Question about RCA P52930BL 52" Rear Projection Television
Hi , I have a Toshiba 42 inch Theater wide rear projection tv . I got the tv used from someone on Craigslist and when I got it home plugged it in , it took about 30 minutes to actually get a good picture . After the picture came in at its best , there is about 2 inches the way way accross the top of the screen that is shaky kind of like a waving flag . Its a pretty good picture if I could stop that waving , I didnt get the remote with the set or the manual so dont know if there is something that the remote could do to fix this or not . Any help with this problem would be greatly appreciated . Also I can be emailed at skyboy_011@yahoo.com Thank you
chillmaster
  • 104 Answers
SOURCE: RCA 52-inch (rear projection) big screen television
Rear projection tv's from 13 yrs ago used three high power CRT's to project the picture. Due to the high power and light output of the CRT's, it wears pretty ******* the tubes. Honestly 13 yrs sounds like a pretty good life on a big screen. You might check into repairs, but the cost would probably rival that of a new comperable HDTV.
Posted on Jun 18, 2008
yambo
  • 230 Answers
SOURCE: RCA 46 inch convergence problem
AM sorry, but can you provide your model number TV and chassis please?. I will tell you location parts. Thank you
Posted on Aug 13, 2008
  • 1030 Answers
SOURCE: 52 inch tv has a warped picture with a rainbow type ark at top
check out the article "the fl231 problem in the tips and tricks section
Posted on Apr 28, 2009
SOURCE: 3 thin colored lines across the top of screen of an rca r56wh78
You have Convergence Failure Problem...
Posted on May 12, 2009
hotratchet
  • 952 Answers
SOURCE: 52 INCH RCA REAR PROJECTION SHUTS OFF
Your TV is overheating.. easiest remedy is to point a fan at the back of the TV or... clean the inside of the TV, Im sure its full of dust and stuff... this prevents air circulation inside the TV thus creating more heat...
Posted on Jun 19, 2009
When i turn on the my toshiba theater view tv all that happens is the of/on idicater light just flashes
We recommend you remove the "Digital In" cable connection from the rear of the TV and turn it back on. If the problem persists, we recommend having the TV evaluated by an authorized service center using the below link.
www.panasonic.com/repair
If the TV turns on then we recommend having the Toshiba Home Theater evaluated. Welcome to Panasonic Online Repair
Mar 26, 2014 | Panasonic PT-47WX53 47" Rear Projection...
What's your problem?40-42 inch Theater View Toshiba TV, Date on TV is June 1999. Picture slowly started shrinking from up and down. Model no. TZ50V51 Serial no. 77988872 chasis no. 9951
you're experiencing a vertical deflection issue and will most likely need to replace the deflection board. You can get a deflection board for your model from www.tvrepairworld.com
Oct 18, 2011 | Toshiba 57H81 57" Rear Projection...
No sound
More than likely you need to go into your menu settings. Check to ensure that your TV speakers are enabled. The previous owners may had it hooked to theater system
Oct 20, 2009 | Toshiba TP50G60 50" Rear Projection...
The tv seems really dark.57in theatrewide hd toshiba
Go into the tv menu and select the Preferences menu and set your picutre preference from Theater to Normal. The TV is currently in Theater mode, wich is for viewing with no lights on in the room. Switching it to normal lightens the pictue a lot.
May 27, 2009 | Toshiba 57H81 57" Rear Projection...
What TV should i buy ? (help)
Go with the samsung it will be the best of all of repair wise!!! The other sets you are talking MONEY for repairs.Hitachis DCU module a lone retails 275.00
Dec 04, 2008 | JVC AV-56P575 56" Rear Projection...
Toshiba 42 inch rear projection T.V.
this sounds like a convergence loss... the most likely cause of this is what is known as stk's or convergenc ic(chips) have gone bad.. also it cound be the output resistors. most likely need replaced
May 12, 2008 | Toshiba 42H83 42" Rear Projection...
Toshiba 52" rear projection
   The theater wide feature 1 may not be available in all tv channel formats.
Try the downloadable manual at www.retrevo.com
Feb 23, 2008 | Toshiba TheaterWide 52HM84 52" Rear...
Televison & Video Logo
94 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
