is your machine an Elna 6003? Is your machine an Elna 6003Q?
May 01, 2015 | Elna Sewing Machines
Do I need to oil an Elna 6003Q sewing machine?
Yes, in the middle of the bobbin case there may be a little hole with a wick below it where a drop of oil can be placed. Much of the internals are now self lubricating or designed for the tech to libe during the recommended annual service
Jun 30, 2014 | Elna Quilter's Dream 6003Q
removed plastic plug (with a small screw driver,so the plastic plug
does not get damaged) on the side of the face plate
carefully removed screw behind plug--be sure not to strip the screw head
carefully pull or wiggle loose plastic cover until it comes off
giving access to bulb.
Jun 03, 2012 | Elna Quilter's Dream 6003Q
Burned out bulb.
Generally on an Elna there's a little hole on the very top of the sewing machine directly above the bulb.
Pushing a long, skinny stick (like a screwdriver,) down into this hole will push the lightbulb and socket assembly down to where you can actually access the bulb without having to try to skvoosh your fingers into the tiny space.
-R
Aug 28, 2008 | Elna Quilter's Dream 6003Q
Elna 6003 just stopped working
Something caught inside the machine and jammed the mechanism. It blew a fuse to protect the circuit board. A competent Elna or Janome Dealer should be able to get you machine going in no time.I don't know of any reason to have trouble finding parts for this machine.
sewman7
Jul 05, 2008 | Elna Quilter's Dream 6003Q
Elna 6003
I had the same problem and was sewing for quite awhile without my light working. Finally, a friend of mine was over and we did get it replaced. I believe there are a couple of plastic tabs behind the machine, and we pried them off and there was a screw behind them, (I can't remember if there was one or two plastic tabs) when we unscrewed them that popped off the cover and I was able to replace the bulb. I hope that helps, and when I go home I will check it again to see if I missed anything. Good Luck!!
Mar 05, 2008 | Elna Quilter's Dream 6003Q
Elna 2007 Mechanical Sewing Machine Logo
232 people viewed this question
Top Elna Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Derek Massey
Are you an Elna Sewing Machine Expert? Answer questions, earn points and help others
